Old Aug 29, 2011, 12:01 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Skymaster 2M ViperJet
We have been working with Kenny McSpadden and Acme Jets over the last year to perfect the latest version of our fan system. Our new system is capable of sustained 20,000 watts even with high g-force loads. The main shaft now starts out as a 30mm diameter solid billet piece of tempered steel. That is turned down to 8mm, except for the very end which is turned down to 26mm x 6mm wide (an end plate), which is then drilled with counter sinks The shaft is pressed into the end bell and then 4 screws are used to secure the end plate directly to the end bell. This prevents the ability of the bell to wobble at all. There is also now a molded strain relief for the wires. We still are using 3 huge high quality Japanese bearings. The end result is a very reliable system that is able to take the place of mid-range (120N/130N) turbines. Our next focus is on a larger fan system (175mm) to power models in the 50 pound range with 160N size turbine performance.
Kenny flew his ViperJet at the Big Jolt this past weekend. He recorded a fast pass of 195.6MPH. This is a 33 pound 2 meter Skymaster ViperJet. It is normally turbine powered, and no attempt was made to save weight anywhere. This is just a direct conversion from a turbine aircraft to an electric aircraft.
John Reid at Model Airplane News was nice enough to donate the use of his high definition video camera and got some great on-board footage of Kenny flying around. That can be found here:
http://www.modelairplanenews.com/blo...ideo-coverage/
Here is a Youtube video as well.
video-2011-08-27-12-24-11.mp4 (1 min 9 sec)
As we find more videos that pop up, I will link to them in this thread.
Thanks to Kenny for being such a good sport, and helping us test our fan system!
UPDATE! Our production motors arrived today! The strain relief is rubber now instead of hard plastic (making it easier on wires), there are isolator barriers to prevent wiring chaffing during winding (no nicks can occur by accident now which happens sometimes with machine winding), the billet shaft cap is machined nicely with black screws, the collar retainer is used instead of a C-clip, making the shaft a full 8mm diameter. Other small changes were made for alignment in our hubs.
JimDrew is offline Find More Posts by JimDrew
Old Aug 29, 2011, 12:20 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2015, May 28-31st
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Can't wait to see it at E-Jets.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Aug 29, 2011, 12:26 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
We won't be attending E-Jets. We will be attending Best In The West October 1st.
Old Aug 29, 2011, 12:27 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Originally Posted by JimDrew View Post
The main shaft now starts out as a 30mm diameter solid billet piece of tempered steel. [/url]
I think you need to go take a look at the descriptive words you are using above. The term "billet" and "tempered" don't belong in the same sentence. Billet steel is the raw unprocessed material that has no temper and must go though further processing. The temper or heat treating is usually the final part of the process after machining of the final part.
Steve Neu
sneu is offline Find More Posts by sneu
Old Aug 29, 2011, 12:30 PM
EDF Crazy is offline
Find More Posts by EDF Crazy
EDF Crazy's Avatar
UK
Joined Oct 2007
That was fast and very impressive for such a large plane.
EDF Crazy is offline Find More Posts by EDF Crazy
Old Aug 29, 2011, 12:46 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Steve, since when can you not machine a piece that is already pre-tempered? I was told that the tempering was done prior to machining to prevent a change in the material size that occurs during the tempering process. Perhaps you can check with our factory and let me know if the tempering is really done after the fact. If so, I will correct the statement above.
Old Aug 29, 2011, 02:58 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
New controllers
Here is a real 30S production controller. Good for over 25Kw.
Old Aug 29, 2011, 03:05 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
You been holding back from Jim...
I'll smoke you if give me one of those in my hand.
I'm mean smoke you in the speed run...not the other smoke.
Tamjets is offline Find More Posts by Tamjets
Old Aug 29, 2011, 03:08 PM
bri6672 is online now
Find More Posts by bri6672
bri6672's Avatar
San Diego
Joined Jul 2009
One of my favorite jets to watch this weekend, Ken flew that jet like its meant to flown!!
bri6672 is online now Find More Posts by bri6672
Old Aug 29, 2011, 03:14 PM
sneu is offline
sneu's Avatar
Joined Dec 1999
Truly hard steel is not nice to machine--it is usually ground to size.
Old Aug 29, 2011, 03:15 PM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
Steve Neu
You need too look over your own designing skills before nagging on others :-/ you costed me alot of money already.
henke is offline Find More Posts by henke
Old Aug 29, 2011, 03:44 PM
bri6672's Avatar
San Diego
Joined Jul 2009
Any chance of getting any data logging on it in the future?
Old Aug 29, 2011, 03:49 PM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
it won't be necessary because it is proven to work at it's highest load.
NS.
neversommer is offline Find More Posts by neversommer
Old Aug 29, 2011, 03:54 PM
bri6672's Avatar
San Diego
Joined Jul 2009
NS.
Looking for ESC temps, Battery Ripple, watts, RPM's, voltage readings etc. similar to what the Caslte setup does. Thats good data to have for fine tuning a setup...
Old Aug 29, 2011, 03:58 PM
Luzern/Switzerland
Joined Aug 2008
And you seriously expect this to happen with this ESC, bri?
You are right about to what you say..but I am not sure as this will happen with this ESC.
It looks like a modern chocolate bar.
NS.
Discussion Skymaster Viperjet EDF Prototyp maiden Liebrein Electric Ducted Fan Jet Talk 423 Oct 31, 2014 10:21 PM
Discussion Hobbytopgun ViperJet kimhey Foamy EDFs 2 Sep 29, 2011 06:27 PM
Sold Sapac ViperJet ARF+ FNFAL Aircraft - Electric - Jets (FS/W) 5 May 12, 2011 10:02 AM
Discussion Sapac Viperjet ciscovet Electric Ducted Fan Jet Talk 3 Apr 01, 2011 09:33 PM
Discussion Skymaster 1.6M ViperJet w/XPS Dynamax Xtreme JimDrew Electric Ducted Fan Jet Talk 31 May 06, 2010 11:30 PM
