Old Aug 27, 2012, 06:29 AM
New Zealand, Auckland
Joined Aug 2009
Question
E-Flite Super Cub 25e Servos
Hey guys,
I apologise if this has been covered before, but I've done a lot of searching and the huge amount of info has me a bit lost.
I'm trying to figure out which servos to buy for my first RC build - the E-Flite Super Cub 25e. In the past i've only owned BnF kits so i'm a bit confused as to what electronics to buy.
The recommended servo is the Spektrum A5030 but most places seem to have no stock plus it's quite expensive here in New Zealand.
Can anyone that's built this plane recommend a servo that will fit in the stock mounts with minimum/no modification of the plane? Would prefer to buy from Hobby King or Amain.
Any info really appreciated. Cheers!
UnitedWeFall is offline Find More Posts by UnitedWeFall
Old Aug 29, 2012, 03:03 PM
Joined Aug 2009
Anyone?
Old Aug 29, 2012, 06:56 PM
Lusby, MD 20657
Joined Mar 2001
Did you review Super Cub thread, you might find your answers there.
pdansalvish is offline Find More Posts by pdansalvish
Old Aug 30, 2012, 01:28 AM
M.Huerta's Avatar
Gilbert, AZ
Joined Jun 2008
Originally Posted by UnitedWeFall View Post
Hey guys,
Hitec 225mg or regular. Only mod is you have to cut the frame for the wing servo mounts, takes about 10 seconds though and is no big deal.
M.Huerta is offline Find More Posts by M.Huerta
Old Jan 01, 2013, 12:19 PM
Joined Feb 2012
Hey guys,
I used Eagle E381 torque 4.1 kg-cm
Speed 0.22 sec/60deg
weight 22.5g
Size: L32.9mm x W14.7mm x H26.1mm
Voltage 4.8v
They fit perfectly.
DaveClaxton is offline Find More Posts by DaveClaxton
Discussion My New Bird / E-Flite Super Cub 25e arf Platinum Series. freechip Scale ARF/RTF 138 Apr 19, 2014 09:01 AM
Found E-Flite Super Cub 25e ARF Philscho Aircraft - Electric - Airplanes (FS/W) 1 Apr 06, 2012 12:57 PM
Found E-Flite Super Cub 25e CarreraGTSCS Aircraft - Electric - Airplanes (FS/W) 3 Apr 01, 2012 01:12 PM
Sold E-Flite Super Cub 25e LPU SBP Aircraft - Electric - Airplanes (FS/W) 3 Mar 17, 2012 07:05 AM
Wanted E-Flite Super Cub 25e PontiusPilate Aircraft - Electric - Airplanes (FS/W) 4 Mar 04, 2012 02:40 AM
