Old Oct 26, 2013, 10:22 AM
Scratchthejeepgu is offline
Find More Posts by Scratchthejeepgu
United States, WI, Hudson
Joined Nov 2012
Help!
Double check my order please
Ok... Finally think I'm ready to place my order and would love it if you guys looked over my list, and told me about any glaring screw ups I'm either missing or ordering. I'm pretty much starting from nothing.
I'm building a wood frame, H quad design and am ordering from HK:
(5) DT750's and the nuts for them - (1 spare)
(5) Plush 30's - (1 spare)
(1) KK2 control board
(1) 2200 3s 25c battery
(1) Turnigy 9X 9ch mode 2 (or should I get mode 1?) TX/RX combo
(4 of each) 11X4.7 props,
Left black
Left green
Right black
Right green
(1 mtr) 14G wire black
(1 mtr) 14G wire red
(5 pr) XT60 connectors
(10 pr) bullet connectors
(1 mtr) 6mm heat shrink tubing - red and black
(1) battery strap.
Anything else I should order?
What about a battery charger? I have a Hobbico 900, 35-75 mA trickle charger, with a 5A max fast charge (for my RC cars) will that work?
Scratchthejeepgu is offline Find More Posts by Scratchthejeepgu
Old Oct 26, 2013, 10:33 AM
Joined Nov 2012
And for the frame, can I just use regular wood glue or should I use something special?
Old Oct 28, 2013, 11:40 PM
WendoNZ is offline
Find More Posts by WendoNZ
New Zealand, Canterbury, Christchurch
Joined Dec 2012
Looks ok, you'll need to make sure your frame is large enough to spin 11 inch props, and depending on that you may need more wire that you have.
Mode 1 or Mode 2 TX is a personal preference only. Doesn't matter as they still function the same.
Your charger doesn't appear to charge LiPo's so no, it won't work. You'll need a new charger, something like the Accucel 6 will probably be fine. If it were me I'd also be getting a higher C rating on the battery. Your current one maxes out at 55A
WendoNZ is offline Find More Posts by WendoNZ
Question Double check my wiring? Pathfynder FPV Talk 0 Sep 02, 2013 02:19 PM
Help! Double check my problem mcnowhere Radios 0 Jul 21, 2013 10:45 AM
Discussion When soldering wires together check & double check! tupeloflyer Electric Plane Talk 11 Apr 24, 2013 12:56 PM
Discussion Double-check my NIMH charging? overmyhead Batteries and Chargers 6 Feb 01, 2013 07:53 PM
Help! Please double check my items! shadowpho Multirotor Talk 6 Jan 05, 2013 08:21 PM
