Old Jun 18, 2012, 09:18 PM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Spray gun sizes
I have a 5 oz hvlp I paint my planes with. I use a paasche H single action for smaller parts and a little detail work. Is there something in between for doing smaller jobs like a cowl? My 5 oz cup uses lots of paint for a small 8" diameter cowl. Or is there a tip I can get for my paasche to give a bigger pattern, something like a 3" pattern. My searches havent found anything for the paasche.
Edwin
edwin1 is online now Find More Posts by edwin1
Old Jun 18, 2012, 09:23 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
How about a touch up gun?
http://www.harborfreight.com/touch-u...gun-66871.html
Maybe not this particular one, I have a devilbis that's real nice.
Underthetire is offline Find More Posts by Underthetire
Old Jun 18, 2012, 10:04 PM
Joined Sep 2003
I have a hvlp 5oz cup from harbor freight. It does ok for now, but it uses a lot of paint for the quick passes I do on a small piece.
Edwin
Old Jun 18, 2012, 11:02 PM
Joined Jun 2012
Mines not hvlp, it seems pretty reasonable on paint, but I have a feeling mine might be a little more adjustable that the harbor freight one. I have the hf gravity feed as well, it uses more paint than my siphon one for some reason. Great for primer though.
Old Jun 18, 2012, 11:13 PM
Joined Sep 2003
Yeah, I use my hvlp for primer and base colors. Its the small pieces I'm looking for a gun for. I'm currently using my paasche for that. Its about 1/8 oz per coat. It takes at least 1/2oz just to fill enough in the hvlp to start spraying. It became an issue when I started running low on paint and had to switch guns to make it last, just barely made it.
Edwin
Old Jun 19, 2012, 08:17 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I have, and use, an air brush, touch up gun, and a production HVLP gun.
I find it best to purchase an excess of paint, and mix plenty for spraying. In my mind, at least, this eliminates the worry of material supply problems. I know that I have enough material in my gun to complete the project.
It may not be the most economical solution, but it does calm the nerves while painting my latest project.
Unless catalyzed, I pour the left over mixed paint back into it's original container. Catalyzed paint goes into a jar, which is placed into my shop's refrigerator for long term storage.
TomCrump is offline Find More Posts by TomCrump
Old Jun 30, 2012, 04:55 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
Tom thats a good trick putting catalized mix in frig. I suppose the cold prevents it from activating, how long have you kept it and when you take it out and use it does the activation time change.
I'm doing some stuff now, clear coat 3 part and I hate to throw it out if I'm doing more the next day. Never would have thought of that, neat idea, might just give it a shot, thanks. Leroy
Leroy G is offline Find More Posts by Leroy G
Old Jun 30, 2012, 06:31 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Leroy; I'vce kept activated paint for over a year for a year. Your experience may vary.
Old Jul 03, 2012, 09:48 AM
jhaywood is offline
Find More Posts by jhaywood
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
I have the HF HVLP touch up gun and just bought a Sharpe Finex 1000 with a 1.0 tip. I was amazed at the difference!! The single biggest difference was the atomization. I could get nice small particles without having to crank the pressure up. The controls on the Sharpe work so nicely. You turn a knob a little, and it changes the pattern...a little. My HF has lousy pattern control and will make for a nice primer gun.
That being said, the HF gun shoots latex stunningly!!
jhaywood is offline Find More Posts by jhaywood
Old Oct 05, 2012, 03:00 PM
MCH27t is offline
Find More Posts by MCH27t
Impatience is a virtue
MCH27t's Avatar
Denver, Colorado
Joined Nov 2008
What size compressor is required for this gun?
MCH27t is offline Find More Posts by MCH27t
Old Oct 05, 2012, 03:25 PM
jhaywood is offline
jhaywood's Avatar
Joined Nov 2007
I have a 30 gallon upright, which plenty, but I don't know the specs of the gun right off hand for the minimum needed.
Old Oct 05, 2012, 04:01 PM
MCH27t is offline
MCH27t's Avatar
Denver, Colorado
Joined Nov 2008
Sold NIB Fuji 9600-4 XPC HVLP Spray Gun tonyjet Aircraft - General - Miscellaneous (FS/W) 0 Feb 20, 2012 07:31 PM
For Sale Miller Air Compressor and 3 spray guns Art Horne Aircraft - General - Miscellaneous (FS/W) 0 Oct 30, 2011 08:17 PM
Question Spray Gun mudfarmer_mike Parkflyers 28 Jan 31, 2003 01:02 AM
Spray gun for painting planes? dvint Electric Plane Talk 1 Nov 11, 2001 09:50 AM
