Old Feb 07, 2015, 01:04 PM
nabzo is offline
Find More Posts by nabzo
Joined Apr 2013
I got it working just has to download version 2.20 assistant software
nabzo is offline Find More Posts by nabzo
Old Oct 30, 2015, 10:26 AM
pixelcore is offline
Find More Posts by pixelcore
Joined Oct 2015
Hi!
I have the same problem. But when I power on my Naza M Lite, remote led blinked red, not red-orange-green.
What it can be?
pixelcore is offline Find More Posts by pixelcore
Old Jan 04, 2016, 06:11 PM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
For people having issues installing the device, I think I have the answer (well it worked for me anyway)
1) First, you have to disabled the requirement for drivers to be signed, a guide can be found here for windows 8.1 and Windows 10 users:
http://www.howtogeek.com/167723/how-...igned-drivers/
2) Once that has been done, open device manager on your PC and expand the Serial ports section, now if you plug and wait then unplug your naza, you should see one here called USB serial device that will have a COM number of 1-15 possibly after it. This will be your Naza.
3)Right click your COM device, click 'update driver Software', then click 'Browse my computer for driver software'
4) then click 'let me pick from a list'.
5)Click 'have disk' then browse to the location the DJI driver software put the drivers (generally 'C:/Program Files (x86)/DJI Product/DJI Driver vx.xx' or similar. In this folder will be a 3 source folders, you will need to open the Source64 folder then select the .inf file and click open
6) The device driver box should now have DJI USB Virtual COM or similar in, click this then click next. This should successfully install the device driver and allow the software to now see your Naza. If at the last stage you get an error saying the driver could not be installed, you may not have completed step 1 correctly and disabled driver signing, or the driver may be corrupted. In the latter, uninstall the device drivers from the Remove Programs section of control panel, reboot, then install the driver package again from DJI.
If the above has helped, please quote the post and let me know, also any issues please let me know and i'll do my best to help.
If USB Serial Device does not show up in device manager for you or does not disappear when you unplug/plug the USB cable for the Naza THIS GUIDE WILL NOT HELP YOU
Bowerz is offline Find More Posts by Bowerz
Old Jan 19, 2016, 09:49 PM
S4UAS is offline
Find More Posts by S4UAS
Joined Dec 2014
Thanks Bowerz this did the trick for me. I was fighting with the driver installation on windows 10 for several hours and this solved the issue! Nice write up thanks!
S4UAS is offline Find More Posts by S4UAS
Old Jan 22, 2016, 09:40 PM
wdretired is offline
Find More Posts by wdretired
United States, AL, Madison
Joined Nov 2007
Unsigned Drivers
I have tried to install the drivers by several methods with no success. From what I can understand it comes down to the drivers will not install without problems on a 64 bit windows operating system. I have tried Windows 10 and Windows 8.1 and neither will load the drivers. There is only one thing worse that I have experienced and that is calling customer service at DJI. What a joke that has been!
wdretired is offline Find More Posts by wdretired
Old Jan 23, 2016, 05:35 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
WDRetired, the method I posted above WILL work for installing the Naza drivers on 64bit OS, we've all had the issue
Old Feb 07, 2016, 12:01 AM
ODUsurfer is offline
Find More Posts by ODUsurfer
Fly it like you stole it!
ODUsurfer's Avatar
United States, VA, Purcellville
Joined Aug 2009
THANK YOU! After spending an hour fighting with the driver not installing, this fixed my problem. Stupid windows 8. :-(
But removing the signature verification requirement did the trick. WOOT!
ODUsurfer is offline Find More Posts by ODUsurfer
Old Feb 07, 2016, 04:54 AM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Awesome, great to hear another person has been helped by this
Help! Naza assist/software HELP please Bbechtel Multirotor Talk 12 Jan 12, 2016 06:28 AM
Discussion DJI WooKong-M New LED With iOS Assistant Software DJI INNOVATIONS Multirotor Talk 32 Oct 24, 2013 01:38 AM
Discussion NAZA M: Trouble upgrading NAZA M firmware 3.10 with Assistant 2.10 pdbraun Multirotor Talk 11 Jun 29, 2013 05:17 PM
Discussion Naza assistant software (network) kazkioken Multirotor Talk 1 Mar 18, 2013 12:25 AM
Discussion DJI Naza-M Assistant Software Error Code List DJI INNOVATIONS Multirotor Talk 0 Feb 22, 2013 06:28 AM
