Old Mar 04, 2013, 06:16 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
Yes, that's what my early CX's look like.
2Doggs is online now Find More Posts by 2Doggs
Latest blog entry: Nano Tech 1800mah 4S 25-50c
Old Mar 04, 2013, 06:55 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Oh good! Hooray for flashing!
tonyastro is offline Find More Posts by tonyastro
Old Mar 04, 2013, 07:44 PM
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
That's how mine looks too but the LEDs don't light up and it doesn't initialize when I flash it with ZYX 3.5.
GooberSB is online now Find More Posts by GooberSB
Old Mar 04, 2013, 08:02 PM
2Doggs's Avatar
Joined Nov 2009
When you try to flash it, give it loads of time to complete - mine took ages.
Old Mar 04, 2013, 08:27 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Mine took about 45 secs then it wasn't compatible with the cx software anymore. Haven't flown it yet but all controls and gyro compensation seem to work perfectly.
Old Mar 05, 2013, 12:26 AM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Is it ok to upgrade the CX gyro to zyx 3.5 firmware? I heard it doesn't work well.
Old Mar 05, 2013, 05:27 AM
Chris
The Netherlands, NB, Eindhoven
Joined Sep 2010
Originally Posted by fishfiend View Post
The newer ones have longer leads and an aluminum bevelled edge on the blue cover on top. Whereas the older ones have a blue only top cover and shorter leads .
Here's mine. Got it from Ehirobo 17-Oct-12 (oops, I thought it was 2011..)
Leads are about 150mm.
I guess this is the new one. Can someone post their "old", flashable one?
Then everyone that has succeeded/failed to flash theirs can say which one they have, so we can identify the pattern and whether it's consistent.
cmavr8 is offline Find More Posts by cmavr8
Old Mar 05, 2013, 11:33 AM
2Doggs's Avatar
Joined Nov 2009
Bevel's and leads
Both of my CX's are early versions.
At the moment, I have one cross-flashed with Tarot V3.5 firmware. That one has a 1.5mm wide silver bevel around the top edge of the case, and 120mm leads (end of case to end of connector) Either side of the bevel, there is a darker blue band.
The other one has a narrower bevel - it looks to be about 1mm (again measured in the plane of the bevel) Otherwise, it's identical to the other one. I've yet to try cross-flashing it, having been using it as a reference against the cross-flashed one, but I may try the cross-flash.
Old Mar 05, 2013, 02:02 PM
Dr.M's Avatar
United States, WA, Issaquah
Joined May 2011
AFAIK, there's no way to tell if the CX will cross flash to ZYX just by looking at it. Try it and see if it works. If not, flash it back to the CX v1 firmware.
Dr.M is offline Find More Posts by Dr.M
Old Mar 05, 2013, 02:56 PM
2Doggs's Avatar
Joined Nov 2009
You're probably right. Closer inspection of my two CX's reveals an inconsistent bevel width rather than a clear difference between the two units.
I do firmly believe that most, if not all the trouble people reported with the CX when it came out - like mysterious reversals of collective and so on, were caused by the hidden "conditions" feature which was always present. Using John_NZ FBL V1.22, there's a very useful "compare conditions" screen (Tools>Compare Conditions) which highlights any settings which differ between the two conditions in yellow. Loading my old, pre-conditions setting .ini files, it's clear that the CX (and presumably the ZYX) had the F3C settings loaded in the then hidden condition 2. Anyone using a negative value of collective range could then see a collective reversal if the unit booted up into condition 2.
In the attached .png image, for example, I used a value of -76 for collective range, (13mm servo arms and RJX head) along with modified parameters from the "3D Extreme" model. The default value in condition 2 was +70.
So my recommendation would be to use the equally useful "Copy Condition" function in the V1.22 software to copy your condition 1 values into condition 2, even if you are not using the conditions switching feature.
Old Mar 05, 2013, 05:27 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Deleted
Old Mar 06, 2013, 07:59 AM
Chris
Joined Sep 2010
Originally Posted by tonyastro View Post
For the first time in 2 years my CX 250 hovered so well... Then the boom support came loose and was hanging by the boom so I couldn't land. Hit TH and tried to land but tipped over and dug into the grass Not much damage but the screw that fastens the mixing arm into the hub snapped again! This is the second head that will go to waste just because of a screw! No one sells just the hub alone, you have to buy the whole head! And this right after loctiting everything except the boom support screw that goes into the plastic base. Isn't there a screw extractor small enough for this?
This is the wrong thread for this kind of (heli-specific, hardware) questions...
Old Mar 06, 2013, 07:16 PM
SoCal
Zr_Flyer's Avatar
Joined Oct 2011
The other ones look like this
Zr_Flyer is offline Find More Posts by Zr_Flyer
Latest blog entry: Micro Brushless H Part III
Old Mar 06, 2013, 07:22 PM
2Doggs's Avatar
Joined Nov 2009
so it's the blue bevel that's the distinguishing mark.
and that reminds me - I must try using a capacitor hooked up to my RX!
Old Mar 06, 2013, 09:16 PM
Dr.M's Avatar
Joined May 2011
I have a blue edge and silver edge CX gyros both xflashed to zyx.
Sold Darthdrk Drone CX Body for coax helis like the Blade CX etc. Twmaster Aircraft - Electric - Helis (FS/W) 0 Oct 08, 2011 08:31 PM
Multiplex mc V2 servo programming PC software Thomas B Radios 3 Jul 23, 2006 10:49 AM
