Old May 23, 2001, 09:18 PM
dale331 is offline
Find More Posts by dale331
Trenton, NJ
Joined May 2001
Flash 5X deal or steal
I'm new to R/C planes and am just getting a radio. From reading posts and talking with people I decided on the Hitec Flash 5X. I was getting it from Tower when their new catalog came. What used to be a $10 difference between the 5X with 4 hs422 and a 600mAh Rx battery and the 5X glider with 3 hs81 and a 270mAh Rx battery is now $30. Since I plan on flying mostly gliders and a only some electric would the larger servos and battery likely end up collecting dust if I went with the regular 5X instead of the glider version?
dale331 is offline Find More Posts by dale331
Old May 24, 2001, 02:25 AM
Rod is offline
Rod
Find More Posts by Rod
Rod
Canada, BC, Kelowna
Joined Nov 1999
dale331, In answer to your question they will probably gather a lot of dust before you have to use them.I have a dozen regular size Futaba servos (new - never been run). When I bought my first Flash 5X I bought the Glider version with HS-81 servos. I have standardized on HS-81 for most models, HS-55 for Speed 400's, and a few HS-225's thrown in for good measure. Try and standardize on as few types of servos as you can as you should keep a few spare gears on hand for emergency repairs.
Rod is offline Find More Posts by Rod
Old May 24, 2001, 02:34 AM
Balin is offline
Find More Posts by Balin
San Diego, CA. USA
Joined Nov 2000
Totally agree, HS-81's are the way to go even though the package costs a little more.
Balin is offline Find More Posts by Balin
Old May 24, 2001, 02:56 AM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
Definitely get the glider version. The HS-81 servos are the standard that you will use, even in bigger stuff. They have so much power for their size and are very quick. Especially in Electric flight where weight is a killer. That full-size equipment will just sit around.
You will end up saving money by going with the glider version.
Shawn
Eflightpower.com
sf_247 is offline Find More Posts by sf_247
Old May 26, 2001, 10:20 AM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
Hobby Horse will put whatever servos you want with the package for only the difference in price. Very competitive prices. Major hobby is also very competitive in price. I am not sure if they with change out servos though.
JoeR is offline Find More Posts by JoeR
Old May 27, 2001, 01:29 AM
mumboender is offline
Find More Posts by mumboender
Omaha, NE
Joined Apr 2000
I recently gave 10 standard servos to a friend who flies gas and I still have some left-over in the garage.
mumboender is offline Find More Posts by mumboender
Discussion Hitec Flash 5X glitching or range problem help ben_fry2003 Hitec/Multiplex USA 1 Mar 27, 2006 04:21 PM
WTB: Flash 5X Tx or (any 5-6 channel TX) mike93 Aircraft - Electric - Airplanes (FS/W) 0 Sep 09, 2003 06:09 PM
Want to upgrade: Flash 5X or ? Al P Radios 4 Nov 21, 2002 04:04 AM
Want! Hitec Flash 5x Or Eclipse! jocappy Aircraft - Electric - Airplanes (FS/W) 8 Jun 19, 2002 10:44 PM
Question flash 5x or laser 6? which one is better choice. Tim2000 Parkflyers 20 Jan 31, 2002 03:42 PM
