Old Aug 03, 2012, 03:53 PM
All Thumbs
Joined Jun 2012
Build Log
The Pink Tank: 30 Min Aileron Trainer (Cessna 172)
My first scratch build (second build ever) and I was looking for a quick and easy, slap it together aileron trainer but didnt want to contend with airfoils, hiding electronics, detailed fuse builds and whatnot, as experience with my first model, a "beginner's" 3D kit indicated flight times above 2 minutes seemed highly unlikely... Enter the Pink Tank.
I used a scale drawing of a Cessna 172 as a dimensions reference and went to town creating something similar--quite convinced this brick-like creature more than likely would not fly without an airfoil... But boy I was wrong!
It aint the prettiest bird out there, but it can be built QUICKLY and CHEAPLY as it has no carbon, bamboo or fiberglass. Just some pink foam, 8” of dowel rod, a couple of pieces of balsa and some packing tape.
[IMG][/IMG]
I didnt bother running wing supports to the fuse either, as I didnt really expect this thing to fly, but surprisingly enough, it flies great, AND it hasnt needed them… As you can see in the photo above, covering the wing spars and electronic wires with packing tape on the underside of the wing created a subtle downward arch to offset wing load…
The elevator was originally connected by just a balsa strip along the leading edge of each half of the control surface, but it broke on its first flight. So now, reinforcement is provided along the trailing edge with a dowel rod. Cut a small V halfway through the dowel and “bend” it to a tail matching angle. Add thin CA to the bend and affix the dowel to some carved out grooves in foam along the trailing edge of the elevator halves and VOILA!
[/IMG]
The fuselage is a solid chunk of 1.5” foam, with compartments carved out to flush mount and secure the electronics
[/IMG]
[IMG][/IMG]
The solid 1.5" foam fuselage can really take some hits and this flat-winged brick is actually pretty stable in gusty/stronger winds too
but dont get over-confident.
We actually lost her in a huge overgrown field when some pretty strong winds took it. Plane was stable enough to control and she maintained great airspeed, but negative ground speed kept pulling her farther and farther away...440 yards away, actually. We didnt find her until the next day during our second search, which, being hooked to the Rx for so long, killed one of the LiPo Cells in my 3s pack.
Otherwise, aside from missing a rubberband, the plane was still in perfect shape! Nonetheless I learned a big lesson about respecting the power of the wind, no matter how docile a plane can be
SO I TOTALLY REALIZE THIS IS A VERY UGLY, BASIC, NO-FRILLS PLANE; that was the whole idea when I set out to build it. But if you’re looking for an easy to build aileron trainer, this turned out to be a really sturdy, great flying plane! In the end, if there’s any communal interest in recreating this slap-together aileron trainer, let me know and I’ll happily create and post some plans for folks.
If not, no offense taken. I’m just an RC newbie with a success story I wanted to share. Thanks for reading! I am going to try to get a video up here in the next day or two.
Technical Data:
Wingspan: 44” (which is slightly larger than scale)
Fuselage: 33”
Weight 14.6 Oz (includes plane + electronics + battery):
Channel: 4
Motor: Grayson Hobby 2208-17 (1100KV)
ESC: 18A
Prop: 9x5 (works well with 3s pack, but requires constant >85% throttle on 2s pack)
Flight Video:
Flight Video (3 min 52 sec)
tripn4days is offline Find More Posts by tripn4days
Old Aug 03, 2012, 04:04 PM
If I build it, it will fly
United States, NY, East Rochester
Joined Jan 2012
What's the wing chord? Looks like a fun quickie. I'm still tinkering with foam cutting but this looks like a much easier alt lol.
~psguardian
psguardian is offline Find More Posts by psguardian
Old Aug 03, 2012, 04:07 PM
All Thumbs
Joined Jun 2012
~psguardian
It's about as simple as physics will allow, I think... The wing chord at center is 7.25"
Old Aug 03, 2012, 06:06 PM
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Congratulations on your Pink Tank. It's very cool. Well done!
I think I'm going to bookmark this thread and use it for motivation the next time I start sweating the details of a new scratch project.
I'm looking forward to a video!
Gary Warner is offline Find More Posts by Gary Warner
Old Aug 03, 2012, 11:44 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
Are these the rough dimensions? I used the given wingspan to set the units of measure on a 3-view I had on file...
(I set the dimension call-out precision to 1 to avoid fractional addition issues)
Also, what's the wing thickness? Looks like 3/4" but I can't be sure.
Old Aug 04, 2012, 01:25 AM
All Thumbs
Joined Jun 2012
My guess is your version will be much more accurate. That would be a pretty cool program to have! I essentially did the same thing you did, but did it the old fashion way, with a ruler, some scaled math and lots of eyeballing. I wasn't too concerned with matching the exact dimensions of the fuselage silhouette, but paid more attention to wing, elevator, and rudder measurements, trying to keep similar proportions while adding just a bit of extra surface to wings and elevator.
I'm sure your diagrammed dimensions would work just as well, but if you want my "exact plans", I could certainly draw them up.
