Old Jul 29, 2010, 02:21 PM
shimsham is offline
Find More Posts by shimsham
shimsham's Avatar
Joined Nov 2009
MTPLX Easyglider ESC
Can anyone tell me how to programm the brake ON on a EZG.
shimsham is offline Find More Posts by shimsham
Old Jul 29, 2010, 03:41 PM
patmcc is online now
Find More Posts by patmcc
Northumberland, England
Joined Jan 2007
Here are the instructions for the ESCs supplied with the brushless power sets for the EG Pro http://www.multiplex-rc.de/cms/vorsc..._37_54_5sp.pdf & http://www.multiplex-rc.de/cms/vorsc..._s_bec_5sp.pdf
patmcc is online now Find More Posts by patmcc
Old Jul 29, 2010, 10:31 PM
outngo is offline
Find More Posts by outngo
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
the non pro basic easyglider has a brushed "multicont" esc, did u mean that instead?
outngo is offline Find More Posts by outngo
Old Jul 30, 2010, 02:44 AM
shimsham is offline
shimsham's Avatar
Joined Nov 2009
Ok. The set up is a 3-4s brushless outrunner 950kv motor,the esc is from Giantcod.co.uk and a cheap SP 30amp esc [recommended],had a quite a few goes trying to programme the brake but i dont think i have been successful yet never done one before,does the prop stop rotating immediatly after pulling throttle to down positition, using a Spektrum Dx7 Tx.
Old Jul 30, 2010, 02:17 PM
Joined Jan 2007
Shimsham, the brake should have been enabled by factory default but if you follow the (clunky) instructions you should be able to alternate between enable & disable. The problem is recognising were it's at now since there's no confirmation signal returned.
IMO best method would be to familiarise yourself with the operation so that you can confidently change over at the field, then see if the prop folds in flight when the power's switched off. If it change it & try again.
You may find that it won't close in either case but a) the prop will freewheel or b) it will stop but not fully close.
In this event change the program to condition b) & make sure the prop is really floppy on it's pivot screw. A fraction of a turn on the screw can make a lot of difference but don't overdo it.
HTH
Pat.
Old Jul 30, 2010, 03:03 PM
shimsham is offline
shimsham's Avatar
Joined Nov 2009
Thanks Pat.
Colin
Old Jul 30, 2010, 10:20 PM
outngo is offline
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
*not to self* ON ANY VAGUE ?'s never even ask a question until main poster has provided his equipment type, in his first post or it WILL be a waste of time..
Sold EasyGlider Electric w/Motor, ESC, and Servos -Prefer Local Sale Tampa/Orlando area LostPlanetAirman Aircraft - Electric - Airplanes (FS/W) 1 Jun 06, 2010 05:44 PM
Discussion EasyGlider vs EasyGlider Pro? ForeverFlying Slope 6 May 24, 2010 02:46 AM
Discussion EasyGlider vs EasyGlider Pro? ForeverFlying Thermal 2 May 23, 2010 04:44 AM
Discussion EasyGlider ESC question milnei Electric Sailplanes 16 Jan 21, 2010 06:24 AM
Discussion MTPLX Twin Star II ? skyking1231 Foamies (Kits) 0 Feb 02, 2006 07:52 AM
