Old Dec 30, 2011, 01:55 PM
ABLomas is online now
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
PPM encoder or decoder?
Hello,
i found this little board:
http://www.goodluckbuy.com/ppm-board...ontroller.html
Help me figure - this is PPM encoder, or PPM decoder?
I think this is PPM encoder (similar to this one), but still confused by "5V for servos" pins.
If that's encoder, can someone suggest PPM decoder schematics for 12 channels? I found many for 4 chans, one for 8 channels but still no idea about 12 channels.
Thanks!
ABLomas is online now Find More Posts by ABLomas
Old Dec 30, 2011, 02:02 PM
dleroi is offline
Find More Posts by dleroi
Don L.
Old Lyme, Connecticut
Joined Feb 2006
Originally Posted by ABLomas View Post
Hello,
Thanks!
AB,
They are basically the same. They call them encoders, but they really aren't doing any encoding. They take the individual servo pulses from a receiver and output them as a serial stream. Many of the multicopter flight controllers require the serial stream rather than individual signals.
- Don
dleroi is offline Find More Posts by dleroi
Old Dec 30, 2011, 02:08 PM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Originally Posted by dleroi View Post
It takes the individual servo pulses from a receiver and outputs them as a serial stream.
Well, PPM encoder then? ;-)
Thanks, still no idea why 5V connector "for servo" is here (but does not really matter anyway).
Old Dec 30, 2011, 02:26 PM
dleroi is offline
Don L.
Joined Feb 2006
I was editing while you were replying.
Yes, you can call it an encoder. I would call it a multiplexer.
- Don
Old Jan 05, 2012, 11:13 AM
navihawk is offline
Find More Posts by navihawk
United States, FL, Orlando
Joined Nov 2006
So that board will convert the signals into PPM to be able to use the DOSD v2 on a regular receiver that doesnt have PPM output?
navihawk is offline Find More Posts by navihawk
Old Jan 05, 2012, 12:16 PM
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Yes.
Old Apr 15, 2012, 04:39 PM
marunga is offline
Find More Posts by marunga
Joined Apr 2009
Hi,
Did anyone use this board? If so, did it work ?
I've have one and I think it does not work. Using a cheap oscilloscope I get some sort of saw wave on the PPM pin (max 1.5V) and the timming of the wave does not seem to change when the radio sticks move.
I'm using a Corona RP8D1 receiver, I can get a PPM signal from it. This signal has square waves and changes with stick movement.
I'll try to get a picture of the signal and post.
EDIT:
Ok, got the thing working. This is a copy of a Paparazzi ATmega PPM Encoder Board (V1 PCB), and I had to remove C3 to make it work. Flashed last bootloader+firmware.
regards,
m
marunga is offline Find More Posts by marunga
Old Jun 03, 2012, 03:52 AM
afraileperez is offline
Find More Posts by afraileperez
Joined Aug 2006
PPM signal out from the Corona RP8D1
Marunga:
Could you shown us how do you get out of the Corona RP8D1 the PPM signal?
I should do that to conect it to my new OSD.
Regards,
Alex.
afraileperez is offline Find More Posts by afraileperez
Sold Quadrino Board & PPM encoder Like new badbill Aircraft - Electric - Multirotor (FS/W) 1 Oct 31, 2011 09:21 PM
Discussion ppm encoder decoder ic faraz99 DIY Electronics 32 Aug 01, 2011 06:12 PM
Discussion 6ch diy rc encoder-decoder circuit sahilkit DIY Electronics 80 Apr 12, 2011 08:18 AM
Help! 12F683 ppm encoder-decoder micro17 DIY Electronics 7 Jan 10, 2008 01:17 PM
