Old Jun 11, 2008, 10:16 AM
nexgen is online now
Find More Posts by nexgen
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
12V adapter to power Lipo charger
Does anybody know if either of these 2 items would be sufficient for powering a Lipo charger? If so, It looks like it would be a cheap easy way to power them, and cleaner looking than a PC power supply
AC to DC portable Adapter
500mA AC to 12VDC Adapter
nexgen is online now Find More Posts by nexgen
Old Jun 11, 2008, 01:07 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
Neither is of much use in charging motor batteries. Current for the first is unknown and only 500 mA for the second.
Bill
ebill3 is offline Find More Posts by ebill3
Old Jun 11, 2008, 01:34 PM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
NO, not for FAST CHARGING
hall woo is offline Find More Posts by hall woo
Old Jun 12, 2008, 03:41 AM
kgfly is offline
Find More Posts by kgfly
Melbourne, Australia
Joined May 2006
Nope, way too low powered. If you want to go that route rather than a proper bench DC supply then consider a 12V 90W laptop/LCD supply from ebay for the same $20. A 90W supply will run most entry level 50W output chargers like for example the Cellpro4S, Bantam BC6 etc.
kgfly is offline Find More Posts by kgfly
Old Jun 17, 2008, 03:43 PM
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
Thanks for the update. I have been looking, and it seems the cheapest way to go is with a spare P4 PC power supply, can use the 12v connections for the motherboard (4 pin plug) to power directly with no other mods.
Old Jun 17, 2008, 04:53 PM
kgfly is offline
Joined May 2006
Most PC power supplies do require some adjustments to work. A loopback from GND to the 5VSENS signal to allow it to turn on and about a %W-10W load on the 5V output so it will regulate properly. Do a search there are lots of threads here and pages out on the web on converting a PC power supply.
Wanted Thunder power lipo charger...TP-425 kirbster Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 20, 2006 09:17 PM
Wanted AC Power adapter for DC Lipo Charger qualcity Aircraft - Electric - Airplanes (FS/W) 1 Sep 16, 2005 12:30 PM
Question PC power supply to power lipo charger question Willard Batteries and Chargers 16 Jul 26, 2005 08:12 PM
12v/700a fry a LiPo charger? QuazBotch Batteries and Chargers 3 Jul 24, 2005 06:32 PM
thunder power lipo charger gr8johnson3 Batteries and Chargers 0 Jan 08, 2004 05:56 AM
