Old Feb 03, 2003, 11:50 AM
gen is offline
gen
Find More Posts by gen
gen
gen's Avatar
Salisbury, Maryland
Joined May 2002
jeti vs hacker master (jeti) for a B40
Is there any quantitive difference between the orange and black Jeti controllers? Using a B40
gen is offline Find More Posts by gen
Old Feb 03, 2003, 02:59 PM
gregg f is online now
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
jeti: fixed timing and frequency modes
hacker master: adjustable timing and frequency modes.
the jeti will work fine. but the h/m you can fine tune for optimal performance............g
gregg f is online now Find More Posts by gregg f
Old Feb 03, 2003, 09:21 PM
Daren is offline
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Jeti also has a new semi-Master controller with I believe two timing modes, but fixed frequency. Personally, given the choice between the semi and the full Master, I'd pick the fully programmable one.
Daren
Daren is offline Find More Posts by Daren
Old Feb 03, 2003, 09:30 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The black Jeti Master is a newer model, and more efficient than the older Jeti white or gold label one (according to Rainer Hacker).
The black one also has a timing mode specifically for the Hacker 2-pole motors (mode 1), while the older red ones have fixed fairly agressive timing best suited for - guess what - Jeti 6-pole motors...
Having said all that in practice the difference is actually quite small and sometimes you can get a good deal on the red ones ...
Herb is offline Find More Posts by Herb
Jeti vs. Hacker Esc krall High Performance 0 May 13, 2005 04:17 PM
WTT hacker C40-8L for B40-8L rcaddition Aircraft - Electric - Airplanes (FS/W) 2 Nov 25, 2004 12:42 PM
CC45 vs Hacker Master 40-B Heli Brushless ESC? msg73 Electric Heli Talk 3 Sep 21, 2004 06:52 AM
Hacker Master timing for AXI Stuey Power Systems 4 May 16, 2003 05:02 AM
Schulze vs Hacker Master 40 3P for Logo 10 jdowdle Electric Heli Talk 11 Jan 01, 2003 08:11 PM
