Old Jul 09, 2013, 11:39 AM
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Music Wire strut steerable C Clip
Does anybody have a better method than to add a C clip near the bottomw of the music wire to keep the 3mm music wire strut from falling into the retract besides trying to cut a groove into the wire with a dremel disk and then using a C clip ?
Are there other options Im missing ?
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Jul 09, 2013, 08:06 PM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
On the wheel side of the retract? If so, a wheel collar will do. If you mean, inside the retract, there isn't much room for anything but a clip.
Wintr is offline Find More Posts by Wintr
Old Jul 09, 2013, 08:36 PM
Champagne Supernova
Joined Jul 2010
Inside the retract other side of the trunion. Pita.
Old Jul 10, 2013, 10:46 AM
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
Yeah, big PITA. While the wire was still straight, I chucked it into a drill, put the drill in a bench vise, then set it turning. Then, I gently touched my Dremel cut-off wheel against it, to carve the groove. After that, I bent the wire to form the axle.
Old Jul 10, 2013, 11:16 AM
Champagne Supernova
Joined Jul 2010
Yeh I did something similar with my dremel in the vise. I ended up with a crude groove but I put a clip on it this morning to test and it looks like it may work, maybe a dab of epoxy too.
Sold Front steerable strut, possibly robart, new martys40s@verizo Aircraft - General - Miscellaneous (FS/W) 4 Apr 28, 2013 08:33 AM
Discussion Aerial clips used in music video Hellsiege Aerial Photography 2 Mar 29, 2013 11:05 PM
Question Soldering Brass Tube / music wire mag1 The Builders Workshop 4 Feb 12, 2013 12:24 PM
Discussion Music wire question btown2 Foamies (Scratchbuilt) 13 Jan 20, 2013 12:40 PM
Help! Robart Strut Music Wire Problems dawhale Flight Accessories 13 Mar 14, 2012 06:01 AM
