Old Jun 25, 2013, 12:01 PM
ServoCity is offline
Find More Posts by ServoCity
ServoCity's Avatar
United States, KS, Winfield
Joined Jun 2011
New Product
Hitec HSG-8315BH Tail Rotor Servo - in stock
BRAND NEW AND IN STOCK NOW AT SERVOCITY!
#38315S - $89.99
http://www.servocity.com/html/hsg-8315bh_servo.html
New! 25 Tooth Spline
Hitec’s new supersonic helicopter sedrvo is fast and furious fun! Built with ultra-speed in mind, the HSG-8315BH has a robust Karbonite and aluminum hybrid gear train, high-performance coreless motor and high resolution, low dead band circuitry. It is the perfect tail rotor servo for 500+ size and up gas pilots whose maneuvers and aerobatics demand the utmost precision and acceleration. Rated at 7.4V for 2S LiPo operation with a 560Hz refresh rate, this servo rivals anything like it on the market. Throw in its 25-tooth standard spline and dual ball bearing and it is sure to become one of your favorite servos!
Specifications:
Control System: 760 ~ 1020 usec
Operating Voltage Range: 6.0 - 7.4 Volts
Operating Temperature Range: -20° to +60° C (-4°F to +140°F)
Operating Speed (6.0V): 0.05 sec/60° at no load
Operating Speed (7.4V): 0.04 sec/60° at no load
Stall Torque (6.0V): 60 oz/in. (4.3 kg.cm)
Stall Torque (7.4V): 74 oz/in. (5.3 kg.cm)
Hz Refresh rate: 200~560 Hz
Continuous Rotation Modifiable: No
Motor Type: Coreless
Bearing Type: Dual Ball Bearings
Gear Type: Karbonite and Aluminum Gears
Connector Wire Length: 11.8” (30mm)
Dimensions: 1.57” x 0.79” x 1.50” (40 x 20 x 38mm)
Weight: 2.12oz (60.0g)
IMPORTANT
The PWM range for this servo is 760 ~ 1020 usec.
It will not work with our Servo Controllers.
ServoCity is offline Find More Posts by ServoCity
Site Sponsor
For Sale Hitec HSG-5084MG Tail Servo BM2KTom Aircraft - General - Radio Equipment (FS/W) 1 Jun 04, 2013 02:49 AM
Sold HSG 5084mg Hitec Tail Servo mikes68charger Aircraft - Electric - Helis (FS/W) 2 Feb 20, 2013 08:05 PM
Sold HSG 5084MG. Hitec Tail servo mikes68charger Aircraft - General - Radio Equipment (FS/W) 1 Feb 20, 2013 07:32 PM
Sold Hitec HSG-5084MG Tail Servo $20.00 Shipped Dizzante Aircraft - Electric - Helis (FS/W) 2 Jan 07, 2013 10:19 PM
Sold ** Hitec HSG-5084MG Tail Rotor Servo ** Sammy70 Aircraft - Electric - Helis (FS/W) 1 Jan 17, 2012 01:47 AM
