Old Jun 06, 2008, 07:17 PM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Beevolution build instruction
All the Beevolution I ship so far are without build instrution.
I am now post the instrution step by step as following:
Ming is offline Find More Posts by Ming
Site Sponsor
Old Jun 06, 2008, 08:15 PM
shane.barton is offline
Find More Posts by shane.barton
Fix it til it's broke
shane.barton's Avatar
United States, CA, Lakeside
Joined Mar 2006
Holy cow that looks easy. Is it really as easy as it looks? I just happened to be in the market for a good slope combat plane like this. I also noticed your other thread on making personalized stickers for it also. I will have to think of something cool so I can include it in my order sometime in the next month! What are these bees costing these days, and what gear is used (micro everything?)?
shane.barton is offline Find More Posts by shane.barton
Old Jun 06, 2008, 10:41 PM
Ming is offline
Ming's Avatar
Hong Kong
Joined Jun 2002
Send me your file, I would like to see more personalized design on Beevolution.
Two standard size Futaba #3001 size of servo.
The Beevolution specification:
Site Sponsor
Old Jun 09, 2008, 03:24 AM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
My BeEvo doesn't have a hole in the root for a tube spar. No worries though, I know the ribbon spar is more than strong enough.
1000MPH is offline Find More Posts by 1000MPH
Old Jun 09, 2008, 12:13 PM
The Predator is offline
Find More Posts by The Predator
The Predator
The Predator's Avatar
Golden, Colorado
Joined Dec 2004
That's what I figure too Stu and, I had Ming send me 2 - 48" ribbon spars VS the 4 -24". I had not seen the tube spar or hole at that time. I'm not sure which will be better but, even just using a 8-12" tube spar in that hole would help fight the A ss crack and that's ALWAYS a good thing! I think it is a good DS mod to say the least in conjunction with the 48"ers just to double up the root sparing and toughness.
The Predator is offline Find More Posts by The Predator
Old Jun 10, 2008, 08:44 PM
infopimp is offline
Find More Posts by infopimp
PNF
infopimp's Avatar
Los Gatos, CA
Joined May 2005
I'm worried - my trailing edge - straight when I got it - now warps a bit after joining the wing cores.
Should I add a sub-TE? Trying to stay light.
infopimp is offline Find More Posts by infopimp
Old Jun 10, 2008, 09:23 PM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
On all of my last wing builds I add the spars from shock flyers to the trailing edge of the panels. I used goop to glued the spar on and then cover with tape. The trailing edges are always straight.
davidjensen is online now Find More Posts by davidjensen
Old Jun 11, 2008, 10:07 AM
The Predator
Golden, Colorado
Joined Dec 2004
I have not seen a warped TE yet but, if you do get one, just fix it with the a ss straps strapping tape by holding those TE's flat on the table while applying it with a CC card laid FLAT and using little pressure. Deforming the foam while applying stapping tape is the most common way to GET WARPED TE's as well. See pic.
Holding the CC card flat on the foam increases it's contact surface area to the foam, decreasing the point load on the foam so, it deforms less/ is more forgiving as a result.
Put simply, a flat CC card will not squash the foam while taping so you do not end up locking in squashed/bent TE sections.
So Steve, I guess in your case you WANT to deform the foam, to straight again. Let the table hold the TE straight while you lock it in with the CC card and tape. At this point it will not be DEAD straight but MUCH better! Use the covering shrink or the New stuff ironing on top of a FLAT table and your good to go. With the new stuff, I just hold it how I want it right after I get it all REAL HOT and then just hold it how it for 5 seconds as the NS adhesive cools and locks in the shape.
As I get REAL familiar with these moves I find I can change the wing whenever I want, even after it is built and flying, in small degrees. A little more washout no problemo. . .
Old Jun 24, 2008, 02:30 PM
kushal_22 is offline
Find More Posts by kushal_22
kushal_22's Avatar
Kamloops
Joined Dec 2001
What do you mean by "New Stuff"? is this just new Tape from a old roll or a NEW TYPE of tape? Also How are you getting it REAL HOT? Is this Before or after placing it on the EPP Foam?
Malcom
kushal_22 is offline Find More Posts by kushal_22
Old Jun 24, 2008, 03:50 PM
Dale Thompson is offline
Find More Posts by Dale Thompson
TD- F3K- Slope - What to fly?
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
To Quote the Predator
"You can get ALL the New stuff you want at www.laminatorwarehouse.com! I use the CP 10 mil, BCH most, rubbery tough and easiest to apply; and the DI stuff when I want real stiff 5-10mil and/or light, the Plastic plys in 3 weights 5, 7, 10, mil. Low luster 10 mil is SUPER BURRLY and is amazingly stiff heavy and expensive compared to the rest of them."
Dale Thompson is offline Find More Posts by Dale Thompson
Old Jun 24, 2008, 08:20 PM
kushal_22's Avatar
Kamloops
Joined Dec 2001
Thanks.
Never saw that comment from the predator though. Maybe it`s because i have not been here for over 10days. This new covering sounds interesting though. I am going to have to go visit the website
Regards
Mal
Old Jul 13, 2008, 10:20 AM
sbrv24 is offline
Find More Posts by sbrv24
Madras India
Joined Aug 2006
Hi Ming ,
Assembled the Beevolution as per your instructions . The only change being I went in for the Brushless Set up instead of the Brushed one.The set up is as below :
1) Motor : GWS Brushless Out runner 2212/13
2) ESC : GWS 25 A brushless ESC
3) battery : 11.1 V 3 S 2650 MAH Lipo
4) Prop : 6" x 3.25 "
I would like to Know if the Power set up is good enough for the Plane OR would it be insufficient.
Sai
sbrv24 is offline Find More Posts by sbrv24
Old Aug 11, 2008, 03:37 PM
flamingooo is offline
Find More Posts by flamingooo
Oslo Norway
Joined Sep 2007
joining rod?
Just bought this wing and am reading up on assembly here at the forum since no instruction where included.
I'm a bit confused as to what to do with the joining rod/spar described by Ming here: In my kit no rod was included; just the 4 x 24" carbon spars. No rod is depicted on the box (and neither on windriders homepage), but there is a slot molded into the foam (ca 6 mm in diameter, and about 6" into both halves).
I read here that some of you got 2 x 48" spars and do not worry about the wings rigidity without the connecting rod, but didn't see anybody write about the same configuration as mine...
I suppose some of you have some air-time with this wing, with and without the connector, and would very much like to har your suggestions as whether to worry about the missing rod...
Looking forward to fly my first ever wing
F
flamingooo is offline Find More Posts by flamingooo
Old Aug 11, 2008, 03:55 PM
Stuart B is offline
Find More Posts by Stuart B
AKA RustyKnee
Dorset, UK
Joined Dec 2006
F
I assume the spec changed, as mine didn't either. the spar hole wasn't even moulded in. I just added a couple of cuts for 12k carbon tow top and bottom for a bit extra strength. its holding up so far. Only thing I would do different is use a different glue to what Ming supplied in mine (took for ever to set).
Stu
Stuart B is offline Find More Posts by Stuart B
Old Aug 11, 2008, 05:30 PM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
we mentioned the difference a coupla posts up.
If you have 6-12 " of .024"/6mm carbon tube, go ahead and use it. If you want to do the split 48" ribbon mod you are going to have to search. My 121mph Bee had the 48" split ribbon and a short 6-7" tube just because I had it lying around. The spar broke about that far from the root so it may cause a stress riser.
stu (too)
Discussion Beevolution Build Thread + Predator's NEW STUFF infopimp Slope 4 May 10, 2009 09:49 PM
