Old Jan 14, 2013, 03:06 AM
lancaster1945 is offline
Find More Posts by lancaster1945
Australia, NSW, Bankstown
Joined Jul 2012
Imax RC B3 Compact flashing lights
Hi there,
just today i notice something weird about my B3 Pro Charger when i plug in my Lipo, all 3 cell lights keep flashing red & green and doesnt charge my battery at all.
can anyone help me here please?
thxs
lancaster1945 is offline Find More Posts by lancaster1945
Old Jan 14, 2013, 04:42 AM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
It is probably time to replace that charger. I doubt that it is worth the time and effort to attempt a repair.
Were I you I would look at a charger that has a two line display that provides you the battery and charging information.There a number of them in the $50 range that will be adequate.
To be able to make a suggestion it would be helpful if you posted your battery requirements and even your location
Glen.
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jan 14, 2013, 05:26 AM
Joined Jul 2012
Glen,
Lipo 4000mah 7.4v 60-80c discharge,
Sydney, Australia
Old Jan 14, 2013, 06:45 AM
USA, GA, Marietta
Joined Aug 2005
Several good chargers here. Look at the CellPro 10XP and the PowerLab 6.
Glen
Old Jan 14, 2013, 08:30 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
I hope he's rich.
The Tug is offline Find More Posts by The Tug
Old Jan 14, 2013, 01:19 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Originally Posted by lancaster1945 View Post
Glen,
Sydney, Australia
Oh my god that has to take hours on that charger.
Get a real charger. Even if it's a cheaper one from HobbyKing.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 14, 2013, 10:48 PM
Joined Jul 2012
the Tug is correct im not rich, so i afford one from Hobbyking for under 50 bucks thats ok
can anyone recomend a good one for my Lipo then im laughing.
thxs
Old Jan 15, 2013, 03:51 AM
USA, GA, Marietta
Joined Aug 2005
OK, here is one: http://www.hobbyking.com/hobbyking/s...er_w_acc_.html
HobbyKing ECO8. It's a 150 watt 7 amp charger, $37 USD. You will need a 12V 15 amp power supply to be able to use the full 150 watts.
This is not a recommendation. I have never used this one but it fits your requirements.
Glen
Old Jan 15, 2013, 05:16 AM
Joined Jul 2012
is that the only one you would recomend or is there another one better that that?
the reviews to that charger wasnt very good sorry.
thxs
Old Jan 15, 2013, 10:42 AM
USA, GA, Marietta
Joined Aug 2005
I just picked that one because the specs more or less matched your requirements. The only ones I truly recommend are more expensive than what you want to spend.
Glen
Old Jan 15, 2013, 11:00 AM
The Tug is offline
Barbados
Joined Jan 2011
The ICharger $79 would be what you really want,it's good quality.What happens is when you go up in power you need a bigger power supply and that's where you're gonna get wacked over the head.However there are these converted PC supplies going for much cheaper and they have capable power.That would be really what you need to do,another side to this is good quality equip can be sold quickly on the net.I own both and there's no comparison.
Old Jan 15, 2013, 11:05 AM
United States, MN
Joined Feb 2011
thxs
Do you need an AC power supply for that price as well? I'm going to guess yes since you're old charger was AC. In which case you'll be extremely limited.
This combo is just slightly over your budget:
http://www.hobbyking.com/hobbyking/s...1_8_Cells.html
http://www.hobbyking.com/hobbyking/s...00v_240v_.html
Just remember that power supply has less capacity then the charger so you'll need to limit your charging appropriately.
Old Jan 15, 2013, 11:42 AM
USA, GA, Marietta
Joined Aug 2005
My only concern with that combo is the power supply is only 105 watts and the charger is 150 watts. It may be possible to damage the power supply if you try to run the charger at 150 watts.
Glen
Old Jan 15, 2013, 11:48 AM
United States, MN
Joined Feb 2011
Glen
Whoops forgot to add that limitation. Post edited. When someone give's a budget so low sometimes you gotta work with what's given.
Old Jan 15, 2013, 12:07 PM
The Tug is offline
Barbados
Joined Jan 2011
If you guys are going to stick to his $50-under budget,why not recomend the Acucell 6 and a laptop supply,he'll be able to do a 1c charge comfortably,with the speed he's at now he will go straight to heaven for even less money.
Cool SKYRC RC Model iMAX C3 Li-polymer R/C Hobby Compact Balance Charger szewang2805 Hot Online Deals 0 Nov 28, 2012 12:27 AM
Cool Only USD11.9 GT Power RC Car Flashing Light LED System szewang2805 Hot Online Deals 0 Nov 15, 2012 07:49 PM
Sold Imax C3 compact charger. CorgiCowPockets - xxDExx Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 25, 2012 02:38 PM
