Old Feb 03, 2015, 08:15 PM
skip63 is online now
Find More Posts by skip63
Phoenix, Arizona
Joined Jan 2005
Question
Apprentice SAFE System different Receiver
So my Receiver for the SAFE system took a dump so I swapped it out with a Spektrum AR8000 which I got for free when I bought the TX. I could not control the plane hardly at all. So I swapped out all the servos with regular EFlight servos and now it fly's great.
My question is are the servos part of the SAFE system?
Are the stock Apprentice servos compatible with a standard receiver?
skip63 is online now Find More Posts by skip63
Old Feb 03, 2015, 09:25 PM
mcnowhere is offline
Find More Posts by mcnowhere
Look out below
mcnowhere's Avatar
United States, OR, McMinnville
Joined Aug 2011
Did you use the same model in the Tx or a new model?
mcnowhere is offline Find More Posts by mcnowhere
Old Feb 03, 2015, 09:32 PM
m4rK is offline
Find More Posts by m4rK
m4rK's Avatar
Joined Sep 2014
I run a different RX in my Apprentice and I do not believe the servos have anything to do with the SAFE system. I have had at least 25 flights like this with no problems...
m4rK is offline Find More Posts by m4rK
Old Feb 03, 2015, 10:00 PM
Phoenix, Arizona
Joined Jan 2005
I'm using a DX8. I was using the stock DX5e until I swapped out the receiver. The problem was when I tried to turn using the ailerons it would stall and spin towards the ground every time. Throttling up while flying would flip it upside down with no stick movement. all control surfaces were centered and checked before flying and seemed to work correctly on the bench.
So my thought was it's the servos.??? So I swapped all of them out and with no radio changes it flew absolutely perfect. I'm just trying to figure out why it wouldn't fly with a new RX and stock servos. The plane has only been flown several times with no problems.
Oh well, it fly's great now and the whole SAFE system is in the trash.
Old Feb 05, 2015, 07:09 PM
JeffinTD is offline
Find More Posts by JeffinTD
United States, OR, The Dalles
Joined Apr 2011
The servos should be normal servos. Maybe you had one that was damaged?
JeffinTD is offline Find More Posts by JeffinTD
Old Feb 05, 2015, 07:30 PM
Rampage is offline
Find More Posts by Rampage
DFS#000178
Rampage's Avatar
United States, CA, Twentynine Palms
Joined Aug 2005
The servos are not part of SAFE. SAFE is only in the RX.
Sounds like maybe the battery shifted and the CG was off?
Rampage is offline Find More Posts by Rampage
Old Feb 05, 2015, 07:34 PM
intoford is offline
Find More Posts by intoford
Scott
intoford's Avatar
Canada, ON, Toronto
Joined Nov 2013
the servos in the apprentice are digital eflites and have nothing to do with
the rx, they should work fine in a non safe or safe plane
BUT...these some people including myself have had problems with them..in fact I junked them for Hitecs. Your problem could have been a bad servo? Nothing to do with safe.
or maybe the outputs from the new rx are different from the safe system..so if you didn't change anything on the TX..the channels would be reversed.I would test it again on the bench and take a close look
intoford is offline Find More Posts by intoford
Discussion Safe to parallel charge 3S batteries of different capacities? CC268 Batteries and Chargers 20 Jun 17, 2014 12:31 PM
Sold Dreamworks GSF-150 Air System Gear Fail Safe VF84Sluggo Aircraft - Fuel - Airplanes (FS/W) 1 Nov 06, 2013 12:46 PM
Sold Dreamworks GSF-150 Air System Gear Fail Safe VF84Sluggo Aircraft - Fuel - Jets (FS/W) 1 Nov 06, 2013 12:46 PM
Discussion Fail safe failure on Spektrum radio system victorfriessen Radios 8 Oct 30, 2013 10:33 PM
eflite apprent. parts yunghov Non R/C Items (FS/W) 7 Mar 04, 2013 12:25 PM
