Old Mar 07, 2014, 12:18 PM
Flying a recreational vehicle!
Flying Pitcher's Avatar
Greenland, Qaasuitsup
Joined Apr 2013
Idea
4axis gyro! collective controller.
qqqqqqqqq
Flying Pitcher is online now Find More Posts by Flying Pitcher
Old Mar 07, 2014, 12:47 PM
Kauai
Joined Jan 2011
Quads use Baro for altitude hold,most quad flight controllers can be setup for helis(at least some list heli settings).Gps altitude hold can vary +\-100 feet or more so not accurate enough.
Kauaiguy is offline Find More Posts by Kauaiguy
Old Mar 07, 2014, 12:50 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
I don't think you have thought this through. Just what would this additional gyro measure, that it could compensate? A 3 axis gyro already measures pitch, roll and yaw. There is no 4th axis. Accelerometers measure change in attitude, barometers measure change in altitude, magnetometers measure change in heading and GPS measures position. Without those "fancy barometric control devices" you have nothing to measure.
Balr14 is offline Find More Posts by Balr14
Old Mar 07, 2014, 04:54 PM
Joined Apr 2013
qqqqq
Old Mar 07, 2014, 11:16 PM
Closed Account
Joined Aug 2007
It sounds reasonable. It would have to have an extra accelerometer I suppose, or maybe combine existing accelerometers. It's probably been done, but I've never heard of it.
eagle777 is offline Find More Posts by eagle777
Old Mar 08, 2014, 11:30 AM
United States, NJ, Manville
Joined May 2006
I think you have to read what Barl said again....Maybe he confused you with the attitude thing.....I think the better way to say that a Accelerometer measures a given enertia on an object....A barometer measures air pressure which changes when altitude changes.....
skizziks is offline Find More Posts by skizziks
Old Mar 08, 2014, 12:19 PM
Joined Apr 2013
qqqqqqqqq
Old Mar 08, 2014, 12:32 PM
Closed Account
Joined Aug 2007
Originally Posted by Flying Pitcher View Post
well, i'm not talking about total altitude hold, but rather keep those spikes from happening during gusts of wind where the accelerometer just trims collective a little to keep it from jumping up and down..
That's what I thought you meant also. There is probably a reason it is not done, probably issues with dampening collective or it's not really necessary.
Old Mar 08, 2014, 12:43 PM
Denver, CO
Joined Dec 2005
A regular gyro needs rotation, so its out. An accelerometer would eventually get confused by having to track the motion, and by g-forces. So something else is needed.
A barometer, laser altimeter, optical devices, sonar, and GPS are things I know have been used. Sometimes a combination of devices, since each has its drawbacks.
Roto Rob is online now Find More Posts by Roto Rob
Old Mar 08, 2014, 01:20 PM
Joined May 2006
Accelerometers and Gyros do not detect changes in altitude....GPS alone does nothing and needs feedback from satellites to measure altitude change.....A Barometer detects changes in air pressure which happens when an object changes altitude......The Naza H uses all 4 sensors...You can use 3 excluding GPS and still keep altitude.....They make chips with both Accelerometers and Gyros on the same chip so why not use that chip and a Barometer to be more accurate ?...
Old Mar 08, 2014, 02:20 PM
Joined Apr 2013
qqqqqqqqqq
Old Mar 08, 2014, 03:03 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Try the DJI Naza H. Or, buy a mulitWii flight controller board.
Old Mar 08, 2014, 04:55 PM
Joined Apr 2013
qqqqqq
Old Mar 08, 2014, 04:58 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
A multiwii board with everything but GPS sells for about $50. But, it requires some fair mount of effort to use it. What you want has been done with these boards.
Old Mar 09, 2014, 01:00 AM
postcounts are meaningless
Green Darner's Avatar
Joined Feb 2014
Just took a drive to Astoria OR (right at the mouth of the columbia river and pacific ocean).
As we started down the hill into town, the Garmin said we 427 feet above sea level. I'm thinkin' that's about 200 feet too high, but not 100% sure. On the way home, at the top of the same hill, it said we were 42 feet BELOW sea level.
Gotta go with Kauaiguy
Green Darner is offline Find More Posts by Green Darner
Sold (2) MINI MWC Flight Control Board and DSM2 Receiver ACC/GYRO/BARO/MAG + GPS, OLED LCD crd Aircraft - Electric - Multirotor (FS/W) 10 Apr 06, 2014 09:30 AM
Sold Blade BLH7601 4-in-1 Control Unit, Rx/ESCs/Mixer/Gyros: Nano QX BLH7601 Used sst2000 Aircraft - Electric - Multirotor (FS/W) 0 Oct 28, 2013 02:02 AM
Sold CNC 4axis hotwire package browncbr1 Aircraft - Sailplanes (FS/W) 3 Jun 01, 2012 03:48 PM
Discussion HobbyCNC PRO Chopper Driver Board Kit 4axis Kevin Matney DIY Electronics 1 Jan 10, 2012 12:17 PM
Discussion getting gcode on both turrets 4axis wire cutter Blackrat CAD/CAM 2 Oct 14, 2011 12:41 PM
