Old Apr 02, 2015, 02:59 AM
peterswolf is online now
Find More Posts by peterswolf
peterswolf's Avatar
United States, FL, Ruskin
Joined Apr 2012
New Product
E-flite P-47D Thunderbolt w/AS3X 42.2” Wingspan, Flaps & Retracts (Due Late May 2015)
Here it is!!!
Due Late May 2015
BNF: http://www.horizonhobby.com/product/...-basic-efl6850
PNP: http://www.horizonhobby.com/product/...lt-pnp-efl6875
E-Flite® P-47D Thunderbolt Scale Park Flyer (2 min 17 sec)
Overview
The Republic P-47D multi-role fighter is impressive with an outstanding service record. A massive radial engine gave the power to deliver a variety of weapons against air and ground targets. Wide landing gear allowed it to excel regardless of field conditions, while its rugged design proved that pilots could return home even after absorbing heavy fire.
Get the warbird experience you crave with the E-flite® P-47D Thunderbolt. This aircraft comes out of the box fully equipped with operational flaps and retracts already installed. Z-Foam™ material not only makes this fighter tough, but also lightweight, even with all the scale detail. The way it flies separates this warbird apart from others in its class.
The advanced AS3X® (Artificial Stabilization – 3-aXis) system built into the Spektrum™ 6-channel AR636A receiver is what helps give the E-flite® P-47D Thunderbolt Bind-N-Fly version an incredibly solid look and feel in the air. It’s technology that works behind the scenes to help counter the effects of wind and turbulence by combining 3-axis sensing with exclusively tuned flight control software. As a result, your workload to fly smoothly is significantly reduced so you can perform every maneuver with greater accuracy. It’s a flight experience you get in the convenience of park spaces, but will have you feeling like you’re at the controls of an expertly tuned fighter that’s much larger.
You can enjoy air superiority in no time at all with this Bind-N-Fly Basic model. Final assembly is minimal and can be complete in about the time it takes to charge your battery. Once bound to your DSM2®/DSMX® compatible transmitter, an outstanding warbird experience is just a park away.
Electric Retracts
The installed main landing gear feature reliable electric retraction with covers over the steel struts that enhance the scale appearance along with the outer gear doors.
Functional Flaps
Operational flaps give this warbird a significantly greater flight envelope with the ability to takeoff in shorter distances and land more slowly.
4-Blade Propeller
The specially engineered 4-blade propeller delivers an appearance on the flight line that’s just as impressive as its performance in the air.
Strong and Light
Durable Z-Foam™ material provides the ability to replicate complex airframe detail with greater accuracy while delivering a very light flying weight.
Key Features
•AS3X technology delivers rock-solid stability and great handling
•Operational flaps with individual servos (installed)
•Retractable electric main landing gear, installed
•Spektrum 6-channel AR636A DSMX® receiver, installed
•6-channel control with servos, installed
•Brushless, 15-size outrunner and 30A ESC, installed
•4-blade propeller and scale spinner hub
•Clear canopy and detailed cockpit with pilot figure
•Dummy engine, gear door, machine gun and panel line detail
•Factory applied graphics with authentic WWII markings
•Easy-access battery hatch and bolt-on wing
•Constructed of durable Z-Foam™ material
peterswolf is online now Find More Posts by peterswolf
Old Apr 02, 2015, 03:38 AM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Peter,
This is Awesome news!
Thanks for sharing!
PittSpecial is offline Find More Posts by PittSpecial
Old Apr 02, 2015, 03:47 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
It seems like they are using the same 4-Blade as the new Dallas Doll.
http://www.horizonhobby.com/4-blade-...x-6-eflp98604e
If I ever get this one I will once again install the lighter and shorter Park Zone 480 (Park Zone T-28 Trojan Standard power system) and the Durafly 4-Blade Prop from the Durafly 1100mm P-51D Mustang!
http://www.rcgroups.com/forums/showthread.php?t=1827219
http://www.hobbyking.com/hobbyking/s...dProduct=68558
Old Apr 02, 2015, 03:52 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Check out my old and still flying 1st generation Park Zone Jug with the T-28 Trojan power system and the Durafly 4-blade at:
http://www.rcgroups.com/forums/showp...ostcount=22450
There is just no reason to even consider the PNP as for a few more $$$ you can get the BNF and I believe this is exactly what Horizon is betting on.
