Old Apr 25, 2002, 12:11 AM
dom is offline
Find More Posts by dom
Toronto, Canada
Joined Sep 2001
Can't run two Hackers off one controller?
I am trying to run two B40-15S Off one Hacker Master 70-3P. The leads from the controller to the motors are of equal length and about 6 inches long. I am using the same connectors between motor and controller as are used on FUN 400 motors. They both start successfully about 1 in 10 times. With no props they start up OK. I am using an 8 cell RC2400 pack. My friend is running two FUN 400-23 off a 50amp Kontronik controller(without BEC). Any advice would be appreciated.
dom is offline Find More Posts by dom
Old Apr 25, 2002, 09:11 AM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Sounds typical. I tried running two Jeti 15-4s each with a Jeti 30 amp controller off of one battery and had unreliable startups. If you nose around, most folks who report running two brushless motors off of one controller have problems- except for the guys running twinjets with very short leads and the right motor/controller combination.
P.S. I'd be very leary about running a motor without a prop- you might get an overspeed- but I'm not sure.
Megowcoupe is offline Find More Posts by Megowcoupe
Old Apr 25, 2002, 10:13 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
It is not really a issue of lead length but, one of the controller, motor and prop. Fact is that the Kontronik 3SL controllers will run most twin setups and Schulze and Jeti will not. I have had 2 twins with brushless and a single controller. Large heavy props(APC gas) are much harder to get started. Low turn high RPM motors are harder to get started. I have had good luck with the Kontronik controller running 2 Aveox 1406/4 and with 2 Aveox 1005/4 motors.
sneu is offline Find More Posts by sneu
Can I run Two Chargers off of (1) 12V regulated power supply? mrebman Batteries and Chargers 4 Feb 28, 2005 04:58 PM
Two Brushless motors one controller counter rotation Ductedfann Foamies (Kits) 7 Oct 10, 2002 02:40 PM
Two Brushless motors one controller counter rotation Ductedfann Scale Kit/Scratch Built 2 Oct 10, 2002 01:26 PM
Can I run two chargers off a 12V automotive charger cruzomatic Batteries and Chargers 7 Aug 11, 2002 11:48 AM
Can we run two ail. servos and elev. on 3 chan. receiver ? Lenny970 Power Systems 4 Jun 30, 2001 01:54 AM
