Old Sep 01, 2012, 02:33 PM
medic45's Avatar
United States, KY, Booneville
Joined Jul 2012
Heli NOOOB...lol
OK well not really a noob just a noob to real helis. I just got my Blade 120 sr in and am working on setting it up with my DX6i. I was hoping someone could sum up what settings if any I need to change? and do I need to set up as Achro or Heli?
Thanks for the help.
Remember NOOB so Keep it as simple as possible...lol,
medic45 is offline Find More Posts by medic45
Old Sep 01, 2012, 02:42 PM
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
ACRO is fine and there's nothing you really need to set. You don't need any special settings for a simple 4 channel FP heli.
Balr14 is offline Find More Posts by Balr14
Old Sep 01, 2012, 02:56 PM
medic45's Avatar
Joined Jul 2012
k ty
Old Sep 02, 2012, 08:48 PM
United States, MO, Springfield
Joined Jul 2010
imo id use a heli model so you can set up throttle hold good habit to get in to now
Elios000 is online now Find More Posts by Elios000
Old Sep 02, 2012, 11:46 PM
medic45's Avatar
Joined Jul 2012
any changes to be made in the heli mode?
Old Sep 04, 2012, 10:23 PM
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
Good advice. I absolutely rely on TH so much that I want it for my elec planes. I have contemplated setting up a plane in heli mode for this feature alone.
I've accidently bumped the throttle while not ready many,many times. Shoot, I switch to TH every time I spool my 450 down to make a radio adjustment, answer a question, do a safety check, etc and I do not take it out of TH until my fingers are on the throttle stick.
GooberSB is online now Find More Posts by GooberSB
Old Sep 05, 2012, 12:54 AM
Joined Jul 2010
you can set up throttle cut work like hold in airplane mode on the DX8 any way
Old Sep 05, 2012, 01:14 PM
Newbie but coming on fast
KYChopper's Avatar
United States, KY, La Grange
Joined Jun 2012
As a fellow newbie I am using the John Salt settings (http://www.rchelicopterfun.com/blade-msr-tips.html) on my DX6i for the 120 SR but if you search this forum (http://www.rcgroups.com/forums/showthread.php?t=1265101) there is a lot of useful information and I am sure you can find some basic settings in here.
For me, D/R and Expo are a must indoors, most of the others you could probably get away without.
KYChopper is offline Find More Posts by KYChopper
Old Sep 05, 2012, 02:11 PM
An Ordinary User
Joined Jan 2011
Is it a switch on the DX8? On the DX6i it's a pushbutton next to the ail d/r switch.
http://secure.hobbyzone.com/SPM6610.html
It's designed to kill the engine on gas motors so you press and hold it until the motor stops then let go. You have to hold it down to keep the throttle cut on electrics.
I read a post where someone replaced the pushbutton with a single pole switch to keep it on hold. I'm not against taht but think I may try setting a plane up in heli mode first.
Old Sep 05, 2012, 02:13 PM
Joined Jul 2010
yes i can assign it to any switch on the DX8
in heli mode you can even have both a cut and hold so you can do autos and still have a way to kill the engine for nitro gas helis
if you have the money i really would upgrade to the DX8 is such a better radio then the 6i
if you already have a few models youll be much happier
Old Sep 05, 2012, 02:16 PM
Joined Aug 2012
There is a throttle hold switch on my DX6i. and that throttle cut button. I have no idea what that button is for. Nitro?
KTMDirtFace is offline Find More Posts by KTMDirtFace
Old Sep 05, 2012, 02:22 PM
An Ordinary User
Joined Jan 2011
There are some menu differences between ACRO and HELI models.
HELI introduces the swash type and various curves depending on the swash type selected.
ACRO introduces wing types.
I'd choose HELI because the throttle curve can be adjusted and throttle hold is activated.
Even without CCPM, it can be fun to adjust the throttle curve and maybe set two curves and switch between them (norm can be low rpm for taking off).
Old Sep 06, 2012, 03:56 PM
Joined Jan 2012
medic 45
This is what you need to do
The only REAL thing you need to do for set up is to make sure all your trims are set to the center
If you are flying and notice that it is woundering too much one way there is two things you can do.1) adjust your trims to center the heli.If that doesn't work go into your sub-trims and ajust it.If the heli is tilting to the right lets say go into the sub-trim and adjust the aileron to the left a bit till it straightens up.same thing goes for too much forward, backwards.If the heli is going too much one way subtrim it the other way.Like a weight scale to ballance the trays.
For the d?r set it to 50% and use the aileron switch.The reason for the aileron switch is because near the throttle is not used AS much as the aileron or elevator
helifreak1 is offline Find More Posts by helifreak1
Old Sep 06, 2012, 07:16 PM
An Ordinary User
Joined Jan 2011
Agreed. I have more than 10 models but no hobby money at the moment.
Old Sep 07, 2012, 09:06 AM
medic45's Avatar
Joined Jul 2012
OK so here is the deal. I took the 120 out on her out side maiden flight. I dont think that Helis are for me..lol I was trying to turn it around and having some issues with using this crazy left thumb for rudder control WHAM BAM SMACK Dang it. broke a main blade. So no she sits in the box while I debate ordering some more blades or selling her off and getting another plane. I really am wanting to do the Heli thing since basically it doesnt take up much room and Im not having to drive to the local club an hour away. But Its driving me NUTS.... I use Phoenix and can fly fairly well or at least i think i can on the larger 450's but even in there the 120 gives me fits ALOT of crashes.. Any thoughts or Ideas. FYI no heli trainer CLOSE..
For Sale big heli need gone lol divorce sale mint cond rxrn 600fbl crash8384 Aircraft - Fuel - Helis (FS/W) 0 Jul 17, 2012 05:38 PM
Discussion lol @ thinkgeeks new heli trust416 Micro Ready-to-Fly 11 Mar 31, 2009 06:52 AM
Discussion im a nooob!! 02lincoln On-road Cars 14 Jul 13, 2008 01:05 AM
FS: Heli Max RotoFly (I give up! LOL) Draconious Aircraft - Electric - Helis (FS/W) 13 Sep 25, 2005 11:40 AM
Nooob. Maiden Mode 3 with nose "landing" triumphtotty Beginner Training Area (Aircraft-Electric) 6 Aug 17, 2004 03:23 AM