Old Apr 02, 2015, 04:06 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Checkered Board Cowling & Invasion Strips!
Guys,
The best of em all is the Checkered Board Cowling & Invasion stripes!
It will be interesting to see if the art work is as good as Callie Graphics
Of course included retracts and fuctional Flaps is a great plus as well!
Old Apr 02, 2015, 04:24 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
It is interesting that this new offering looks almost like the big papa Jug from Top Flight!
Old Apr 02, 2015, 06:07 AM
GiusedtoBe is online now
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
I don't see any difference other than the stab system and a slightly reworked cowl. That and the included retracts and flaps. Glad they brought it back but not exactly a major scale overhaul.
GiusedtoBe is online now Find More Posts by GiusedtoBe
Old Apr 02, 2015, 06:30 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
What?
Just say it......you wanted to see a P-47B?
Old Apr 02, 2015, 07:18 AM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Horizon Hobby Employee
Mahomet, Illinois
Joined Aug 2007
Originally Posted by PittSpecial View Post
What?
Carlos - that's a -D model. The -D model changed from razorback to bubbletop partway through production, with quite a few razorback -D models produced.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Site Sponsor
Old Apr 02, 2015, 07:22 AM
Mahomet, Illinois
Joined Aug 2007
Just so it's out there, this is the same airframe as Snortin' Bull with pre-installed retracts, flaps, AS3X receiver and a new trim scheme.
Site Sponsor
Old Apr 02, 2015, 07:44 AM
oscarmok is online now
Find More Posts by oscarmok
Canada, ON, Toronto
Joined Jun 2013
When is it available and what's the price?
oscarmok is online now Find More Posts by oscarmok
Old Apr 02, 2015, 08:21 AM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
Nice Parkzone with a face lift. Snortin' Bull with new makeup...
matiac is offline Find More Posts by matiac
Latest blog entry: Stability issue
Old Apr 02, 2015, 08:34 AM
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Yes glad to see it come back. Best foam plane HH has made IMO.
Old Apr 02, 2015, 09:01 AM
RavenV1 is offline
Find More Posts by RavenV1
Gear jammin,Foam crackin!
RavenV1's Avatar
Canada, BC, Surrey
Joined Apr 2013
Wow the best has returned. My Snortin bull lll is getting tired, stress crack's everywhere!
Will buy the kit though, got no use for AS3X unless it's in a DR1 and got a low KV P-25 for the Durafly prop. Otherwise will definitely pick this one up.
RavenV1 is offline Find More Posts by RavenV1
Old Apr 02, 2015, 09:09 AM
ryramZ is offline
Find More Posts by ryramZ
Your Pilot Ryan
ryramZ's Avatar
United States, IN, South Bend
Joined Nov 2008
Yay, great news! I'm In!
ryramZ is offline Find More Posts by ryramZ
Sold E-Flite P-47D Thunderbolt W/ Extras NJ4229F Aircraft - Electric - Airplanes (FS/W) 6 Mar 13, 2015 03:40 PM
Sold Top Flite P-47D 60 Thunderbolt\DLE 20!! reconxvi81 Aircraft - Fuel - Airplanes (FS/W) 3 Jan 11, 2015 08:08 PM
Wanted E-flite P-47D Thunderbolt marchese1229 Aircraft - Electric - Airplanes (FS/W) 1 Dec 21, 2014 11:09 AM
For Sale E-flite P-47D Thunderbolt ARF NIB fastwilly Aircraft - Electric - Airplanes (FS/W) 5 Aug 15, 2014 10:13 AM
Sold E-Flite P-47D 400 Thunderbolt Razorback Cap'n Aircraft - Electric - Airplanes (FS/W) 1 Sep 27, 2013 05:28 AM
