Old Jan 02, 2013, 04:03 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Help!
I only get black and white on my FPV cam
So.. i just got my whole FPV setup sorted out, and i powered the whole thing up to see how it would look, and i seem to be only getting a black and white picture from my cam. this is the camera that i have: 1/3-inch SONY CCD Video Camera (PAL). Other than the black and white problem, the video quality is very good and i have no static.. any suggestions?
-Seth
nightfox7 is online now Find More Posts by nightfox7
Old Jan 02, 2013, 04:12 PM
United States, CA, Huntington Beach
Joined Dec 2012
Check you voltages to the camera
CambriaHobby is offline Find More Posts by CambriaHobby
Old Jan 02, 2013, 05:21 PM
Joined Nov 2012
Many cameras will go to black and white in low light conditions. If you have it in a bright room, is it still black and white? Also, there may be configuration options of how low the light should be before switching to black and white mode.
(also, why PAL?. Most USA monitors will be NTSC. although that has nothing to do with color vs. b&w.. )
InFocus is online now Find More Posts by InFocus
Old Jan 02, 2013, 05:53 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Will do
Alright i'll see what i can do.
(Well NTSC was out of stock, though i have heard that PAL will give you slightly better video, where NTSC gives you a faster FPS of around 60FPS)
Old Jan 02, 2013, 08:07 PM
ISP Supervisor
makg's Avatar
United States, AK, Fairbanks
Joined Jan 2006
Check your connections @ the camera as well. I have one camera that when wiggled it will go to black/white or have static. Don't worry I'm gonna solder a servo lead on that one
makg is offline Find More Posts by makg
Old Jan 03, 2013, 09:06 AM
BEOWULF
North vancouver, B.C. Canada
Joined Apr 2008
My lawmate pvr goes bw sometimes
But now if I power up pvr first then all other stuff it always is color
Try powering up certain stuff first
Like the video tx last as example
David22 is online now Find More Posts by David22
Old Jan 03, 2013, 10:34 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Well it looks like my voltage on my camera was 11.8 while testing. Also, I took it outside today where it was well lit, and it was still B/W. And I checked my connections and tried to wiggle them and they seem to be solid.
I tried lowering up my camera first then my VTX, and vise versa. Still B/W. I'm beginning to wonder if I just got a bad camera..
Old Jan 03, 2013, 11:21 PM
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Does your camera have a menu? It could be selected to be in b/w
ashdec87 is offline Find More Posts by ashdec87
Old Jan 04, 2013, 10:46 AM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
If it does I don't know how to get to it
Old Jan 04, 2013, 11:05 AM
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
If you have a PAL camera and NTSC display you will only get B&W and you may have the video cutoff at the bottom. You just can't mix and match this stuff.
brontide is offline Find More Posts by brontide
Old Jan 04, 2013, 12:21 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
ah that would probably be my problem.. are there any simple converters?
Old Jan 04, 2013, 12:34 PM
Joined Sep 2012
Not really, and even if there were you would be losing resolution, increasing latency, and probably getting close to the cost of just replacing it. Get a NTSC camera or PAL display.
Old Jan 04, 2013, 12:37 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Duly noted.. well you live and learn i guess.
Old Apr 04, 2013, 05:21 PM
IndiaHobby's Avatar
United States, MD, Laurel
Joined Mar 2010
Same problem here...
Have a 8.8 g micro camera from FPVHobby that shows everything in Grey scale !
Followed the advice of other on this thread (NTSC/PAL, Power, etc), but it does not resolve the problem... I guess will live and learn !
IndiaHobby is offline Find More Posts by IndiaHobby
Old Apr 05, 2013, 12:24 AM
BEOWULF
Joined Apr 2008
Try powering up fpv stuff at different times
Power stuff up at opposite than you normally do
My lawmate pvr as example acts funny unless I power it up first
I get bw if powered up last as example
Some video tx need few or more
Power up to work
It's funny but that fox video tx is funny as well
As to get video with some fox units I need to re power video rx and video tx
If you get bw make sure lighting is well around camera
So no auto detect for bw
If problem persists
Un power everything and re power over and over again in different combos
Try different video sources for seeing video out
Look at video at googles and also tv screen
Many times my pvr record in bw but googles color
Because I not power up pvr very first
Discussion Anybody give advice on our HD FPV CAM pls. Piery 3D Flying 1 Feb 20, 2013 04:53 AM
Discussion OT, for those still on the fence about GoPro cams for your FPV needs. bgnome Dock Talk 9 Sep 19, 2012 01:59 PM
Discussion Wimped out on first time trying FPV on my hexacopter, any help to get over the fear jasper7821 FPV Talk 13 Mar 28, 2012 08:15 AM
Discussion Chester1 want opinion on my new Blitxworks Black Roigue 500V2 RTF pdpwp33 Beginner Training Area (Heli-Electric) 13 Mar 19, 2012 12:55 PM
