Old Dec 10, 2013, 12:56 PM
jmendoza's Avatar
Joined Apr 2011
To slow it down, bypass your exhaust steam heater, run it straight off the boiler.
jmendoza is offline Find More Posts by jmendoza
Old Dec 12, 2013, 05:42 PM
jmendoza's Avatar
Joined Apr 2011
Photos of oiler attached!
Here is my version of a displacement oiler made from an M1 Carbine shell, works great. Sight gauge tubing is removed for draining and filling.
Old Dec 16, 2013, 03:23 PM
Joined Dec 2012
Thats a good idea with the shell, I like it, I might have to try one with a .45acp and see how it turns out!
The boat project has slowed down lately, after the 3rd attempt at painting and thinking I finally had it figured out when I peeled the fineline tape off from the paint it took some paint with it, so its been sitting for about week untill I feel like sanding the whole thing down AGAIN! Not having luck with this part of the build at all.
mcscott is offline Find More Posts by mcscott
Old Jan 05, 2014, 11:04 AM
Canada, ON, Toronto
Joined Jan 2013
I am building the same kit. For painting, I wouldn't use any automotive paints.
I am coating the hull in WEST epoxy (will post pictures soon).
Then I will be applying a Humbrol enamel primer, then the Humbrol enamel paint. This is proven to work.
SteamSurge is offline Find More Posts by SteamSurge
Old Jan 05, 2014, 11:07 AM
Canada, ON, Toronto
Joined Jan 2013
To slow it down, I installed a tap that lets me control how much steam to let through to the engine. There is also a T-fitting before the tap that sends steam to a whistle. Will post pictures.
You're not going to blow up the boiler if too much steam builds because of the plastic tubing "pipes". These will pop off before the boiler blows. Also, with the whistle, extra steam will force its way out that way.
I am also running a brass Prop Shop prop instead of the plastic kit one.
Old Jan 05, 2014, 12:53 PM
Henk Goosen's Avatar
The Netherlands
Joined Dec 2008
What size is the brass prop?
Henk Goosen is offline Find More Posts by Henk Goosen
Old Jan 05, 2014, 02:42 PM
Canada, ON, Toronto
Joined Jan 2013
Was custom made by Prop Shop:
The prop is 1.2" diameter, with larger pitch by using our Fast Scale propeller, part number 3015/3. It is 3 blade and left hand.
Cost was 25, including delivery to Canada.
Old Jan 05, 2014, 03:53 PM
The Netherlands
Joined Dec 2008
Thank you SteamSurge next week wednesday I will be in Canada. Surrey BC.
Old Jan 05, 2014, 04:54 PM
Canada, ON, Toronto
Joined Jan 2013
Nice. Try to go to Vancouver and Whistler; one of the most beautiful places in the world.
Complete RC Idiot Savant
The Netherlands
Joined Nov 2009
If you can find a controllable burner, you have a slightly slower response, but both water and fuel will last a lot longer (and you'll be surprised how relatively quick a boiler responds to burner modulation).
Brgds, Bert
Brutus1967 is offline Find More Posts by Brutus1967
Old Jan 06, 2014, 01:59 AM
The Netherlands
Joined Dec 2008
I know SteamSurge I used to live in the Lower Mainland, was in construcion in those days.
We build a fourplex in Whistler in the late nineties.
Old Jan 07, 2014, 12:28 AM
Just call me "Mo"
mogogear's Avatar
NE PDX OR
Joined Aug 2008
A very smart - simple design for draining!! Well done with the thinking muscle
mogogear is offline Find More Posts by mogogear
Old May 05, 2014, 02:05 PM
Joined Dec 2012
ok, some updates... Finally got somewhere with this thing. After setting it off to the side for a while due to paint frustrations I finally got some decent results. I painted it green on the bottom, white on top, and used real actual gold leaf for the stripe. Then went over the entire thing, bare wood and all with automotive grade polyurethane clear coat and it turned out ok.
Such a pleasure to finally get the maiden voyage in, ran great had about 6 minutes of good strong steam and she trucks along really well at a fast walking speed and sounds amazing "I think anyway" sorry no video the wife was busy with the dog instead of video taping.
Thanks rcgroups for the inspiration. Now I need a bigger one with a real steam plant in it!!
maiden voyage
Old May 05, 2014, 02:15 PM
Joined Dec 2012
Now I need to make some accessories for it, thinking of making it a fishing boat so to say, some nets, maybe little tires on the side or something, at least a person in it. Where is a good place to find a little person to put in here?
Old May 05, 2014, 09:31 PM
Au_Wozza's Avatar
Australia, SA, Elizabeth Downs
Joined Mar 2007
congrats on the maiden....... Have a look on fleabay for 1:12 scale doll house people
like
http://www.ebay.com.au/itm/1-12-Doll...530fe16&_uhb=1
Au_Wozza is offline Find More Posts by Au_Wozza
Discussion Midwest Steam Engine Anxst Capt. Windypants Steam Boats 43 Jan 07, 2014 12:35 AM
Discussion Midwest steam engine mcscott Steam Boats 10 Oct 24, 2013 08:24 AM
Question Midwest steam engine oiler? impmotor Steam Boats 4 Sep 26, 2013 10:51 PM
Sold NIB Midwest Fantail launch with steam engine kit. nero1156 Boats (FS/W) 2 Apr 27, 2013 09:43 PM
Sold Midwest Elliot Bay Steam Launch and Engine NIB dds7197 Boats (FS/W) 6 Oct 02, 2005 02:45 PM
