Old Jun 07, 2013, 01:25 PM
PcChip's Avatar
Joined Sep 2012
Tried the Zippy 6s 5000mah batt from HobbyKing
I ordered a few of THESE to try out since they're only $80 apiece - and I have to say they've been holding up nicely! I have 40 cycles on one and 20 on the other, and they still pack a decent punch for the price!
When I compare it to a 6s 5300mah 30C Gens Ace battery, I notice the Gen's Ace is only *slightly* harder to bog when REALLY smacking it around hard (full pos/neg collective with full cyclic) but the zippies are really good for the price (especially if you're just doing sport flying)
Just wanted to give my opinion on them - anyone else tried them ?
PcChip is offline Find More Posts by PcChip
Old Jun 07, 2013, 02:19 PM
Professional heli wrecker
Luvmyhelis's Avatar
United States, WA, Spokane
Joined Oct 2010
Yep, those and the Turnigy's. But I won't go below 45c. The ripple effect is pretty bad below 40c hammering the big ones. I lost my last esc due to this on my Goblin. I did notice a degrading of punch overall by about the 30th cycle on them.
Luvmyhelis is offline Find More Posts by Luvmyhelis
Old Jun 10, 2013, 09:43 AM
barnstorm100's Avatar
United States, CA, Rancho Cordova
Joined Jan 2011
Just ordered a 3000mah 40c for 500, so we'll see. I've heard they're ok. The Turnigys are all back ordered so time to try one. I believe the Zippy 40c are the equivalent of Gensace 25c.
barnstorm100 is offline Find More Posts by barnstorm100
Old Jun 12, 2013, 08:25 PM
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
I just recieved one today. After reading your post i thought i would give one a try @ only $80 for a 6s "45c" 5000mah battery. Took 4 days from time of order. All cells came in at 3.80....Now to see how they stand up to the test of time -n- flights on a chaos 600e.
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Jun 12, 2013, 09:16 PM
Atomic Skull's Avatar
Joined Dec 2011
Are you guys removing the 5.5mm bullets and replacing them with your connector of choice or just using a battery adapter?
I really, really don't like the idea of soldering wire that large.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Jun 12, 2013, 10:04 PM
Need More PURPLE !!
Joined Aug 2012
Replacing and going with EC5's. I use a Butain torch to solder with the bigger stuff.
http://www.ebay.com/itm/Portasol-Min...item5d3e18818a
Old Jun 12, 2013, 11:28 PM
Joined Dec 2011
Wish they would just put a normal connector on those, who uses separate 5.5mm bullets for batteries?
Old Jun 13, 2013, 12:51 AM
Need More PURPLE !!
Joined Aug 2012
I know right..I saw those and was dumbfounded. I cant even think of anything that uses those ..In a perfect world they would put EC5's on all 6s 5000mah batts.
Old Jun 13, 2013, 02:38 AM
Joined Dec 2011
EC5's are proprietary to Eflight though. If it was HK then they'd be using XT60 and XT90
Still don't know why a 30c battery needs massive wires like that either when the things that use a 5000mah 6S 30c battery are using speed controllers with 12 AWG wire.
Old Jun 13, 2013, 03:24 PM
Luvmyhelis's Avatar
Joined Oct 2010
I do. It is so much cleaner when wiring them in series for 12s than the complex soldering it takes to setup XT90s.
Old Jun 14, 2013, 02:01 AM
Never trust laughing dolphins
Joined Feb 2011
The thick wiring is s good thing. Less chances of running in to problems. I agree though that EC5s are a great match for these lipos.
PHMX is offline Find More Posts by PHMX
Old Jun 14, 2013, 04:18 AM
Joined Jan 2011
I just received the Zippy 3000mah 40c. It looks balanced. I also received 2 Gensace 25c, 2600mah for 500 and 4000mah for 550. I don't fly either of those at the park, so I'll have to wait till this weekend to check flight times. I'll start with 4mins on each and maybe end up going to 5mins or maybe even 5.5mins . I'm shooting for 3.83 per cell.
Sold [SLOLD] - 2x NEW ZIPPY Compact 5000mAh 6S 25C Wynn1427 Aircraft - Electric - Batteries & Chargers (FS/W) 1 May 26, 2013 04:53 AM
Found 1 or 2 6s lipos from 4 to 5000mah 3rd-dem Aircraft - Electric - Batteries & Chargers (FS/W) 0 May 07, 2013 08:37 PM
Sold Zippy 6s 5000mah 30c garrettt04s Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 20, 2013 01:28 PM
Sold Zippy flightmax 6S 5000mah 40c hi2nr Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 11, 2013 06:59 AM
Sold Sold 6S 5000mah Batts. Curt S Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 05, 2013 03:29 PM
