Old May 01, 2012, 12:35 PM
kartoffel is offline
Find More Posts by kartoffel
kartoffel's Avatar
United States, AL, Decatur
Joined Jul 2005
Complete ESC replacement on Radian Pro
EDIT: put an order in for a Castle Ice Lite 50. Thanks for the suggestion, Pilot Pete
I'm thinking of picking up a Parkzone Radian Pro to haul a camera round with a pan/tilt mount. The stock motor should be fine (knock on wood). Planned receiver: Spektrum AR8000 w/ T1000 telemetry.
Problem: Parkzone's included E-Flite 30A ESC has a marginal 700 mA BEC. It's barely sufficient for a bone stock Radian, nevermind the extra servos on a Radian Pro. There's no way I'd run the E-Flite 30A ESC with the avionics loads I intend to power. I'd prefer to avoid a separate RX battery pack. I'd also rather not splice a separate BEC onto the stock ESC. Space is at a premium and I like clean airplane guts
tl;dr, What's a good replacement ESC in the 30A to 50A range that can push at least 3 amps out of the BEC? Here's my current short list:
  • Hacker X-30 Pro, 1.06 oz. 2.01"x0.91" 5A BEC
  • Castle Phoenix-35, 0.9 oz. 1.72"x0.95", 5A BEC
  • Hacker X-40 SB Pro, 1.59 oz., 2.95"x1.1", 5A BEC
The X-40 SB Pro is only in the running because it gives some margin should I ever decide to replace the stock motor with something sportier. So what do y'all think?
kartoffel is offline Find More Posts by kartoffel
Old May 01, 2012, 03:11 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
None of the listed ESC's have a 5A BEC. The Hacker X-30 is only 1.5A, the other two are 3A, and all are linear mode BEC's. The CC Ice Lite 50 would be a nice upgrade. It has a 5A switch mode BEC, so it would do the job. Sure you can't shoe horn an external BEC in there, somewhere?
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old May 01, 2012, 03:15 PM
tkallev is online now
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I think you should re-evaluate your airframe choice, actually. A reconstituted beer cooler can only take you so far.
tkallev is online now Find More Posts by tkallev
Old May 01, 2012, 03:27 PM
pilotpete2's Avatar
Joined Jun 2004
Oh! That was cold
Pete
Old May 01, 2012, 03:56 PM
Kenny Sharp is offline
Find More Posts by Kenny Sharp
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Originally Posted by pilotpete2 View Post
Oh! That was cold
Pete
Gotta keep the beer on ice.
Kenny Sharp is offline Find More Posts by Kenny Sharp
Old May 01, 2012, 09:40 PM
kartoffel's Avatar
Joined Jul 2005
Pete
Actually, the Haker X-40 SB Pro has a 5 amp BEC. Look here and hit the "more details" button: http://www.aero-model.com/Hacker-Bru...B-Pro-ESC.aspx Where are you reading that it's only 3A?
The Ice Lite 50 does look really nice: smaller and lighter, which is always nice.
Don't worry, the beer cooler has carbon strategically placed as needed. Even the stock fiberglass wing spar is now a lighter, stuffer carbon tube. And unlike balsa, if I re-kit the plane, you can cut the guts out of it, stuff it into a fresh beer cooler, and be back flying the same day. Plus all my antennas are internal
Last edited by kartoffel; May 02, 2012 at 11:23 AM. Reason: Hacker X-40 SB Pro has a 5A BEC. See link.
Old May 02, 2012, 07:17 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Why not simply add a good quality, dedicated BEC?
http://www.castlecreations.com/products/ccbec.html
..a
Old May 02, 2012, 11:26 AM
kartoffel's Avatar
Joined Jul 2005
..a
Because if I'm going to go to the trouble of fixing half of the electrical power system, I may as well replace the E-Flite 30A ESC while I'm at it, too. It doesn't meet spec for the Radian Pro, IMHO, so why should I humor it by slapping a band-aid on it and keeping it in the plane?
Old May 03, 2012, 02:22 PM
turn, turn, turn.
Joined Oct 2005
Because it is not a bandaid... it is a fix.
Discussion Floats on a Radian Pro? rabdooley Waterplanes 11 Apr 22, 2012 02:18 PM
Sold Parkzone Radian Pro Motor,ESC, Servos, $80 OBO rcwarrior Aircraft - Electric - Power Systems (FS/W) 1 Apr 11, 2012 09:40 AM
Help! Lost post on Radian Pro mods - just found it! JBGROS Sailplane Talk 1 Apr 02, 2012 07:27 PM
Sold Motor, ESC, Servos and other Radian Pro Parts $100 OBO rcwarrior Aircraft - Electric - Power Systems (FS/W) 0 Mar 24, 2012 08:54 PM
Discussion What is the best glue to use on Parkzone Radian Pro? Riodiler1 Electric Sailplanes 0 Mar 01, 2012 09:15 AM