Everything except the fuselage is 1/2" foam
My Dimensions:
Wing chord at the center 7.25"
Ailerons are 9.5" x 2"
Tapered ends of wings run 10.5" from the tip
Elevator (symmetrical) is 16" x 5.5" with 3.5" tips and 2.5" control surface
Rudder is 6" tall with 3" up top and 1.5" control surface (although I would increase the control surface a bit if I were to build another one)
Old Aug 04, 2012, 02:13 AM
York Electronics
Dallas Tx USA
Joined Apr 1999
I have plenty of 2" and 3/4" board (blue, but the same in strength and weight). For 1/2" I'll have to cut down some with a hot wire.
Also, the fins and wing look closer to 1" thick. Is the fuselage still 2" thick or was it thinned? It was the relationship between the fuselage and fin in the pictures that made the fin and wing look thicker than 1/2".
Old Aug 04, 2012, 02:30 AM
All Thumbs
Joined Jun 2012
Just use the 3/4" blue then. I'm sure it'll be fine if you have a decent motor. With the 1/2" foam AUW was only 14.6 Oz. With the blue, you'll probably come in at 17 Oz tops
**CORRECTION** Fuselage is, indeed, 1.5" foam NOT 2" foam . . . Sorry for the mix up
Old Aug 05, 2012, 08:54 PM
joshgluck's Avatar
United States, NJ, Middletown
Joined May 2012
Looks awesome. What did you use to make your cuts? They look really clean.
joshgluck is offline Find More Posts by joshgluck
Old Aug 05, 2012, 09:16 PM
All Thumbs
Joined Jun 2012
Thanks. I just use a razor blade...
Old Aug 06, 2012, 10:08 PM
All Thumbs
Joined Jun 2012
Alright! Mother Nature finally chilled with her non-stop Great Lakes winds for a minute. She graced us with some calmer breezes to fly in! I'm kind of new to flying, so my turns arent picture perfect yet... I'm working on it
Sorry for the shaky camera moments here and there. It was my son's first try at videography
Do the birds fly up on any else's planes?
Every time I fly this thing I get a whole ton of birds swarming around her, checking it out. It's pretty comical. I think they're just curious. Once in a while I'll turn and chase them, which you'd think would scare them off, but they're WAY more agile and it's kind of turned into a game of sort. It's weird.
Anyways, here's the video I promised... ENJOY!
You gotta love all the ambient sounds... Trains, diesel trucks, my cat, the wife telling me, "Do a flip!" . . . "Barrel roll it!"
Old Aug 06, 2012, 10:30 PM
York Electronics
Dallas Tx USA
Joined Apr 1999
She sure does fly... no doubt about that. Looks very relaxing and comfortable too. Yup, I need to add this one to my list.
Old Aug 07, 2012, 12:50 PM
All Thumbs
Joined Jun 2012
Yeah, who knew?!
Old Aug 07, 2012, 10:19 PM
It's Just Foam!!!
EZglider's Avatar
Canton,Ga
Joined Apr 2010
Congrats on a nice-flyin' plane! You essentially captured the heart of scratch-building to me with this Pink Tank. You knew what you wanted it to do, you used available components, and you designed and built your own flyer! That's what makes this stuff so cool to me. Again, congratulations.
EZglider is offline Find More Posts by EZglider
Old May 01, 2014, 08:23 PM
All Thumbs
Joined Jun 2012
Pink Tank v2.0
Well, i got bored this spring and was itching to fly something, so my pink tank was sitting there with a busted up, yet fixable nose. But rather than fix it I decided why not just build another one real quick?
Well, sometimes real quick becomes a 3 hr project... but i figured if im gonna do it a 2nd time, why not up the aesthetics a bit?
So i reused the wing rudder and elevator, taped them up to look purdy and went flying the next day...
Flew fine but it turns out that tape and an extra 1/2 " thick foam on the fuse can really add some weight! (Duh!) Only way to keep afloat was with full throttle.
So that wasnt gonna work, and i wound up building a new wing "real quick"
Well, sometimes real quick becomes 3 hrs and the next thing i knew i was hand sanding a Clark Y inspired airfoil into the thing...
Long story short though it would seem 35% more surface area and an actual air foil can do wonders for a plane! LoL
Now she glides just like she used to while looking the part a bit better
Sold Profile foamy trainer cessna 172 dr rc Aircraft - Electric - Airplanes (FS/W) 4 May 20, 2011 12:49 PM
Sold Profile foamy trainer cessna 172 dr rc Aircraft - Electric - Airplanes (FS/W) 9 May 18, 2011 01:01 PM
Discussion TM Pro Cessna 172 - Aileron Connection calvin74 Electric Plane Talk 3 Jul 29, 2009 02:31 PM
Discussion Cessna 172 Aileron Trainer miatafreak Parkflyers 1 Jan 18, 2009 10:28 PM
Discussion Depron Cessna 172 Skyhawk "trainer" RegionRC Foamies (Scratchbuilt) 27 May 13, 2007 06:13 AM
