Old Apr 03, 2009, 05:51 PM
Joined Nov 2005
Mounting an outrunner on a glider
I'm considering putting an outrunner in a 3m glider (see other post), but the glider has been designed for traditional brushed motor with 2 screw mount in the wood flat nose.
To mount an outrunner in-board, could i screw the supplied cross plate to the outside/front, and then screw threw to the motor on the inside. This means the can would spin in a fairly tight space, and I need to be careful with the wires but is this feasible ?
FFMan is offline Find More Posts by FFMan
Old Apr 03, 2009, 06:07 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I suppose you could use the X-mount ahead of a ply plate, but you could also screw (with washers) just through the ply plate itself. As long you can route the leads free of the rotating can you are fine.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Apr 03, 2009, 09:23 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Here's another way to do it....
Mount the motor to a thin aluminum plate (license plate material or thicker) using the front motor screw holes. Screw the plate to the fire wall. Would require you to enlarge existing fire wall hole.
hoppy is offline Find More Posts by hoppy
Old Apr 04, 2009, 07:19 PM
Boston, MA subburb
Joined Sep 2004
If you have not already purchased the motor, use a brushless inrunner that drops right in
http://www.astroflight.com/index.php...products_id=74
Alan
Al Offt is offline Find More Posts by Al Offt
How to maintain the thrust line when using an outrunner on a stick mount eran_k Power Systems 5 May 24, 2005 02:22 PM
Can I use an outrunner on a wing? GraphicsMan Flying Wings 5 Mar 12, 2005 03:58 PM
Mounting an outrunner on an IFO supergroomer Parkflyers 1 Dec 13, 2004 04:02 PM
Mounting an AXI on a Formosa - Here's How rcmann Parkflyers 3 Apr 18, 2004 01:44 PM
Mounting an outrunner on a stick mr_wood Power Systems 2 Feb 02, 2004 04:13 PM
