Old Aug 25, 2003, 11:13 PM
Bonez is offline
Find More Posts by Bonez
Bonez's Avatar
Moorpark, CA
Joined Oct 2002
E-Starter w/300C Questions
My maiden with my AF010 did not go so well last weekend. So rather than damaging the AF I decided to go back to the factory 300C set up. However, my E-starter is a whale at 17.5-ounces with factory 300C and 7-cell 720 nimh.
Questions: Will the factory 300C work with this weight? Should I use a 1080 or 9070 prop? (Motocalc indicates overtemp concerns)
I will have to hand luanch this bird since I doubt it will plow even short grass...
Anyone share their weight/set-up that will guide me before next weekend?
Many thanks.
Bonez is offline Find More Posts by Bonez
Old Aug 26, 2003, 05:59 AM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Mine weighs 16 oz with 6 cell nicad - flies real good. Completely stock built. Rog's out of 3" grass. Yours sounds a little heavy but should be ok. I'm using the stock 10/8 prop - and it's flown on 7 cell 700 ni-cad, GWS 6 cell 600 ni-cad and GWS 7 cell 700 NIMH.
skyhawk is offline Find More Posts by skyhawk
Old Aug 26, 2003, 06:00 AM
skyhawk is offline
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
pic
Old Aug 26, 2003, 08:40 AM
Bonez is offline
Bonez's Avatar
Moorpark, CA
Joined Oct 2002
Thanks Skyhawk. I will give it a go this weekend.
Old Aug 26, 2003, 09:08 AM
fourstarforty is offline
Find More Posts by fourstarforty
Chilliwack, Canada
Joined Sep 2000
My E Sarter weighs 17.1 oz flys with the stock setup gws 300C drive 5.33:1 gearbox 10:47 gws prop.I use a 8 cell gws 720 nimh pack get around 7 min flight time and fly inverted for the first 3 min or so
fourstarforty is offline Find More Posts by fourstarforty
Old Aug 26, 2003, 09:33 AM
mrebman is offline
Find More Posts by mrebman
Cincinnati, Ohio USA
Joined Nov 2000
How would the Estarter fly with the Etec 1200-2S Lipoly Pack & the GWS 10x8 stock prop?
-Mike-
mrebman is offline Find More Posts by mrebman
Old Aug 26, 2003, 10:16 AM
pc_pilot is offline
Find More Posts by pc_pilot
USA, NY, Yonkers
Joined Aug 2002
From the reports around here it will fly very well with the etec 1200. Use the 10x8 prop, I had the best performance with this. Take off at full throttle then fly around at half throttle.
pc_pilot is offline Find More Posts by pc_pilot
Old Aug 26, 2003, 10:51 AM
Warren Jones is offline
Find More Posts by Warren Jones
Warren Jones's Avatar
Langley,B.C,Canada
Joined Jul 2002
My Speed 400 E-Starter
I had one of these and completely wore it out. I eventually strapped on a S400 direct drive/5 inch prop. It flew unreal. Took the gear off and ran 8 cell 1100`s. Totally transformed the plane in to a little aerobat.
Lots of fun.
Cheers
Warren
Warren Jones is offline Find More Posts by Warren Jones
Old Aug 27, 2003, 08:32 PM
mrebman is offline
Joined Nov 2000
Has anybody actually flown both the Etec 1200-2S & 10x8 Prop -vs- the GWS 8-cell 730 Minh AAA pack & 9x7 prop? How do these two combinations compare (Which is better)?
-Mike-
Old Aug 28, 2003, 09:23 AM
nikko is offline
Find More Posts by nikko
Ponca City, Oklahoma, United States
Joined Oct 2002
I will be trying out my new E-tec 1200's in my E-starter this weekend after I modify my battery compartment for better access and cooling. I was a using 8 cell 800ma nimh and had good performance just short run times and the battery was getting way too hot. One new pack I had only lasted about 10 flights b4 it was shot (I'm guessing due to heat). I do not want this to happen to my e-tec batteries. I will post this weekend with the results....
nikko is offline Find More Posts by nikko
Old Aug 28, 2003, 09:39 AM
guyaneze is offline
Find More Posts by guyaneze
guyaneze's Avatar
gainesville FL
Joined Jan 2002
nikko: odd....u doing pylon races with the e-starter?...I've used quite a few different packs with my 300c and a 10x8 prop....and i haven't killed any yet....
I've been flying a modified 300c (gearbox turned backwards), which even draws a little more current than standard...and a 1200mah 2s etec pack for a while now...with no sign of problems due to heat. I think the current draw I measured was somewhere between 8-9amps max...static. I hardly ever fly full throttle for the whole flight....I use full throttle to escape from gravity...but once up there...i fly mostly at about between 50% and 80% throttle until the power starts to fade....by the end of the flight i have no other choice but full throttle....batts and motor are usually quite warm
guyaneze is offline Find More Posts by guyaneze
Old Aug 28, 2003, 01:20 PM
nikko is offline
Joined Oct 2002
I have had a problem with my GWS P-51, beaver and Estarter with hot batteries. I read somewhere that it was due to using a 9.6 volt battery. I think that it is due to lack of ventilation on all of these models. I have modified my beaver already, drilling some holes on the side of the fuse. I am going to try to remove the battery hatch on the E-starter and replace it with velcro I saw on an earlier post, leaving part of the bottem open for better ventilation. I too run 3/4 to full throttle on the e-starter, but my beaver gets hot from running less than half.
Old Aug 28, 2003, 01:56 PM
Bonez is offline
Bonez's Avatar
Moorpark, CA
Joined Oct 2002
This is where my concern comes in: Motocalc predicts overtemperature for the 300C with 7 and 8 cell packs. Seems like some of you are experiencing what Motocalc predicts.
Old Aug 28, 2003, 02:29 PM
gstegman is offline
Find More Posts by gstegman
Northen CA, Bay Area
Joined Jun 2003
E-techs
I am flying E-tech 1200's on the stock set-up and am having a complete blast. Prior I was using 8 cell 720 nimh packs from Aeromicro and they were nice.....but you can feel the difference in weight in the air.
I fly half throttle, no crazy stunts and have gone 25 minutes before I was ready to land. The battery had more to give as my Triton indicates putting back 400-500mah's!
I have a Razor 350 laying around but the plane flys so sweat now, I don't think I will mess with it.
I did see a long estarter thread where Guapoman2002 (?) had all kinds of data on different batts and motors. This guy know a bunch.
gstegman is offline Find More Posts by gstegman
Old Aug 29, 2003, 08:53 AM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
I am flying with an E-Tech 1200 2S1P battery pack in this E-Starter with floats.
AUW 411 grams (14.67 oz)
Stock 300C-CS, 5.33:1, with the motor retimed by moving the brushes 8mm clockwise.
10x8 propeller either stock or cut down to a 9x8.
A very good flyer.
Ken
kensp is offline Find More Posts by kensp
New E-Starter w/ Castle Creations 20P Scaps GWS (Grand Wing Servo) 6 Mar 01, 2004 08:09 PM
e-starter (Cessna Skylane) Questions and progress... Nik-rc Parkflyers 54 Feb 20, 2004 09:40 PM
E-starter w/350c wants to turn left! Help... albireo Parkflyers 6 Oct 18, 2003 01:56 AM
E-Starter, Battery/motor questions headless GWS (Grand Wing Servo) 19 Oct 11, 2003 04:24 AM
newbie to flight - have a E-starter with 1001 questions PhillyB Foamies (Kits) 10 Jun 26, 2003 06:45 AM
