Old Feb 17, 2009, 11:13 AM
tsimmons is offline
Find More Posts by tsimmons
SC Flyer
South Carolina
Joined Dec 2008
Lipo batteries low voltage
I have some how discharged a new lipo below the charging voltage allowed by may charger. I put the battery in a larger plane, 30A ESC, and the plane had trouble flying after a few minutes. I brought it down and tried to charge the battery and got a low voltage warning. I tried measuring the individual cell voltage with no luck, very low. Is there a way to charge the individual cells to the minumum level, 3.7 volts so it can be recharged? I would appreciate any help. Thanks,.
tsimmons is offline Find More Posts by tsimmons
Old Feb 17, 2009, 11:36 AM
freechip is offline
Find More Posts by freechip
freechip's Avatar
Joined Aug 2008
If you have multi-type charger, you can select NIMH charge at the lowest setting (100mah) and keep a close eye on you're lipo when it reaches 3.0v or more the select lipo charge and it should be good to go with out low voltage warning. Care should be taken when doing this and you should make sure you balance the pack with proper charger/balancer or external balancer.
Since you're pack went below the recommend voltage of 3.0v per cell, their may or may not be damage done but care should also be taken when you use this pack from now on.
freechip is offline Find More Posts by freechip
Old Feb 18, 2009, 03:32 PM
CHilll is offline
Find More Posts by CHilll
Joined Jan 2009
Hi, if that is a lipo battery do not use any charger other that a charger that is for lipo batteries only.I drained my lipo down so far by accident that it took 7 1/2 hours to fully charge at the lowest setting on the charger.When a battery is that run down very low charge at the lowest setting possible on your charger.Hopefully your battery will come back.Do not charge any one cell more than 4.2 volts @3s=12.6 volts if its a 3 cell battery
CHilll is offline Find More Posts by CHilll
Old Feb 25, 2009, 02:16 PM
tsimmons is offline
SC Flyer
South Carolina
Joined Dec 2008
Low Lipo voltage
I did what was suggest, that is, connect as a NiCd battery and recharged to 9.6 volts at which point I was able to recharge normally. Thanks for the help.
Discussion Short Circuited Lipo has Low Voltage jkarnacki Batteries and Chargers 3 Dec 21, 2007 04:41 AM
Question Symptoms of 2s lipo reaching low voltage? lammy1000 Batteries and Chargers 3 Dec 04, 2007 09:25 AM
Lipo battery low voltage Fordplay Batteries and Chargers 2 Jun 16, 2005 07:30 AM
Walkera TX batteries.... Low voltage warning at ?? volts? dacaur Micro Helis 0 Jun 15, 2005 08:30 PM
lipo and low voltage detectors mlitke Scratchbuilt Indoor and Micro Models 14 Apr 02, 2004 02:28 PM
