Old Jun 25, 2003, 03:33 PM
mars's Avatar
San Francisco, CA
Joined Jan 2002
Funcraft P-51 KP-00 Prop Help!
Hi All,
I have a converted Funcraft P-51 with a KP-00 in the pointy end with a U80 prop. The AUW is 1.1-1.2oz.
I launch the thing and it wallows for a while and then sinks to the ground. It looks to me that I am not getting enough thrust to climb. As the plane wallows I have elevator and aileron response, it just will not climb or even stay in level flight for long.
My first reaction is to put a bigger prop on the motor I have. Do you think this will help? I can only pull 1A as I am using the RFFS-100 and a 145Mah Lipo. Will a GWS 4.5x4 be too much for this motor? My gearing is the stock KP-00 set-up.
If a new prop is unfeasible, do you think a LV m-20 with a different ratio might do the trick? I also have a DC5-2.4 geared 5:1 sitting around but I do not think it will work well on a single Lipo.
Please help!!!
Thanks you in advance,
Mars
mars is offline Find More Posts by mars
Old Jun 25, 2003, 04:48 PM
AMA 697691
Rochester, NY, USA
Joined Aug 2000
Yes, you are on the right track.
A higher gear ratio and a larger prop are needed.
DWE or somebody sells a Didel gearbox that should work better. They also make a higher ratio KP-00 motor. Perhaps Sky Hooks sells it.
The little P-51 needs more speed to keep aloft.
Good luck!
Greg Covey is offline Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jun 25, 2003, 05:01 PM
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
The KP-00 and U-80 should be enough to fly one of these. A heavy Spicy Wing is about the same weight and wing area, and they fly great at reduced throttle...
It sounds like you may not be getting up to flying speed. Try a harder launch (they do need to go pretty quick to really fly). If you can't get it up on the step with the U-80. you might try to locate a KP 2-bladed adjustable prop - these generate more poop, and you can adjust the pitch to give a little more speed to the plane... I've got some and they are better performers. I got mine from Tony at T & A Hobby Lobby (3512 W. Victory Blvd., Burbank, CA 91505 - (818)842-5062).
Are you running it with the supplied foam spinner? That cuts into the blades a fair amount. The KP adjustable prop would give a little more blade area outside the spinner. If you are running the spinner, make sure that everything is centered and in balance - any out of balance here will add more friction to the bearings and may cut into the performance...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Jun 25, 2003, 05:07 PM
mars's Avatar
San Francisco, CA
Joined Jan 2002
thanks greg & mike
I am running the spinner and it is out of wack by a little bit. I will remove it and see if that helps.
I am giving the little plane what seems to me like a good push, but I will push a little harder on the next try.
I'll let you know how it goes w/o the spinner.
Mars
Old Jun 25, 2003, 05:38 PM
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
Mars,
If that doesn't work you may want to try the 4:1 gearbox that Bob Selman has. It seems to produce more thrust at the same current.
Regards,
Dan Hurd
DWE
dhurd is offline Find More Posts by dhurd
Old Jun 25, 2003, 07:15 PM
Dan Leonard's Avatar
Lenexa KS USA
Joined Jun 2001
Dan
I agree with using the Kenway M-20 gear box from Bob Selman. It's funny that this came up today as I just finished putting one in my P-51 last night and it fits great with room to spare. With a little creative mounting I didn't even have to cut it open. The 10 cm prop sticks out plenty far. I haven't tried to fly it yet but I have one on another plane and it feels like it has about double the thrust of the KP-00. Best part is nice and smooth and quiet. I'll post a picture later.
Dan
Dan Leonard is offline Find More Posts by Dan Leonard
Old Jun 25, 2003, 08:53 PM
mars's Avatar
San Francisco, CA
Joined Jan 2002
Thanks guys
Dan, I'd love to see a picture when you get a chance.
Mars
Old Jun 26, 2003, 12:00 AM
Brentwood,TN
Joined Mar 2001
I am using the kenway gear set (homemade) with a gws 4.5x4.0 on M-20 motor, and it flies with authority. Really no power problems. It even loops. Dan, if you get a chance post those vids of inflight. I think the m-20 and kenway gears work very well.
jhas is online now Find More Posts by jhas
Old Jun 26, 2003, 07:57 AM
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
jhas,
Actually they are already there I just haven't created a link to them yet. but here is a direct link
Video One
Video Two
Video three
Video Four
Regards,
Dan
Old Jun 26, 2003, 10:26 AM
Team 30 Micro EDF
Joined Apr 2002
Dan, the last link is bad...
Old Jun 26, 2003, 10:51 AM
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
Sorry,
It should work now.
Dan
Old Jun 26, 2003, 01:34 PM
Team 30 Micro EDF
Joined Apr 2002
Yep, that's all better now...
Old Jun 27, 2003, 10:47 AM
bselman's Avatar
sw missouri
Joined Sep 2001
Another Prop Suggestion
Another thing to consider --- The GWS 0303 prop does an excellent job on the KP-00 with the 2.67:1 gearing. I'm using them now instead of the U-80 and get a noticable increase in performance.
The shaft needs some shimming to get a good friction fit. I use wire insulation or heat shrink tubing.
Bob
bselman is offline Find More Posts by bselman
Old Jun 27, 2003, 11:10 AM
Team 30 Micro EDF
Joined Apr 2002
Bob,
Have you checked the current draw with that combo by any chance? Does it warm the motor up very much? If it is not too much load for the motor/gears, I may have to snag one for a CF copy...
Old Jun 27, 2003, 11:30 AM
bselman's Avatar
sw missouri
Joined Sep 2001
Current draw?
Mike,
I haven't measured it. I'm sure it is much higher though because the increased performance doesn't come for free. My best guess is that it is a little over 1 amp at full throttle on the RFFS-100 and the 145 lipoly cell. I don't use full throttle very much because the speed builds quickly on my SLW (Gary Jones design). But the extra power is very nice for loops and when you get in trouble. The RFFS-100 handles the power with no problems and the KP-00 doesn't get hot.
Bob
Discussion Hangar 9 P-51 PTS battery setup help!! aznsupremacy Glow to Electric Conversions 7 Jul 14, 2007 05:45 PM
JEPE P-51 ROTO FINISH " help" stonewall Scale Kit/Scratch Built 7 Oct 29, 2004 10:32 PM
P-51 4 bladed prop simituff Parkflyers 0 Feb 19, 2004 10:20 AM
Wallmart P-51 Meets RFFS-100 Help? Rocketman209 Scratchbuilt Indoor and Micro Models 9 Feb 18, 2003 11:30 PM
Funcraft P-51 Conversion Greg Covey Scratchbuilt Indoor and Micro Models 87 Dec 21, 2002 07:13 PM
