This thread is privately moderated by RAY GWS, who may elect to delete unwanted replies.
Old Oct 08, 2013, 09:09 PM
jamesdr is offline
Find More Posts by jamesdr
Unrepentant Carnivore
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
Try changing the servo leads to the receiver. You may have to reverse the servo aft the transmitter to get the control surfaces to move correctly. Up and down look normal, right aileron makes the trailing edge of the right elevon go up, and the left elevon go down.
Jim
jamesdr is offline Find More Posts by jamesdr
Old Oct 09, 2013, 06:55 PM
Pdr1966 is offline
Find More Posts by Pdr1966
Canada, ON, Toronto
Joined Oct 2012
Spektrum rx is ok
Works properly for elevons, same tx setup.
So appears something fishy about the orange rx, will look into further an post back results.
Pete
Pdr1966 is offline Find More Posts by Pdr1966
Old Oct 10, 2013, 10:37 AM
Pdr1966 is offline
Canada, ON, Toronto
Joined Oct 2012
Receiver
OK
This morning I confirmed that my regular spectrum receiver works properly with one servo in Aileron, and one in elevator and TX set for Delta.
The ORANGE Receiver with Stabilization (new one) Works ok when its switch is set to regular (non delta), and the stabilization reaction is correct for a NORMAL setup - in this case elevator only and one elevon move.
When I set the switch to delta, the stabilization reaction is correct both respond to elevator correction, and correctly respond to roll correction, but the regular inputs from the stick move one servo only, no matter what you do.
Going to search this on the receiver form.
PR
Old Oct 10, 2013, 10:46 AM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
Try a different Orange RX. They all work fine for me. I think you have a bad RX.
denial15 is offline Find More Posts by denial15
Old Oct 10, 2013, 04:38 PM
2RK is offline
2RK
Find More Posts by 2RK
2RK
United Kingdom, England, Hampshire
Joined Jun 2011
When you set the stabilization board to a delta you don't have to set your transmitter to delta, too. Either the stabilizer does the mixing or the transmitter does, but not both. Otherwise you'll get some funny results. To get a stabilized delta mix, set the stabilizer on delta and the transmitter on normal.
2RK is offline Find More Posts by 2RK
Old Oct 10, 2013, 09:01 PM
Pdr1966 is offline
Canada, ON, Toronto
Joined Oct 2012
The winner is....2RK
Thanks, you are correct, I set receiver to delta,as it would need too be this way to implement corrections, and set my DX7 back to normal wing, two servo ailerons.
all responds correctly now!
Just have to go over my esc programming and am ready to glue up the fuselage.
Peter
Old Oct 10, 2013, 09:55 PM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Peter
That's strange it would work with one RX, but not with another.
Old Oct 11, 2013, 04:22 AM
2RK is offline
2RK
2RK
Joined Jun 2011
@Pdr1966 - You're welcome. Glad to have helped.
@denial15 - Not really. Pdr1966 has 2 receivers ... one a regular Spektrum receiver and the other an Orange receiver with a built-in 3-axis stabilizer and a built-in delta wing mixer. As expected, the Spektrum RX works ok on delta with the transmitter doing the mixing. The problem with the Orange RX is that it's mixing the elevator and aileron signal inputs for a delta wing, expecting the inputs from the transmitter to be separate elevator and aileron signals. But he already had his transmitter sending mixed elevator and aileron signals. Just a small overlook that can make anyone scratch his head
Old Oct 11, 2013, 10:37 AM
denial15 is offline
swede
denial15's Avatar
Joined Aug 2005
Got it. I thought it was a standard Orange RX. Yeah, I can see that one making a difference.
Old Oct 11, 2013, 05:45 PM
jamesdr is offline
jamesdr's Avatar
Brandon, Fl
Joined Mar 2005
F-15 flying
Got two nice flights in today, had the camera on board for both and it worked fine. Landings were fine but managed to screw-up the roll out on both. The first time I went a little long and then couldn't stop/turn in time before I hit the grass overrun. The second landing I drifted right and couldn't correct, off into the grass again. One thing I know about my plane, there is relatively little static weight on the nose wheel - which is fine unless you have a head of steam going and then the nose wheel steering is pretty ineffective. And with no functioning rudders - it's point and GO!
Anyway - here's to better landings!
F 15 1 (5 min 29 sec)
F 15 2 (5 min 43 sec)
Jim
Discussion GWS F-15......The Eagle has landed!!!! skyhawk Foamy EDFs 1269 Dec 20, 2015 08:33 PM
Discussion gws 15 Eagle bob2005 Product Announcements 0 Aug 03, 2007 07:37 PM
Video Gws F-15...DON'T BUY IT tailslide5_0 Electric Plane Talk 47 Jun 24, 2007 10:18 PM
New Product ****GWS-15: The Eagle Strikes Again**** RAY GWS Product Announcements 7 Jun 24, 2007 06:31 AM
eflightpower.com strikes again tic Vendor Talk 6 Apr 29, 2002 08:17 PM
