Old Sep 17, 2012, 09:10 AM
91Atrac is offline
Find More Posts by 91Atrac
91Atrac's Avatar
Joined Aug 2012
Question
How to repair sticky carb
So tried taking the savage out yesterday to find its got a sticky carb throttle shaft. Something like that cuz the throttle doesn't go all the way in so stays 1/4 or more open all the time.
It's a savage 25 and has the 4.6 motor in it if it makes a difference. Let me know if you have any good walk throughs thanks.
91Atrac is offline Find More Posts by 91Atrac
Old Sep 18, 2012, 06:52 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
If you disconnect the linkage from the throttle servo, does it close any more? The carb will have a limit screw that stops it from closing beyond a certain point. You can adjust it to set the idle speed. Don't touch that until you know that the carb is actually hitting that screw though, no point in messing up something that isn't needing to be touched.
wparsons is offline Find More Posts by wparsons
Old Sep 20, 2012, 01:04 PM
91Atrac is offline
91Atrac's Avatar
Joined Aug 2012
I'll follow up on this later. Keep you posted!
I can manually push the throttle closed tho.
Old Sep 20, 2012, 10:07 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Is it hard to push it all the way closed? It's possible that nothing is sticking, you just need more servo travel.
Old Sep 21, 2012, 09:14 PM
91Atrac is offline
91Atrac's Avatar
Joined Aug 2012
Could be. I'll try again. I know the servo doesn't brake. Would this be a sign it's the servo not the carb. Was reading this is common :/
Old Sep 22, 2012, 09:58 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Does the servo not turn to activate the brakes, or are the brakes just worn out?
Old Sep 22, 2012, 06:27 PM
91Atrac is offline
91Atrac's Avatar
Joined Aug 2012
Bran new brake pad and it doesn't turn that way at all.
Old Sep 23, 2012, 07:22 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Does it turn that way if it's not connected to the throttle/brake linkages?
Old Dec 11, 2012, 10:41 PM
91Atrac is offline
91Atrac's Avatar
Joined Aug 2012
Well linkage was backwards and throttle was turned on the remote lol!
But now I can't get her started. Ugh
Discussion How to repair damaged hull Swanny454 Dock Talk 3 May 12, 2012 03:34 PM
Discussion Crashed HawkSky - How to Repair or not repairable? sahil80 Beginner Training Area (Aircraft-Electric) 18 Apr 30, 2012 11:22 AM
Whoops! First chance to learn how to repair a wing greg00miller Hand Launch 22 Apr 24, 2012 09:33 AM
Discussion How to repair dents on solid core molded wings GaryO Hand Launch 5 Mar 20, 2012 08:15 PM
Discussion How to repair dents on solid core wings GaryO Hand Launch 0 Mar 10, 2012 10:37 PM
