Old Sep 03, 2015, 11:56 AM
leadpan is online now
Find More Posts by leadpan
leadpan's Avatar
United States, CA, Eastvale
Joined Sep 2007
Help!
stab holes in fuselage uneven
Hope this is correct forum to ask.
I got this balsa ARF kit and all looks okay except the holes for stab on fuselage is uneven.
Can this be fixed? Do I use an Xacto knife to cut bigger hole on one side? Or do I Dremel the hole?
leadpan is online now Find More Posts by leadpan
Old Sep 03, 2015, 12:52 PM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Kinda looks like the whole tail may be twisted. Loos like the horizontal stab and fin are square to each other.
Can you heat the covering while twisting the tail in opposite direction and see if it straightens it out? Twist it opposite direction past square by about the same amount it is out. Let cool while holding it this way.
davidmc36 is online now Find More Posts by davidmc36
Old Sep 03, 2015, 04:18 PM
leadpan's Avatar
Joined Sep 2007
I'll try that tonight.
Thanks for that idea!
For Sale Explorer mk II fuselage with stab buzzaverill Aircraft - Sailplanes (FS/W) 0 Jun 14, 2015 05:38 PM
For Sale Carbon z splendor : fuselage and rear stab set Hoodflyer Aircraft - Electric - Airplanes (FS/W) 6 Oct 21, 2014 01:40 PM
Help! fixing uneven horz stab? jokeane The Builders Workshop 3 May 07, 2011 09:17 PM
Question H & V Stab lightened holes... tomi Hand Launch 3 Feb 20, 2006 10:01 PM
How do you cut holes in the horizontal stab? Slow Riser Hand Launch 3 Aug 28, 2002 12:45 AM
