Old Sep 18, 2003, 04:33 PM
kgmorris is offline
Find More Posts by kgmorris
Ken
kgmorris's Avatar
Arlington, Texas, United States
Joined Sep 2002
Two FanTastic AT-6s make first Flights
Lex Taylor and I made the first flight of our FanTastic AT-6 Texans’. Both flew great and were the center of attraction at the Bedford Boy’s Ranch near the DFW Airport Texas. I also have a Strega and they both (AT-6 & Strega) fly about the same with the AT-6 I think, is faster. Lex and I agreed it’s a Great fun to fly aircraft!
Fly Low and Slow
Ken
kgmorris is offline Find More Posts by kgmorris
Old Sep 18, 2003, 04:34 PM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
My AT-6 fly by.
Old Sep 18, 2003, 04:37 PM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
Another Training shorty
Old Sep 18, 2003, 04:38 PM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
Lex makes a pass
Old Sep 18, 2003, 04:40 PM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
Lex on the go.
Old Sep 18, 2003, 04:43 PM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Nice! They'll fly indoor, in say, a gym?
Whats the specs?
larsy87 is offline Find More Posts by larsy87
larsy87 is offline
larsy87's Avatar
London, Canada
Joined Aug 2002
You prop looks better, lol.
Old Sep 19, 2003, 02:57 AM
kgmorris is offline
Ken
kgmorris's Avatar
Joined Sep 2002
Molded EPS sheet foam (Depron)
Weight: 6 1/2 oz with paint and 1200mah Li-poly E-TEC 2S pack. I would guess about 30 min flights with this set up?
GWS IPS "A" drive (single) this one is out of a retired TM
GWS 9 7 prop
31 1/2" wing span
Undercambered airfoil (single surface wing)
Pull/pull ailerons, pushrod controlled elevator. Can very easly be made into a four channel.
The Texan flies great in a gym and can handle light winds outdoors.
Had to fly it at the local park after flying it at the gym.
Ken
Old Sep 19, 2003, 07:18 AM
Tarpon Shawn is offline
Find More Posts by Tarpon Shawn
I'm kind of a big deal
Tarpon Shawn's Avatar
Tarpon Springs, FL USA
Joined Feb 2002
kgmorris,
I can't believe you guys are flying it in a gym. Looks great. Where can they be purchased? I have a GWS Zero I think I will sell and build one of these babies instead.
Shawn
Tarpon Shawn is offline Find More Posts by Tarpon Shawn
Old Sep 19, 2003, 10:50 AM
jnowell is offline
Find More Posts by jnowell
jnowell's Avatar
United States, FL, St Petersburg
Joined Sep 2000
Nice job Ken and Lex, I can't believe you guys beat me. Mine is barely out of the box, too much email to catch up on after returning from NEAT fair.
The Indoor Pylon Racing at SWAC is on, we have the time slot dedicated, RC Groups will be providing trophies, and Hobby Lobby will be bringing some nice prizes. Rare Bears, Strega's and AT-6 are all welcome! See you there.
Jason
jnowell is offline Find More Posts by jnowell
Old Sep 19, 2003, 11:44 AM
Martin Hunter is offline
Find More Posts by Martin Hunter
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
That last picture is particularly striking. Nice looking planes, guys!
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Sep 19, 2003, 05:49 PM
Paul Willenborg is offline
Find More Posts by Paul Willenborg
Registered Lifeform
Paul Willenborg's Avatar
Little Rock,AR,USA
Joined Jun 1999
How to build a Texan...
I shot some pictures during the build of my FanTastic AT-6. These will answer a lot of questions about the basic construction. However, remember that this is a pre-production kit, so some details could change. Also, I built it without instructions, so I might have done some things differently than the designers intended.
First step was glueing the fuselage halves together. I did this before cutting out the canopy and wing openings- this keeps the pieces stiffer and makes it easier to get them lined up. The whole model was built with thick and thin foam-safe CA glue.
This photo also shows the bamboo dowels that are glued to the wing leading edge. They have to be cracked to fit the dihedral break. I cracked them, test fitted them, then soaked the cracked area in thin CA to reinforce it.
Paul Willenborg is offline Find More Posts by Paul Willenborg
Old Sep 19, 2003, 05:52 PM
Registered Lifeform
Little Rock,AR,USA
Joined Jun 1999
Next I trimmed the remaining parts and cut away the tail control surfaces. The elevators are joined with the typical "U" shaped piece of wire.
Old Sep 19, 2003, 05:54 PM
Registered Lifeform
Little Rock,AR,USA
Joined Jun 1999
The wings only need to have the root area trimmed and a groove sanded into the LE to receive the bambo dowel.
Old Sep 19, 2003, 05:59 PM
Registered Lifeform
Little Rock,AR,USA
Joined Jun 1999
I left the ailerons attached to the wings for the time being to prevent damage to the wingtip as it got tossed around the workbench. The wing halves are glued together- the flat center section automatically sets the correct dihedral.
A little bump on the wing surface at the joint indicates the location for the aileron servo. I cut a small hole there to allow the top of the servo to extend through the wing.
The bamboo dowels are glued to the leading edge and joined in the center by a small piece of aluminum tubing.
Yippee! first flights windy, bad battery, and two planes plane stupid Beginner Training Area (Aircraft-Electric) 5 May 15, 2004 07:06 PM
DR 1 First flights Ron Scale Kit/Scratch Built 26 Aug 05, 2001 11:12 AM
Mini Laser 3D- First Flights Adam in Toronto Electric Plane Talk 2 Jul 23, 2001 12:27 AM
Litestick First Flights - Batteries? mrebman Parkflyers 9 Jul 16, 2001 09:40 AM
First flights of Slim-Gym 280 (SG-280) realglow Parkflyers 6 May 14, 2001 06:50 PM
