Old Nov 26, 2008, 06:33 AM
lucasavaitor is offline
Find More Posts by lucasavaitor
Joined Aug 2008
Best way to apply monokote
Hi, I'm new and need an easy way to cover a nexstar with monokote. Problem is it is all round.
lucasavaitor is offline Find More Posts by lucasavaitor
Old Nov 26, 2008, 08:02 AM
Viper Pilot is offline
Find More Posts by Viper Pilot
God is good
Viper Pilot's Avatar
Banjul
Joined Jan 2001
Use the RCGroups search engine to find threads about MonoKote. There's enough answers already given to get you a new covering for the Nexstar. Actually, the instructions on the MonoKote rolls are good enough. Just buy the covering and read their instructions.
Viper Pilot is offline Find More Posts by Viper Pilot
Old Nov 26, 2008, 11:07 AM
rwp is offline
rwp
Find More Posts by rwp
rwp
rwp
rwp's Avatar
Joined Nov 2003
Take a look at the Monokote Instruction Video. It is very helpful.
rwp is offline Find More Posts by rwp
Old Nov 26, 2008, 07:31 PM
Joined Aug 2008
I searched before, and didn't find anything specific to applying monokote to balsa.
Old Nov 26, 2008, 07:40 PM
planefixer is offline
Find More Posts by planefixer
GO COLTS!!!!!
Lafayette, IN
Joined Jun 2007
It is really not that hard. Make sure that you have a good iron and a blow dryer. Because Monokote shrinks when you apply heat, it is pretty forgiving. Be careful because too much heat and you will burn holes in it. Take your time and practice. If you belong to a club, I am sure that you will find a never ending supply of opinions and tips!
planefixer is offline Find More Posts by planefixer
Old Nov 27, 2008, 12:48 AM
rwp is offline
rwp
rwp
rwp
rwp's Avatar
Joined Nov 2003
http://www3.towerhobbies.com/cgi-bin...?&I=LXKSB4&P=7
Old Nov 27, 2008, 08:15 AM
my c210 is offline
Find More Posts by my c210
Resident giant scale guru
my c210's Avatar
Picayune, MS
Joined Oct 2007
don't know bout you guys, but I prefer ultracote. easier around curves, and shrinks better.
my c210 is offline Find More Posts by my c210
Old Nov 27, 2008, 08:21 AM
GO COLTS!!!!!
Lafayette, IN
Joined Jun 2007
I agree 100%. Unfortunatly, my LHS only carries Monokote, so I have to order Ultracote when I need it.
Old Dec 09, 2008, 11:41 AM
Joined Aug 2008
I used white monokote for all of my nexstar. Its pretty nice, but some spots have permanent wrinkles, despite popping air bubbles. Pretty good for a first try though!
Old Dec 09, 2008, 11:53 AM
bwalt822 is offline
Find More Posts by bwalt822
USA, WA, Edmonds
Joined Aug 2008
what is the general technique for covering complex curves? Heat and stretch?
bwalt822 is offline Find More Posts by bwalt822
Old Dec 09, 2008, 01:52 PM
jim_ag3y is offline
Find More Posts by jim_ag3y
Hagerstown, MD
bwalt, I PAINT complex curves! Plastic covering is the DEVIL to get to stick to inside curves . I'm sure someone will have a better answer.
jim_ag3y is offline Find More Posts by jim_ag3y
Old Dec 09, 2008, 02:41 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Stretching plastic covering in concave areas ! ! !
Hello Jim and all readers,
I have recently trying to find what happens or how to handle stretching plastic covering in concave areas. I am not getting anywhere fast.
I even questioned the nature of the glue used on these plastic sheetings.
I have never used them for coverng my airplanes so I am quite ignorant and have some questions.
Do I undestand properly that a layer has to be peeled off ?
YES ... or ... NO (please delete the inappropriate word).
If the answer is YES, is the glue aleady sticky (like a post it label) ?
I understand at this time that the above line answer has to be NO if we can stretch it in contact with the surface or structure but I will welcome an answer.
I think we know that the glue is affected by heat and that heat has to be applied in order to get sufficient adherance.
RIGHT or WRONG (please delete the inappropriate word).
Now we have a high camber wing and the under surface (bottom surface of the wing) is concave.
How do we make the stretching plastic follow the concave shape where only a line near the leading edge and the trailing edge can touch a straight edge (ruler, anything straight).
Would not the heating pull the surface to a flat surface ? and loose that camber of the airfoil ?
Yes, when I was at school some of my teachers hated some of my questions for an obvious reason. They did not know the answer. So in electrical and electronic classes, having studied all that stuff already by myself, I was studying aviation, aerodynamics, meteorology, air regulations, aircraft engines with manuals hidden on my knees below my desk .
I have not change a bit .
Any one with a moment to respond ?
Would be highly appreciated although not remunerative, I am broke .
Thanks folks and Merry X'mas.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Dec 09, 2008, 04:09 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
YES (please delete the inappropriate word).
RIGHT
I wasnt talking about concave surfaces, I was talking about convex. But in anycase for concave, what I would try to do for an undercambered wing is to lay the covering so that it is laying against the surface as much as possible. Then tack it down around the edges. Normally you would hit it with a heat gun but that would just pull it away from the concave surface. So, I would try tacking it in a semi random pattern all over the concave surface using the lowest possible heat that gets it to stick. You wouldnt be able to slide the iron because that would probably make wrinkles. Once its all stuck, then do the same again with higher heat to really stick it down.
Old Dec 09, 2008, 11:26 PM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
Hi bwalt822,
Thank you very much for your response.
My concern was that, not knowing how well that glue on the plastic really adheres I was afraid that on final heating and stetching it would pull out the adhernce to the bottom of the ribs.
Enjoy the Xmas season,
Zor
Old Dec 09, 2008, 11:54 PM
bwalt822 is offline
USA, WA, Edmonds
Joined Aug 2008
it is possible that it would pull loose but if its already stuck down then the tension will be along the surface of the skin if the wing is sheeted which means there is no out of plane force to pull the covering up. It may distort the wing shape though. I'm not sure how it would work across ribs that weren't sheeted. It would probably be ok for a fairly shallow concave surface.
And FYI, this is all purely my speculation because I have never tried covering a concave surface with monokote.
Discussion What's the best way to cut MonoKote jims123 Painting and Finishing Tips 4 Nov 04, 2008 11:13 AM
Discussion Best Way To Remove Old Monokote From Balsa Fred Sanford The Builders Workshop 5 Apr 05, 2006 03:28 PM
Best Temperature to apply Monokote? Yardbird The Builders Workshop 2 Mar 25, 2005 09:20 AM
Best Way to Apply Covering to Glass or Carbon? green66 The Builders Workshop 2 May 10, 2004 11:17 PM
What's the best way to apply carbon fiber tape? doppler Electric Plane Talk 3 Aug 16, 2002 08:46 AM
