Old Dec 19, 2003, 02:17 PM
schnebly is offline
Find More Posts by schnebly
schnebly's Avatar
Bloomington Normal, Illinois, United States
Joined Sep 2003
plantraco dsp4c w/esc
Anyone have any experience, good or bad, with the Plantraco receiver with built in esc? Seems like a bargain if it works well.
schnebly
schnebly is offline Find More Posts by schnebly
Old Dec 19, 2003, 02:45 PM
radfordc is offline
Find More Posts by radfordc
radfordc's Avatar
United States, KS, Lansing
Joined Jan 2002
Mine works great. I used the esc to control a 280 motor. The RX is solid. No problems.
Charlie
radfordc is offline Find More Posts by radfordc
Old Dec 19, 2003, 03:06 PM
schnebly is offline
schnebly's Avatar
Joined Sep 2003
radfordc
Thanks! I am going to attempt to do some fff flyers over Christmas break and I'm trying to get my ducks in a row, so to speak.
schnebly
Old Dec 19, 2003, 06:35 PM
adar is offline
Find More Posts by adar
Slowflier
Palo Alto, CA
Joined Nov 2001
where to buy it?
Where can you buy it in the US?
thanks,
Michel
adar is offline Find More Posts by adar
Old Dec 19, 2003, 07:17 PM
zzonie77 is offline
Find More Posts by zzonie77
T A C
Gilbert, Arizona
Joined Sep 2003
http://mikrodesigns.com/dsp4.htm regards, zzonie
zzonie77 is offline Find More Posts by zzonie77
Old Dec 20, 2003, 09:03 PM
Jim Taylor is online now
Find More Posts by Jim Taylor
Wexford, PA
Joined Mar 2001
I've had one in my Slow Stick aerial photography plane for almost a year. Stock 300C-D with 11X8 prop on 7 KAN 950's or 8 AAA 700's. Never had a problem. I've had the Slow Stick specked out and never had a glitch. I've never flown around other fliers though.
Jim
Jim Taylor is online now Find More Posts by Jim Taylor
Old Dec 21, 2003, 12:14 PM
Martin Irvine is online now
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
I flew with one in an indoor setting with 5 other fliers in the air - until I had a mid-air, (Gee, I wonder why THAT happened!). I am using a GWS A drive and a 2S1P E-Tec 700 pack and 2 servos. I never got a radio glitch. A local hobby shop is selling them for $65CAN including the crystal.
Martin
Martin Irvine is online now Find More Posts by Martin Irvine
Old Dec 21, 2003, 05:27 PM
IanS is offline
Find More Posts by IanS
Toronto, ON, CANADA
Joined Jul 2003
I wonder if anyone has used this RX with a Speed 350 /400 motor or you will have to use a separate ESC.
They claim that the build-in ESC can handle up to 12A but I will take this with a grain of salt as it uses a single Mosfet and not a very good one IMHO (mine is with IRF7813).
Other than that it is a bargain - it is cheaper compared to the Berg's and is also "glitch-free" , uses cheap crystals too and can use the GWS's in a case you have some extra, better range that the all the GWS RXs and as an added plus has a build in ESC capable of handling up to 280 (maybe 300 too - see Jim Taylor's posting above).
IanS
IanS is offline Find More Posts by IanS
Old Dec 21, 2003, 10:46 PM
Wexford, PA
Joined Mar 2001
I'm away on vacation right now so can't check on the FET number, but the one on mine (IRF????) is rated at 12A but I believe Plantraco rates the DSP4 for 10A. Assuming you have a little airflow I don't think I'd worry about using it clear up to the DSP4's rated current which should be enough for most 300C setups. The 300C on my Slow Stick will pull 9.5 A static, but is probably only pulling 6A most of the time the way I fly it. International Rectifier makes higher rated SOT8 FETS that appear to be compatible. I got a couple higher rated FETS from Digi-Key and replaced the FET on another DSP4 with a higher current rated one. I've bench tested it and it seems to work fine, but I haven't put it in a plane yet. My eyes aren't what they used to be so I worry a little about my SMT soldering skills but the one I did seems fine on the bench. I did that because I thought I might want to replace the 300C with a 350 and I'm not sure 10A will be enough for a 350 on KANs. Another option might be putting a heat sink on the existing FET. If anyone is interested I'll post the specs. and number of the FET I used when I get back home after Christmas.
Jim
Old Dec 22, 2003, 06:30 AM
Dave Lindsey is offline
Find More Posts by Dave Lindsey
Dave Lindsey's Avatar
Brighton Ont. Canada
Joined Jan 2001
Martin
Which shop is that?
Dave
Dave Lindsey is offline Find More Posts by Dave Lindsey
Old Dec 22, 2003, 08:29 AM
IanS is offline
Toronto, ON, CANADA
Joined Jul 2003
Hey Dave,
Check out www.backyardflying.com - they are in Quebec.
This RX is only $57CAD and Free Fast Shipping!!!!!
I do not work/represent them, just a happy customer.
IanS
Old Dec 22, 2003, 02:19 PM
adaptabl is offline
Find More Posts by adaptabl
windsor,ontario,canada
Joined Jun 2001
I have one and use the ESC with a GWS 350 in a formosa(2 etech 1200,s or 2 1500 Kol's). Great compination, never a problem even with many fliers in the air at the same time. The reciever is as solid as my 555's.
adaptabl is offline Find More Posts by adaptabl
Old Dec 23, 2003, 08:16 AM
Joined Aug 2000
Hi Dave:
Leading Edge Hobbies
www.leadingedgehobbies.com
Martin
Old Dec 28, 2003, 07:36 PM
chewy is offline
Find More Posts by chewy
Joined Nov 2003
DSP-4SC
Anybody know if there is a way to use channel 3 for a second aileron servo? I've got a foamie using 2 aileron servos and it would be nice not to have to use a wye. Matt
chewy is offline Find More Posts by chewy
Old Dec 29, 2003, 06:48 PM
ElectriFan is offline
Find More Posts by ElectriFan
Redmond, WA
Joined Apr 2002
Another source for the Rx is www.balsapr.com, $55US w/ xtal. The Canadian price seems more attractive but doesn't include the xtal, shipping costs might negate the cost savings.
I've got 3 RXs and very happy with them, sold off my GWS Pico RXs after I got the DSP4-SCs.
ElectriFan is offline Find More Posts by ElectriFan
For sale - Kavan Partenavia w/ ESC and servos Mike_Then Aircraft - Electric - Airplanes (FS/W) 3 Jun 02, 2002 02:40 PM
For sale: Aveox 1406/4y w/ ESC and planetary gb dpseadave Aircraft - Electric - Airplanes (FS/W) 2 Jan 23, 2002 10:24 PM
Hacker B20-12L w/ESC and WeMoTec fan unit bruff Aircraft - Electric - Airplanes (FS/W) 3 Jan 19, 2002 09:36 AM
Permax 480 power system w/ESC and 8-cell packs JohnM Aircraft - Electric - Airplanes (FS/W) 3 Nov 30, 2001 07:08 AM
Speed 400 power system w/ESC and 8-cell packs JohnM Aircraft - Electric - Airplanes (FS/W) 7 Nov 26, 2001 09:08 AM
