Old Mar 22, 2013, 11:12 PM
rcphreak is offline
Find More Posts by rcphreak
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
they have a lipo cut off but check the specs in the manual or maby some one will chime in with the same esc . can you tell me the numbers on the esc and ill help you check
rcphreak is offline Find More Posts by rcphreak
Old Mar 23, 2013, 08:42 AM
Jake5j is offline
Find More Posts by Jake5j
Joined Mar 2013
Losb0827 is the esc number
Jake5j is offline Find More Posts by Jake5j
Old Mar 24, 2013, 02:14 PM
Jake5j is offline
Joined Mar 2013
I am really confused about the brushless thing I don't no how to do it since the esc and receiver is in one can someone tell me every thing I need besides lipo to be able to run stock controller the website would be nice to thanks
Old Mar 24, 2013, 10:19 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
have you ran the lipo yet?? if not do that and learn how to drive it properly as brushless is a whole other nightmare if your new to rc because you will need to know how to work on the truck . remember a brushless set up will instantly double the power and speed of the truck and with that comes a price . crashes will not be simple anymore stuff will break due to the higher speeds . you will no longer be able to use the current controler , motor , esc / reciver . you will need all new electronics because your esc and reciver are one unit . and you cant run brushless with 27 mhz . it will glitch like crazy due to the high frequency .
Old Mar 25, 2013, 10:07 AM
Jake5j is offline
Joined Mar 2013
Oh ok i will just run lipo
Old Mar 28, 2013, 08:24 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
That's just not true, I've run brushless on 27mhz before without a single issue. The losi 27mhz systems glitch like crazy on any motor setup, and have terrible range so upgrading to 2.4ghz isn't a bad idea at all though.
wparsons is offline Find More Posts by wparsons
Old Mar 28, 2013, 11:06 PM
Jake5j is offline
Joined Mar 2013
What setup are you using like esc and reciver
Old Mar 29, 2013, 08:21 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
well true or not every 27mhz am radio ive owned has had problem glitching maby you have a better version but in your same statement telling me im wrong you say losi have problems glitching with any motor . sence you know it all please help him with his problems .hope my info has helped in some way .jake .
Old Mar 29, 2013, 08:37 PM
Jake5j is offline
Joined Mar 2013
It has been rc phreak thanks I have a problem I just bent a axel is there a good upgrade that is stronger
Old Apr 04, 2013, 10:40 PM
Jake5j is offline
Joined Mar 2013
Ok so I can't find any thing for this stupid desert truck should I just by a mini t chassis because I want aluminum chassis and can't find any thing and the mini t has More hop ups will the whole dessert truck besides the frame fit on a mini t like the a arms and servo mounts all that stuff or is it totally different I would also like to no if any one has a good place to buy aluminum kits for this truck it's a mini not micro I would like the whole thing to be aluminum
Old Apr 06, 2013, 03:51 PM
rcphreak is offline
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
you will find less for the mini t as either truck is no longer made .
the drive line parts for the mini dt ( not micro ) are the same as the mini late model and mini slider some other parts may interchange as well but not sure .
Old Apr 07, 2013, 12:34 AM
Jake5j is offline
Joined Mar 2013
Ok thanks
Wanted Losi micro t 1/36 or desert truck brushless or mini t 1/18 Constantino 2007 Cars - Cars and Parts (FS/W) 3 Nov 25, 2014 05:17 PM
Sold Losi 1/18 desert mini truck $55 blk822 Cars - Trucks and Parts (FS/W) 6 Apr 27, 2010 09:08 PM
Discussion What pinion for a 1/18 losi desert truck with 6800 brushless motor ? mortonj69 Micro Cars 6 Mar 15, 2009 07:26 PM
Discussion what is the stock pinion in a losi 1/18 desert truck ? mortonj69 Micro Cars 4 Mar 11, 2009 05:38 PM
