Old Oct 31, 2011, 02:54 PM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
trex 700e 3g flips on its own at full collective !!!!!!!! Please help
ok guys so I have my new 700e 3g flying and wow am i impressed BUT I have one issue. when I go to full positive collective the heli does a backwards flip even if I am in fast forward flight and I want more speed I point the nose down even more as i give it more and more collective until all of a sudden I get to a point where she just dose a back flip .
Any ideas ?
hotdog1 is offline Find More Posts by hotdog1
Old Oct 31, 2011, 02:57 PM
Druss is offline
Find More Posts by Druss
Canada, AB, Edmonton
Joined May 2008
When you set up the heli, did you check to see the swash was level at all collective stick positions? Is the elevator servo traveling more than the others?
Druss is offline Find More Posts by Druss
Old Oct 31, 2011, 05:53 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
I would also guess the servo travel is not correct. Check for binding. If its not binding you probably need to go back through the 3G setup.
Roto Rob is offline Find More Posts by Roto Rob
Old Oct 31, 2011, 05:54 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Agree with the above suggestions.
Steph280 is offline Find More Posts by Steph280
Old Nov 01, 2011, 07:39 AM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
ok I will check these things today
Old Nov 02, 2011, 01:34 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
ok just checked and everything looks fine here is a vid do you guys see anything i am missing
trex 700e 3g head (0 min 30 sec)
Old Nov 02, 2011, 02:01 PM
whto is offline
Find More Posts by whto
Fremont, CA
Joined Jul 2007
One thing you can do is removing the main and tail blades. Spool it up and do the same things that causes the problem. Observe the swash to see what kinda movement it's making.
whto is offline Find More Posts by whto
Old Nov 02, 2011, 02:33 PM
Gedexas is offline
Find More Posts by Gedexas
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
How fast are you flying? Helicopter's speed is inherently limited due to differential lift. Symptom: pitch instability.
Gedexas is offline Find More Posts by Gedexas
Old Nov 02, 2011, 02:52 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
this will happen at any speed even from a hover
Old Nov 02, 2011, 02:59 PM
Gedexas is offline
CP heli ≠ 3D heli
Gedexas's Avatar
Joined Mar 2009
What FBL unit do you use? Maybe double check setup? Also, servos may bind under load and not bind when on the ground if their gears are bent, of course this applies to MG servos and not plastic.
You could try weighing it down and giving full throttle with the blades attached and everything, keep an eye on the swash, I bet it will tilt.
Old Nov 02, 2011, 03:45 PM
whto is offline
Fremont, CA
Joined Jul 2007
Are you sure you want him to weight down a 700 size heli and give full collective to check the swash movement?
I wouldn't do that with my 450 size heli. When I run into the similar problem, I'll check it without blades. At least that's how I trouble shoot with my beastx.
Old Nov 02, 2011, 03:49 PM
Gedexas is offline
CP heli ≠ 3D heli
Gedexas's Avatar
Joined Mar 2009
I believe I do want him to do that. There is a certain amount of weight that even a 700 won't lift. I would to that myself and I believe it can be done safely. It's certainly safer than letting it fly in this condition.
Old Nov 02, 2011, 05:11 PM
whto is offline
Fremont, CA
Joined Jul 2007
Iím not familiar with 3G, so my suggestion is for general FBL unit setup. Since your heli is flying fine except when in full collective, Iím not sure if itís because of vibe. However, it is still a good practice to make sure that thereís no excessive vibe. Too much vibe will confuse the FBL unit. If youíre sure thereís no vibe, then go through the setup process again, as suggested by Roto Rob. You can probably get more help from here, a lot more traffic: http://www.helifreak.com/forumdisplay.php?f=222
Old Nov 02, 2011, 06:56 PM
Purple Aki is offline
Find More Posts by Purple Aki
Joined Jul 2011
This same thing happened to me last week and nearly hit me. Another foot to the right and i'd of been chinless. I nearly soiled myself.
Mine is also a FBL, albeit only a Walkera v400d02. Mine did it from an hover though, and I think one of my servos was defective as the v400 is renowned for it.
Before I fire Her up again, i've ordered some new metal gear servos and have arranged to meet some experts at a local flying club whom said they will set it up and teach me to fly FOC.
Purple Aki is offline Find More Posts by Purple Aki
Reply With Quote  (Disabled)
Old Nov 02, 2011, 07:54 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
I don't think you will be able to simulate this issue with the heli secured to anything. It's FBL setup and the FBL unit must be in the air in order to take over and behave normally. There is no telling what it it will do locked down and even it did do something strange, you can't be certain it's not just coming from the fact you aren't in the air flying normally.
Xrayted is offline Find More Posts by Xrayted
For Sale Trex 700E 3G Super Combo 3DTRYER Aircraft - Electric - Helis (FS/W) 1 Jun 09, 2011 12:21 PM
Discussion Trex 700e 3g washout base control arm very stiff ? hotdog1 Large Electric Helis 0 May 23, 2011 10:09 PM
Discussion Trex 700e 3G or Logo 600SE mswify Large Electric Helis 4 May 07, 2011 01:23 PM
Sold New in box Align Trex 700E 3G w/o ESC modelfun2 Aircraft - Electric - Helis (FS/W) 3 Feb 14, 2011 09:22 AM
Sold Trex 700E 3G BNF dubd Aircraft - Electric - Helis (FS/W) 2 Nov 29, 2010 02:06 AM
