Old Nov 22, 2015, 10:32 AM
homer5364 is offline
Find More Posts by homer5364
Joined Jan 2015
Mini CP lift problems
I have a Mini CP with lift problems. The Mini will not lift off the ground. I don't know if it's the files I use or a motor problem. I use a Devo 7E upgraded to deviation firm ware. I use files Tom Zader uploaded to . The files were under ultra beginner settings. I am a newbie and need guidance where to get my files and then maybe I can make some progress. Thanks for your input.
homer5364 is offline Find More Posts by homer5364
Old Nov 22, 2015, 12:23 PM
Steve_ is offline
Find More Posts by Steve_
More Flights = Less Crashing
Steve_'s Avatar
United States, WI, Beloit
Joined Nov 2012
Welcome to RCG !
While we don't have much to go on, here is something you can quickly check.
After removing your blades, power everything up and check your pitch range by using throttle hold and
running the collective from from low to high and looking at the blade grips.
You should have 10+ degrees of positive pitch at full collective.
(While removing the blades might seem to be overkill, it makes for more comfortable troubleshooting.)
Is this a new helicopter? If not, how many flights does it have?
Have you measured your battery voltage after a flight?
How old are your batteries? Has it been crashed?
Steve_ is offline Find More Posts by Steve_
Old Nov 23, 2015, 09:57 PM
sprint11 is offline
Find More Posts by sprint11
sprint11's Avatar
Joined Dec 2013
have you went into your reverse settings and made sure your pitch is reversed
sprint11 is offline Find More Posts by sprint11
Discussion Best indoor 3D mini heli. HP100BL, Super CP, Mini CP, v977, Hisky HCP100? Varium 3D Electric Heli Flying 11 Aug 05, 2015 09:35 AM
Discussion Mini CP vs Super CP vs Genius CP V2 vs HiSky vs WLToys V977 vs ?? - Which to prefer? SoloProFan Micro Helis 32 Jun 03, 2015 01:19 AM
Discussion Walkera master cp lift off problem msgoblue Electric Heli Talk 6 Feb 07, 2014 09:21 AM
Mini-HowTo Fix: Tail drift problem on Genius CP and Mini CP bobepine Micro Helis 54 Dec 17, 2013 10:29 AM
Discussion AXE CP vibration and lift problem, help! Nicros Micro Helis 2 May 24, 2007 02:26 PM
