Old Feb 02, 2013, 08:31 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Much better with a working ESC!
Got some good flights in today, but I have flutter.... Video coming soon on the first 5s flight on a decent ESC. Soon as I start to get the speed up it flutters. Pretty sure it is a flap doing it.
Elevator has no slop, and the ailerons are pretty tight. Flaps have a fraction of a mm or so of slop though, and it's coming from the servo itself which isn't good. Nice solid large horns, and the servo arm is as short as it can go. Might need to pull them out and put something else in.
I'll link video once it's up.
sykotic is offline Find More Posts by sykotic
Old Feb 02, 2013, 08:57 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
I know that flap flutter sound by hart...will be waiting for vid ....If nothing else,just toss a bit of tape on the flaps and go fly her to see what you get...just remember not to hit that flap switch on the TX
VooDoo Child is offline Find More Posts by VooDoo Child
Old Feb 02, 2013, 09:14 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Hmm... Can't hear the flutter very well on the video, I'm being too loud to hear it.
Loud vibration noise.
I can't remember if I used AMD or SCD servos on the flaps. I'll pull the covers and take a look. I should have thought about the taping of the flaps... Would have proved it one way or another.
Jolt F5D (3 min 37 sec)
Video should be done processing soon. Should be in 1080p once it's finished.
Motor was warm, but not bad. ESC was 65degrees on the IR thermometer. Battery was mid 60's.
Old Feb 02, 2013, 11:36 PM
jackosmeister is online now
Find More Posts by jackosmeister
Non Eius A Stupri Fucus
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Looks fast! Pity about the flutter, maybe changing the blanace point of the flap will fix it. Slapping a strip of solder up under the wiper maybe enough to change the frequency it wants to resonate at.
jackosmeister is online now Find More Posts by jackosmeister
Old Feb 03, 2013, 02:19 AM
blitzu is online now
Find More Posts by blitzu
The Prop is Where its At!
blitzu's Avatar
New Zealand, Bay Of Plenty, Omokoroa
Joined Dec 2012
Mean! Snds nice bro
blitzu is online now Find More Posts by blitzu
Old Feb 03, 2013, 12:30 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
That mega screams very nice, sorry about flutter.
whats the amps ? 130-140A
sebbe is offline Find More Posts by sebbe
Old Feb 03, 2013, 01:56 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
At a guess it would be around 130.
Don't have a castle in this anymore so don't have logging.
Once I figure out how to stop the flutter I'll do (try to!) some clean doppler runs
Old Feb 09, 2013, 07:39 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Flutter fixed
Can someone have a go at manual doppler on this?
RCspeedo is picking up some passes, but the later passes are surely a bit slower due to the battery... I killed the pack I was using on this flight. Totally puffed beyond usage. Couldn't get it out of the plane
Old Feb 09, 2013, 09:26 PM
Auckland NZ
Joined Aug 2007
Nice! How was the flutter fixed?
Guessed at 25 degees C
1 - 309.9kmh +/- 8.19
2 - 308.36 +/- 8.15
3 - Had throttle change in it, its around 319kmh though (guestimate)
4 - 345.7 kmh +/- 7.87 (214 mph woop!) Nice looking pass, look perfect in wavoscope . Is between 36-39 seconds in jolt5sp1
5 - 331.26 kmh +/- 8
6 - 316.93kmh +/-7.93 (pass from sp2)
Attached audacity cut down passes as zip, #4 is the winner.
Welcome to the 200mph club
Old Feb 09, 2013, 09:33 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
I figured that I had a tiny bit of movement in the clevis on both flaps. So some new servo arms, and carefully managed to get a 2/56 z bent rod through them. Far tighter fit than the clevis I did have.
Still got a fraction more movement in the servo output itself than I would like, but it's not fluttering so I'm happy.
Thanks for the dopplers
Thats running standard 4.75x4.75. Need to try one of the magic 4.1ish x 5.5's before my new toy for it gets here
Side note my Viperjet flew today. That one I crashed in Hastings... new fuse and it's away. Pretty quick as well
Old Feb 10, 2013, 04:05 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Nice speeds, seems the Jolt is pretty fast..
Old Feb 10, 2013, 04:34 AM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
How does the 4.1x5.5's pull Skyotic? I should make some carbon ones and lable them the 'noize machine' Always found the 4.1's make the sweetest noise
SB7 is offline Find More Posts by SB7
Old Feb 26, 2013, 08:56 PM
seng30904 is online now
Find More Posts by seng30904
seng30904's Avatar
United States, SC, North Augusta
Joined May 2007
antique Jolt
I finally finished my Jolt. It's been sitting on the work bench for a long time. Programmed in 2 stages of flaps, with crow mixed into the second (lowest) flap position. For all of the control horns, I ordered some .080 G10 material and cut out all five. Linkages are all tight and slop free. I deviated a bit on the wing trailing edge "tape it down method" and CAREFULLY installed a pan head screw through the rear wing to attach it. I thought it a much simpler procedure than taping the rear of the wing to the fuse. It turned out perfectly. I found a tapered screw (with the same pitch) as the main wing screws. Glued in a small piece of light ply with a blind nut into the rear wing saddle to hold it all together.
I am planning on attending the Perry Georgia swap meet this weekend, but plan on first flights the following week.
seng30904 is online now Find More Posts by seng30904
Old Feb 26, 2013, 09:03 PM
seng30904's Avatar
Joined May 2007
More pictures
Balances perfectly with the battery exactly in the middle of the wing saddle. 2s 350mAh receiver battery, Castle BEC, Castle Esc, motor/gearbox in the nose. Elevator servo and Rx in the rear. I've run the motor for a fairly long time with the wing on to evaluate temps, and find everything to be within normal limits. Set up for 10X23 prop, but will run the 10X19's for the first trim flights
Old Feb 26, 2013, 09:37 PM
Joined Aug 2010
2 - 308.36 +/- 8.15
Big Congrats Man ! That is some nice speed
Discussion Swist F5D build and fly 250mph+?! henke High Performance 424 Jun 24, 2015 01:03 PM
Discussion Micro Shrike Build Thread (was Mystery Build Thread) AndyKunz Electric Plane Talk 101 Dec 05, 2013 10:50 AM
Build Log Build thread for my F5D fuselage used at the WC Troy High Performance 3 Sep 09, 2010 04:39 PM
New Product New Build thread for Viper F5D Model Rob AR High Performance 20 Sep 08, 2009 04:06 AM
Build Log Build Thread or not to Build Thread? - Redback malachite Slope 35 Feb 28, 2006 01:12 AM
