Old Dec 02, 2014, 07:21 AM
Don't Panic!
GavDorro's Avatar
Australia, WA, Baldivis
Joined Jul 2011
Originally Posted by RCBlackSheep View Post
Update on the tail wheel.... I found that the brass collar was turning around inside the plastic arm. It was holding until it got a good bump and then it would hold in that (wrong) position until it was bumped good again. Grrrrr! That would explain why it taxied straight but turned on me on take off and landing and correcting didn't have the effect like I expected.Those of you that are using the stock arm may want to replace it with an all aluminum or at least replace the tiny set screw with a longer one to brace against the plastic. I happened to have a replacement arm that has a hex shaped collar inside the plastic arm and I still added the longer 3mm screw for good measure. I also found that the top end of the wheel wire was moving a 1/4" forward and back causing the wheel alignment itself to offset. So I firmed that up with some plywood and drilled a hole to accept and hold the top of the wire in place.
My advice... don't use the stock arm. Replace it.
As far as torque from the motor, I'm sure there is some and I will know more how the plane acts from it with more flights.
Looks like a good fix.
I just keep nursing mine....Mainly cause I'm too lazy!
GavDorro is offline Find More Posts by GavDorro
Old Dec 04, 2014, 02:48 AM
I'd Rather Be Flying
RCBlackSheep's Avatar
Stockton CA
Joined Feb 2009
Thanks Gav. I'm hoping my fix will hold up good. Unfortunately I wont be flying it soon to know. The rainy season has started here and the weatherman says its going to continue for a few days. Its even stalled my plans to airbrush some details on her due to the humidity. Its ok... I'm in California. It cant rain forever.
RCBlackSheep is offline Find More Posts by RCBlackSheep
Old Dec 04, 2014, 10:16 AM
Yep! I'm addicted.....
mash76's Avatar
United States, AZ, Mesa
Joined Mar 2012
Your rain moved over to Az, we're getting it now. But we could use a little so I won't complain.
mash76 is online now Find More Posts by mash76
Old Dec 13, 2014, 07:58 PM
Stockton CA
Joined Feb 2009
Finally got the details done. For now... I'll add more later. Exhaust, antenna, guns, checkered the tail and clear coated the decals.
Maybe Santa will bring me a 4 blade prop.
Old Dec 16, 2014, 09:42 AM
Don't Panic!
GavDorro's Avatar
Joined Jul 2011
That looks VERY nice.
Good job BlackSheep!
Inspires me to get my detail finished.....
Old Dec 16, 2014, 09:43 AM
Don't Panic!
GavDorro's Avatar
Joined Jul 2011
Stickers arrived.
**Update for Mash.
Got the sticker set in the mail yesterday.
Thanks once again...
Now no excuses to delay the finishing touches to mine....
Another job for the (too short) Xmas break
Old Dec 17, 2014, 08:30 PM
Stockton CA
Joined Feb 2009
Thank you Gav. I downloaded a bunch of pics of the real Excalibur to try and get as much detail as possible but the owner of the real one keeps his pretty clean so there wasn't much wear and tear to detail. Still had fun.
Old Dec 17, 2014, 11:41 PM
mash76's Avatar
Joined Mar 2012
Cool, I've gone just got back was wondering if they got there ok
Discussion NEW Top Flite P-51 Mustang 60 ARF MUTID Fuel Warbirds 10 May 11, 2009 11:29 PM
Discussion Hangar-9 P-51 Mustang PTS ARF dfruehwald Electric Warbirds 8 Mar 21, 2009 10:55 PM
Discussion Hangar 9 P-51 Mustang PTS ARF - Recommendations sandydr Fuel Warbirds 27 May 27, 2008 10:43 AM
Sold Hangar 9 P-51 Mustang PTS FUSELAGE ARF rcfunhouse Aircraft - Fuel - Airplanes (FS/W) 0 Mar 30, 2008 01:57 AM
For Sale F/S Hangar 9 P-51 Mustang 60 size electrified (Airframe Only) LOCAL PICKUP Aobid Aircraft - Electric - Airplanes (FS/W) 12 Jun 24, 2006 09:07 PM
