Old Oct 24, 2011, 04:58 PM
Love the sticks
JCFLYR's Avatar
Mason, Michigan
Joined Nov 2009
New to DSM.....hooking up R921 question.
I am hooking up an R921 rx and I noticed two battery ports. 1=bat/bind and 2=bat/data. I am only going to use one port, I think, for the battery but I also would like to set up two external ports for binding and data checking so I can either rebind or check signal losses after my flights without disconecting everything to do this. I was told to run y cords but how exactly would this be done? Do I y cord off of the rx switch to the rx with one end of the y cord going to rx bat/data port and the other end to my external jack and I can check data that way? If I connect the battery to the bat/bind port instead and y cord that to an external jack, can I rebind thru the external jack if necessary with power going to the receiver from the other end of that y cord? Thanks for the help guys, JC
JCFLYR is offline Find More Posts by JCFLYR
Old Oct 24, 2011, 06:12 PM
58 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Battery can be connected anywhere you have a spare slot as all +ve and GND pins are in parallel. But if you plug the switch into the Bat/Bind port (and use a 3-wire switch) you can then re-bind using the bind/charge connector. That leaves you the data port free to plug in the recorder. No Y-cable necessary.
Daedalus66 is offline Find More Posts by Daedalus66
Latest blog entry: Polaris Aileron Pushrods
Old Oct 25, 2011, 01:59 PM
Bowling Green,Ky
Joined Sep 2004
Plug the Y into the data/battery port of the receiver. Then at any time you can plug in the data logger. You need not rebind unless you move the receiver to a new plane and want to rebind the receiver to it. Once the receiver is bound it stays bound to that one plane.
To rebind the receiver the bind port cannot have a battery plugged into it. This is time you use the other battery port or any open port on the receiver. Dennis
Dadstoysbg is offline Find More Posts by Dadstoysbg
Old Oct 25, 2011, 06:22 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
With Spektrum/JR (unlike other 2.4 radios) you do need to be able to rebind, as binding not only remembers the transmitter and memory slot, but also the throttle failsafe and the initial positions of the servos. So if you do significant reprogramming, you need to re-bind.
When using a receiver battery, the bind port can have the connector from the switch plugged into it. Then binding can be initiated by using the female bind plug on the charge/bind connector of the switch (provided it's a three-wire switch).
Discussion Best method for hooking up linear servos rcjim11 Indoor Pattern/F3P 7 Oct 22, 2011 11:39 AM
Discussion Hooking up 7.5V for roll tilt servos JZSlenker Hoverfly Technologies 5 Sep 23, 2011 10:22 PM
Discussion Help with hooking up ESC + Motor Ruskiflyer Beginner Training Area (Aircraft-Electric) 10 May 30, 2011 05:01 AM
For Sale JR R921 DSM reciever. 9 channel brand new WeazyMan Aircraft - General - Radio Equipment (FS/W) 0 Aug 30, 2010 11:57 AM
Question question on hooking up separates Dorwin Micro Helis 4 Aug 27, 2005 09:29 PM
