Old Feb 07, 2003, 05:36 AM
Heiner Skroblin is offline
Find More Posts by Heiner Skroblin
Cologne-Deutz R.R. Svc, Germany
Joined Jan 2002
Henschel HS P75
Hi,
did anyone ever built a HENSCHEL HS P75 in scale with an wingspan of about 48 inch. Are there any plans or drawings avaiable?
http://www.luft46.com/aoart/aop75-6.jpg
Heiner
Heiner Skroblin is offline Find More Posts by Heiner Skroblin
Old Feb 07, 2003, 09:45 AM
Tempest is online now
Find More Posts by Tempest
Tempest's Avatar
Gaithersburg MD, United States
Joined Nov 2000
Man that is cool! This is one of the experimental designs that I have not seen. I LOVE IT!
I am equally interested in any information about this aircraft (3 Views, Plans, etc).
Paul
Tempest is online now Find More Posts by Tempest
Old Feb 07, 2003, 10:15 AM
RMason is offline
Find More Posts by RMason
A Few Sandwiches Shy
RMason's Avatar
Orlando, FL
Joined Jun 2001
Go to www.luft46.com Click on Henschel. There is some info and a 3-view. Also some more oddities.
Rob
RMason is offline Find More Posts by RMason
Old Feb 23, 2009, 08:41 AM
wartoy is offline
Find More Posts by wartoy
wartoy's Avatar
United States, AR, Jacksonville
Joined Dec 2005
Heiner Skroblin, did you ever build your Henschel P.75 or even find plans for it?
wartoy is offline Find More Posts by wartoy
Old Feb 24, 2009, 12:47 PM
heiner is offline
Find More Posts by heiner
Joined Jun 2007
@ Wartoy,
No, not up to now. I made a lot of other projects, where I had more documents. But may be in future, I may start that project. In what size you were interested? What WS?
Heiner
heiner is offline Find More Posts by heiner
Old Feb 24, 2009, 11:52 PM
wartoy is offline
wartoy's Avatar
Joined Dec 2005
I am wanting to do one between 36-50 with full control surfaces and landing gear. That is the funkiest langing gear I have ever seen.
Old Mar 11, 2009, 03:19 PM
p901P901 is online now
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
He p75
I am building one with 44" wingspan from Depron. Its built but not flown still mixing servos. Running a 700w outrunner, 60Amp esc, 4 cell lipo, and 3 servos. Painted like the one in the picture.
p901P901 is online now Find More Posts by p901P901
Old Mar 11, 2009, 04:14 PM
wartoy is offline
wartoy's Avatar
Joined Dec 2005
Keep me informed of your progress! Can you show some pictures? How did you cut your parts?
Old Mar 13, 2009, 09:14 AM
newcomer is offline
Find More Posts by newcomer
newcomer's Avatar
central illinois
Joined Aug 2002
keep it coming. i really like this plane.
newcomer is offline Find More Posts by newcomer
Old Mar 21, 2009, 10:53 PM
p901P901's Avatar
Joined Jan 2009
Hand launched and powered at 1/4 throttle to adjust trim. The elevons and canard are mixed with a ratio of 60% canard to elevon movement. Pitch was sluggish. Forum advice from Canard Addict suggest that canards S/B 25% - 30% of main wings, mine was 10%. This was the scale comparison to the drawing from Luft 46. I am in the process scaling the canards to ~25 %.
Horizontal tail is split from 8" facing downward to 4" up And 4" down. This was to assist belly landing. Larger canards will prevent belly landing as this will cause canards to hit the ground or brush in the field I fly at. I'm looking at placing 0.125 music wire for landing gear with 1 1/4 wheels or skids. This will keep wings horizontal when landing and hopefully not allow canard damage.
The main wings are 44" long. Aircraft weight is 42oz.
Old Dec 02, 2009, 12:33 AM
p901P901's Avatar
Joined Jan 2009
Redesign rev b
After 10 flights and many crashes I Jjst had alot of issues with trying to make this design fly right. One big issue was that scaling the wing from the drawing led it to have a large camber which caused the ailerons to have no slow speed control. I used a flat profile canard that was undersized and rescale it to 30% of the main wing surface area. I just had to make this thing fly fast for any real control. The Large canard caused porpoising due to over control, linkage slop and later finding that pivoting it should be at 25% of AC it was at 50%.
So now for rev b and the only thing that will look like the original drawing is the fuselage. The wings are going to be more sweptback with an clark-y airfoil and wingtip verticals instead of the single downward facing type. I going to put landing gear instead of bungee launching.
Old Dec 02, 2009, 11:18 AM
WTFLYR is offline
Find More Posts by WTFLYR
WTFLYR's Avatar
West Central PA
Joined Dec 2008
I commend you for your efforts with the design. I've thought about building a few of these tailless/and/or/canard Luft '46 planes, but always chickened out, due to fears of non conventional aircraft. There are a few that just slightly resemble planes like the Stryker, Synape, etc, such that they may be a good start point, and only a start point, for a bash. I may go that route, simply because I could use a proven flying wing as a start point, given that I don't hack it up too badly to ruin it's characteristics.
This Henschel design is one that I've drooled over for years:
http://www.luft46.com/kwart/kwp135.html
As of now, I've stuck to the Luft '46 designs with tails.
WTFLYR is offline Find More Posts by WTFLYR
Old Dec 02, 2009, 10:46 PM
p901P901's Avatar
Joined Jan 2009
WTFLYR
You have some great looking planes. I also like LUFT 46 aircraft. What are the wing spans and the size of the fans? I have built a 6' Horton HO X and posted some information in the flying wing forum. Unfortunate that I could not add build information to those that were interested.
Although not flown yet,taxi test and flight controls are looking good.
Old Dec 02, 2009, 11:20 PM
WTFLYR is offline
WTFLYR's Avatar
West Central PA
Joined Dec 2008
WTFLYR
Thanks. They are around 32" span, using the GWS ME109 wing. The Flitzer is Himax 2025-5300/EDF55 and the FW250 is Don's Wicked outrunner/EDF64, both with EVO 3s-1800. The ME109 wing seems to perform better swept, than on the GWS plane. At one time I had categorized the airfoil type (can't remember which Eppler offhand) and read that they do perform well when swept.
I'll have to look at your Horton.
Old Jun 12, 2012, 02:12 AM
p901P901's Avatar
Joined Jan 2009
Version 2
After reviewing the old drawings and design I am thinking of a new direction. The new one will be 60" long with a 65" wingspan. The old version had a flying canard that lead to over controlling the pitch. New design will have a canard with a 3 degree incidence and a trailing edge control surface. Many other projects going on and may take a while to get back to it.
Need Help - CG Henschel HS 135 sdberlin Electric Ducted Fan Jet Talk 6 Jan 18, 2010 03:32 PM
Discussion Henschel Hs 129B-3 (1/12th Scale, Twin S400 DD) jfrabat Scale Kit/Scratch Built 17 Feb 27, 2006 01:55 PM
Henschel Hs-129b FAA Scale Kit/Scratch Built 13 Aug 09, 2002 03:42 PM
