Old Nov 03, 2008, 08:41 AM
dazzzer1 is offline
Find More Posts by dazzzer1
Joined Oct 2008
brushless motor help
Hi. I have a wind dragon 2 and would like to upgrade it to brushless, I still want to keep it in the range on a park flyer so I donít want to much power . Im really looking for longer flight time and a more stronger flight.
As im still quite new to the tech side I donít want to do any soldering is this all possible? Ive been looking at E-Flite Park 400 Brushless Outrunner - 920Kv with 20a brushless speed control.
Dose anyone recommend this?
dazzzer1 is offline Find More Posts by dazzzer1
Old Nov 03, 2008, 11:20 AM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
The Park 400 will require a BIG prop. 9-10" SF prop, so it may not be what you are looking for.
A decent setup to use that will definately give you more power would be:
Motor
http://www.hobbycity.com/hobbycity/s..._viewItem.asp?
idProduct=4203&Product_Name=HXT_2040_(130L)_2080kv _Brushless_Inrunner
ESC
http://www.hobbycity.com/hobbycity/s...eed_Controller
Battery
http://www.hobbycity.com/hobbycity/s...0C_Lipoly_Pack
And an APC 6x4 prop. Should provide you with about 10 minutes of flying, and give you more power then you have right now.
Xpress.. is offline Find More Posts by Xpress..
Old Nov 03, 2008, 12:06 PM
dazzzer1 is offline
Joined Oct 2008
your motor you sent didnt come up ? dose this require any soldering>?
Old Nov 03, 2008, 12:40 PM
StealthGod is offline
Find More Posts by StealthGod
Just call me Stealth
StealthGod's Avatar
Canada, BC, Delta
Joined Sep 2008
You can avoid soldering by just using some butt crimp connectors, but I wouldn't recommend it.
Soldering is pretty easy and you can pick up a soldering iron for $20 easily. Is there someone who could teach you?
StealthGod is offline Find More Posts by StealthGod
Old Nov 03, 2008, 12:44 PM
StealthGod's Avatar
Canada, BC, Delta
Joined Sep 2008
Motor
I assume this is what you were trying to link to:
HXT 2040 (130L)
Old Nov 03, 2008, 01:14 PM
Sir Raleigh is offline
Find More Posts by Sir Raleigh
Raleigh, NC
Joined Apr 2007
dazzzer1, check out the Wing Dragon/Wing Dragon 4/Begin-Air Series Planes Tips & Tricks thread. Down near the bottom of post #1 is a list of what others have put on their WD's. Maybe you can find what you're looking for there.
Bill
Sir Raleigh is offline Find More Posts by Sir Raleigh
Old Nov 04, 2008, 06:48 AM
dazzzer1 is offline
Joined Oct 2008
thanks for helping me regarding my wind dragon upgrade. at lot of the mods done in the forms i cant find the parts for in the uk eg- Tower Pro, 2408-21 (BP21), outrunner looks a popular one- so im looking for one as similar as possible . been looking at "E-Flite Park 370 Outrunner, 1360Kv. seems close. do you think or would you Recommend something else .
Old Nov 04, 2008, 04:32 PM
Raleigh, NC
Joined Apr 2007
If you don't have an aversion ordering from HobbyCity, they have this TowerPro BM2408-21T / 18A BEC / 9x3.8 Prop Combo, or similar combos that will work just fine. You'll not be able to use the prop that comes with it, too long, so order some 7x3 - 7x6 slow fly props, too.
Bill
Brushless motor help hover dude Micro Helis 0 Feb 15, 2005 03:36 PM
Help! Combat Wings XE2 Brushless Motor Help Please Joe Elston Foamies (Kits) 11 Dec 14, 2004 10:31 AM
brushless motor help n001pa Power Systems 9 Feb 17, 2004 12:39 PM
build brushless motor help!!! fraser12 Aircraft - Electric - Airplanes (FS/W) 1 Dec 19, 2002 05:29 AM
