Old Jul 23, 2001, 12:54 AM
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Battery Pack for Astro Cobal 15G /Sig 6' Cub
Just bought a used geared Astro 15 geared cobalt motor and Astro Model 211 esc. want to power a 5-pound Sig Cub for grass ROG scale-like flight, 8-10 minutes duration with throttle management.
1.Number and type of cells needed.
2.Best Master Airscrew or APC prop.
3.Does the Astro 211 have BEC or will I need a rcvr pack?
Thanks in advance
E-Challenged is offline Find More Posts by E-Challenged
Old Jul 23, 2001, 01:32 AM
Rod
Canada, BC, Kelowna
Joined Nov 1999
E-Challenged, (Arn't we all), Answers to your questions:
1) 12 cells -- either 2400 Nicads or 3000 NiMH's. If performance is not up to what you wan't you can go to 14 cells, just try and keep the amps draw within reasonable limits,(25-30amps) 2) I like the Master Airscrew Electric props(wood) in a 12 x 8 on the Astro 15G. The APC's(electric) I use in smaller sizes are very good as well. 3) The Astro 211 does not have bec, so you will have to use a flight pack to power your receiver and servos.
Rod is offline Find More Posts by Rod
Old Jul 23, 2001, 03:24 PM
Chief Turnip Inspector
Cincinnati, OH USA
Joined Dec 1999
I agree with Ron. I use the 14 cell set-up for A Tiger Moth to good effect. 12 cells is probably more than enough for for a Cub. I use the APC 12x8E prop and it seems to work geat.
Ted
tiggs is offline Find More Posts by tiggs
Old Jul 23, 2001, 04:55 PM
United States, IL, Wonder Lake
Joined Apr 2000
I have a SIG clipped wing 1/6 scale cub. It is powered by a AF15G standard gearbox, MA 12 X 6-10 prop, and 12 2000mah nicd cells. It weighs between 5 and 6 pounds. I think about 85oz but cannot remember exactly. It has more than enough power. It flys very well at about 1/4 throttle. easy 10-12 minute flights, with throttle management. Excellent climb. It will fly and ROG with a ten cell pack but very borderline power. it need almost full throttle then to maintain level flight. 12 cells works great but if desired 14 would be fun too.
Rob
ratobin is offline Find More Posts by ratobin
What battery pack for Astro 035 with 7x3? Flyinphil Batteries and Chargers 3 Dec 31, 2004 09:15 AM
Question Best battery pack for SIG Jenny/Bristol Scout? PfalzPflyer Batteries and Chargers 15 May 03, 2004 03:38 PM
battery pack for Astro 020 aerodave Batteries and Chargers 9 Jan 21, 2004 09:49 AM
9.6 V 1800 mAh Battery Pack for Zagi and other electric RC aircraft ALL e RC Aircraft - Electric - Airplanes (FS/W) 0 Sep 14, 2002 04:57 PM
Battery pack for GWS Cub RookieOne Parkflyers 4 May 08, 2002 07:52 PM
