Old Feb 13, 2015, 08:33 AM
AJ_Aircraft is offline
Find More Posts by AJ_Aircraft
AJ_Aircraft's Avatar
Joined Dec 2014
AJ Aircraft 93" AJ Laser 230z
Official thread for the 93" AJ Laser 230z.
Purchase here.
Build manual here.
The 411:
Wing Span - 93"
Length - 88"
AUW - ~18-20 lb
Power(Elec) - Q-80
Power(Gas) - 60-70cc
Radio - 6 channel with 5 high torque servos
What's in the box:
Carbon reinforced landing gear mount
Pre-hinged glued and sealed ailerons & elevators
Pre-run rudder pull-pull wires (turnbuckle also included for push-pull option)
Removable horizontal stabs & rudder
Carbon fiber main gear
Carbon fiber control horns
Carbon fiber wing tube
High quality ball links & turnbuckles for all connections
Padded wing bags & stab bags
Full-length pipe tunnel
Genuine Ultracote covering in 2 color scheme choices including the AJ Competition Scheme
Fuel tank
3 different muffler can mounts
3/4" standoffs for gas engine (~3" standoffs will be required for electric setups)
Firewall drilling templates for DA-60/70 & 3W-50
Aluminum re-enforced firewall
Thick heavy duty pre-drilled wheel pants
Pre-drilled & rubber lined landing gear cuffs
3 1/2" rubber wheels w/ aluminum hubs
Heavy duty steel axles
Velcro for fuel tank or battery restraint
Extra hardware bag for spares
AJ flies this airframe with the following equipment:
Hacker Q-80
Falcon 24x10 prop
Castle 160 ESC
2x 6s Thunder Power lipo
Castle Pro BEC
Thunder Power 2s 3800mah G8 Pro-lite + 25C
Futaba S-9157 servos on Elevator/Rudder/Ailerons
Also needed to complete:
2x 6" extension for ailerons (not needed for S-9157)
2x 6" extensions from the receiver to the aileron servos
2x 48" extensions for the elevators
1x 12" extension for the ESC to Receiver (if electric)
1x 12" extension will be needed for the throttle servo and ignition (if gas)
4x 1 3/4" servo arms for elevators & ailerons
1x 3 1/2" servo arm for rudder
4" spinner
AJ_Aircraft is offline Find More Posts by AJ_Aircraft
Site Sponsor
Joined Dec 2014
reserved
Site Sponsor
Joined Dec 2014
reserved2
Site Sponsor
Old Feb 13, 2015, 05:28 PM
c-182 is offline
Find More Posts by c-182
RC Addiction
c-182's Avatar
Southeastern Michigan
Joined Oct 2007
We got a couple !
Nice quality air frame, went together very well .....need some flying weather !
c-182 is offline Find More Posts by c-182
Old Feb 13, 2015, 06:03 PM
cap23244 is offline
Find More Posts by cap23244
cap23244's Avatar
USA, OH, Warren
Joined Jan 2011
when is the new batch of 3 coming?
cap23244 is offline Find More Posts by cap23244
Old Feb 13, 2015, 06:15 PM
Nikolei Zinsli is offline
Find More Posts by Nikolei Zinsli
If it's R/C, I LIKE IT!
United States, NC, Raleigh
Joined Jun 2005
c-182 - What pin flag system you using? I'd love to see more internal fuse pics of that setup!
Nikolei Zinsli is offline Find More Posts by Nikolei Zinsli
Old Feb 13, 2015, 10:28 PM
c-182 is offline
RC Addiction
c-182's Avatar
Joined Oct 2007
Hornetnz
Retro scheme is the neighbors.....(pin and flag) think it is a smart fly....will check it out tomorrow......
Old Feb 14, 2015, 05:14 PM
Fly Utah is offline
Find More Posts by Fly Utah
United States, UT, Layton
Joined Feb 2015
I have been looking for a replacement for my beloved 89" Slick. The 93" Laser looked like a good replacement but I was a little concerned the DLE61 would not be enough to pull the vertical lines. Well I should not have been concerned. While the DLE 61 with Zoar 24X8 at 4200 feet will not rip the covering off of the airframe is has plenty of vertical. Using the pull-pull rudder system and putting 2x 2100mah Glacier LIFe packs against the firewall the balance was perfect. Hitec HS7955TG servos all around with Spektrum AR9110 reciever. The maiden was flawless and I got 4 flights today. What a great airframe! KE perfect! It tumbles like a wild-man. Hovering the airframe was rock solid and harrier had NO wing rock. There is no question in my mind the 93" Laser is more than a replacement for the Slick. Thanks to AJ and Tim. The call I received from Tim to tell me when the airframe was shipped was customer service of the highest level.
Fly Utah is offline Find More Posts by Fly Utah
Old Feb 14, 2015, 07:25 PM
malcolmm is offline
Find More Posts by malcolmm
Joined Jan 2005
I'm going to be using a Jeti Master Mezon 135 Opto 12s ESC with my Hacker Q80-8M.
Could someone with experience with this setup tell me what, if any, settings I should change from the factory settings in the ESC?
malcolmm is offline Find More Posts by malcolmm
Old Feb 15, 2015, 03:54 PM
olezippi is offline
Find More Posts by olezippi
*It Ain't Lookin Good*
olezippi's Avatar
Evansville IN
Joined Aug 2004
I got a lot finished today. Waiting on Spring. Suppose to get 6-8 inches of snow by tomorrow.
olezippi is offline Find More Posts by olezippi
Old Feb 19, 2015, 02:09 PM
c-182 is offline
RC Addiction
c-182's Avatar
Joined Oct 2007
Looking good olezippi......waiting on some WARMER flying weather here too
Old Feb 19, 2015, 04:31 PM
Buzzed is offline
Find More Posts by Buzzed
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Sounds like an awesome bird & congrats!
Can we get some video please??
Buzzed is offline Find More Posts by Buzzed
Old Feb 19, 2015, 04:33 PM
Buzzed is offline
3D Sunset Flier
Buzzed's Avatar
PHX
Joined Jun 2008
Outstanding build! Very clean.
Old Feb 20, 2015, 10:42 AM
vegasking is offline
Find More Posts by vegasking
vegasking's Avatar
United States, MO, Springfield
Joined Dec 2008
Same here, 93" is just waiting on Mother Nature.
vegasking is offline Find More Posts by vegasking
Site Sponsor
Old Feb 20, 2015, 11:22 AM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
Who's built this with the DA-70 and pipes? Any comments on cowl fitment or any other build aspects of the build worth mentioning? I'm almost done with my first gasser build and I have this one on my short list 9X wants.
jk6672 is online now Find More Posts by jk6672
Discussion AJ Aircraft 73" AJ Laser 230z AJ_Aircraft 3D Flying 539 Yesterday 11:24 PM
Discussion AJ Aircraft 56" AJ Laser 230z AJ_Aircraft 3D Flying 701 May 26, 2016 11:18 AM
Discussion *New AJ 93" Laser 230z * olezippi Giant Scale Airplanes 3 Jan 20, 2015 06:13 AM
Discussion AJ-Aircraft Laser 230z 56" with Pilot odejay 3D Flying 1 Sep 05, 2014 11:18 PM
News Andrew Jesky - AJ Aircraft L73" Laser 230z Jim T. Graham 3D Flying 16 Jul 25, 2014 06:25 PM
