Old Dec 08, 2013, 09:18 PM
Wetafly is offline
Find More Posts by Wetafly
Joined Feb 2004
The Arduino seems to have full functionality and I have the machine running on GMFC. I would like a bit more speed though so I might try upping the pulse speed out of the Arduino.
Wetafly is offline Find More Posts by Wetafly
Old Dec 08, 2013, 09:51 PM
Wetafly is offline
Joined Feb 2004
Changed the pulse speed in the Arduino sketch to 10K. That did the trick. Getting 7.5mm/sec machine speed now.
Old Dec 09, 2013, 09:06 PM
bombmer is offline
Find More Posts by bombmer
Joined Nov 2009
Anker's Foam Cutting Program
Hey Wetafly, Can you give me any help in getting Anker's foam cutting program to run all 4 axis.. Mach 3 runs fine, but Anker's Left X (pins 2 & 3) nothing...
bombmer is offline Find More Posts by bombmer
Old Dec 09, 2013, 11:51 PM
Wetafly is offline
Joined Feb 2004
I had no problems. You could try GMFC which has the same pinout and see if you still have the problem.
Old Dec 11, 2013, 04:24 PM
Wetafly is offline
Joined Feb 2004
Tidied up the plugs and leads and got the heat controller into an enclosure.
Very pleased with the outcome. Many thanks to JH.
Just need to get the vinyl cutter going for some labels.
Now to start cutting foam again.
Old Dec 11, 2013, 04:33 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
That is Professionally Nice. Very well done.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Dec 12, 2013, 12:55 AM
Wetafly is offline
Joined Feb 2004
Well I was a bit premature on the cutting. Can only get the machine to run in one direction in GMFC (both directions with Anker's software). Interestingly changing the table direction in the software did nothing. Checked the pinouts no problem there. Am suspecting GMFC sending pulse before direction. I have just received a GGC V2 from Dan which can control those parameters. Anyway more testing to be done before complete success.
Old Dec 12, 2013, 04:14 PM
Wetafly is offline
Joined Feb 2004
Problem was incorrect pinout information for GMFC. Sorted now.
Old Dec 16, 2013, 11:39 PM
Wetafly is offline
Joined Feb 2004
So the machine is working perfectly and doing 15mm/sec. Made new short bows so I decide to use my old 47V bow power supply. Connected it to the Arduino controller and turn it on and Zap Pow the smoke comes out and the PC goes black Ahrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrr.
I think the power supply rectifier must have been half blown, hence the old machine dieing. The multimeter just didn't show it up.
Back to the drawing board, at least aeromodeling prepares you for the occasional catastrophe.
Old Jan 04, 2014, 04:47 AM
jdfelosi is offline
Find More Posts by jdfelosi
United States, KY, Harlan
Joined Feb 2013
anyway to throw up a vid of it running? I'm looking into building something similar to your design.
jdfelosi is offline Find More Posts by jdfelosi
Old Jan 04, 2014, 04:59 AM
Wetafly is offline
Joined Feb 2004
Sure. I'm just waiting on a Gecko drive to turn up. It should be any day now. Will need to do some more work on connectors and fitting the cable chain. Nothing special about the mechanical design just get the same rails. One improvement I will do soon is to go for stainless threaded rod and brass nuts with spring loaded anti backlash.
Old Jan 09, 2014, 07:49 AM
bchristal is offline
Find More Posts by bchristal
TuffWing
Joined Nov 2009
How about a picture of your bows?
Thanks!
Brian
bchristal is offline Find More Posts by bchristal
Old Jan 09, 2014, 03:45 PM
Wetafly is offline
Joined Feb 2004
Thanks!
Brian
Sure Brian
I have made 3 bows for this project with wire lengths of 500mm 1000mm and 1600mm using .012" inconel wire. If anyone can knows where to get .009"-.010" rene or inconel let me know.
New Gecko controller arrived yesterday so hopefully I am back in business.
Old Jan 09, 2014, 04:00 PM
Fubar 123 is offline
Find More Posts by Fubar 123
Fubar 123's Avatar
Whitchurch,Shropshire. UK
Joined Jul 2008
Are you sure about wanting to buy wire made to a tolerence of 1/10000 of an inch on Dia, with a dia of just under a thou ?
Fubar 123 is offline Find More Posts by Fubar 123
Old Jan 09, 2014, 04:07 PM
Wetafly is offline
Joined Feb 2004
Sorry decimal place error. I hate imperial.
Here is a pic of how the bow is mounted on the machine.
Help! cnc foam wing cutter build HELP! mlggeek CAD/CAM 21 Jul 29, 2014 03:12 AM
Discussion CNC Foam cutter Tension jcyr1 CAD/CAM 22 Jan 16, 2014 07:25 AM
Discussion starting to build my own cnc/foam cutter azzou CAD/CAM 0 Jun 24, 2013 07:55 AM
Discussion CNC Foam Cutter for Hire? tyates5445 CAD/CAM 5 Apr 24, 2013 06:04 PM
Discussion home made cnc foam cutter DEBAY777 Foamies (Scratchbuilt) 5 Feb 01, 2013 07:06 AM
