Old Jun 09, 2003, 10:19 AM
locomoto is offline
Find More Posts by locomoto
locomoto's Avatar
San Pedro, CA
Joined Mar 2002
Left thrust?
Hello all,
I have a Wattage Piper Cub400 that I maidened this past weekend and I noticed it was pulling hard to the right which I couldn't correct even with full left trim. I landed removed all the right thrust and it flew better, but still has a tendency to pull right a bit and the left turns are sluggish to control input with neutral trim. I checked and re-checked all my rigging and everything measures fine. So.....I was wondering if a degree or two of left thrust would help it fly better. I am running a Nippy 400 direct drive with an APC 8x6 prop. Any recommendations would be appreciated.
Dave
locomoto is offline Find More Posts by locomoto
Old Jun 25, 2003, 06:55 PM
DaveGherardini is offline
Find More Posts by DaveGherardini
Central Illinois
Joined Sep 2002
Hmm
How does it glide motor off? If it still pulls with motor off i would guess that its a warped wing to some degree. If it dose not roll in glide then i would say a couple degrees would do it. But i still suspect the wing may have a little more up twist on the left panel. Hope this helps
Dave G
DaveGherardini is offline Find More Posts by DaveGherardini
Question Souper 30 left thrust? kevin matthews Free Flight 42 Jun 06, 2007 03:01 AM
Discussion a newbie question about right/left thrust Dvglas Pusher Prop Jet Models 2 May 08, 2007 09:13 AM
Discussion Issues with left thrust pull! Wing kctrading High Performance 0 Apr 07, 2007 06:15 PM
Left thrust on a pusher ? Nigelp Power Systems 5 Oct 05, 2004 07:24 PM
Right & left thrust angles for aerobatic monoplane ifrichard Modeling Science 0 Sep 14, 2002 12:50 PM
