Old Dec 23, 2012, 05:37 PM
WOS is offline
WOS
Find More Posts by WOS
WOS
United States, IN, Michigan City
Joined Nov 2003
Pre-Flight Checks
Am Curious as to what everyone checks and goes over on their Pre-Flight Checks and After they get done flying
WOS is offline Find More Posts by WOS
Old Dec 23, 2012, 08:47 PM
RFDelie is offline
Find More Posts by RFDelie
Get to the choppa!
RFDelie's Avatar
United States, PA, Pittsburgh
Joined Sep 2012
When I power up I basically just do an electronics check. I check all my servo travels. I also check for gyro correction.
At the end of a day of flying I put it on the bench and check for loose screws and anything out of place.
I think you will find that people's habbits are directly related to the failures that they have suffered in the past. A lot of lessons learned the hard way in this hobby.
RFDelie is offline Find More Posts by RFDelie
Old Dec 23, 2012, 10:08 PM
Hajile is online now
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
I'm still building up my checklist. So far, i check if the servo screws are loose, check the swashplate linkages, power it up on throttle hold and check the flight surfaces, and then throttle up.
I still have a fairly short checklist, i expect that to get significantly longer as i keep crashing.
Hajile is online now Find More Posts by Hajile
Old Dec 23, 2012, 10:39 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
Check everything mechanical for integrity, wear and correct mechanical action.
-rotors, grips, head, arms, shafts, gears, belts, frames, linkages, mounts, skids, tail, canopy, lipo straps, nuts, bolts, bearings
Check everything electronic for integrity, wear and correct electronic operation.
-esc, bec, motor, rx, servos, gyro, fbl (if applicable), lipos, wires, connectors, solder joints, rx pack (if applicable), radio
Check safety checks
-perform a range check, make sure all batteries(flight pack, rx and tx) are charged, test throttle hold, verify that the gyro is operating correctly, verify the proper operation of the swash plate, have a spotter
phoenixheli is offline Find More Posts by phoenixheli
Old Dec 23, 2012, 11:06 PM
old4570 is offline
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
Hmmm
Mainly head and tail for loose screws parts every time before flying ..
Generally just check everything , from time to time I will check every screw .
From battery tray to feathering shaft screws to tail rotor .. Every last screw on the heli ...
Just listen to how it sounds , any new vibrations , You need to keep a very close eye on the head and tail and a general eye on everything else ..
And every now and again , check every last screw ..
old4570 is offline Find More Posts by old4570
Discussion Anybody Use the Scope Window In MKTOOLS In Their Pre-Flight Check List? Bullseye123 Multirotor Talk 0 Aug 11, 2012 11:19 AM
Mini-HowTo R/C Heli Tutorial #7 Pre-Flight Checks frivilousteamrc Beginner Training Area (Heli-Electric) 1 Jul 14, 2012 12:53 PM
Discussion Pre Flight Check rheaun Foamies (Scratchbuilt) 2 Apr 09, 2012 04:02 PM
Bandit: Pre first flight check davidleitch Electric Sailplanes 11 Oct 26, 2002 09:38 AM
Pre-flight checks - a cautionary tale Wright Flyer Parkflyers 20 Oct 03, 2002 09:53 AM
