Old Nov 22, 2011, 06:36 PM
paullie is offline
Find More Posts by paullie
Are we having fun yet?
paullie's Avatar
USA, NY, Clarence
Joined Jan 2010
Originally Posted by rawUAV View Post
Hows this for starters...
Removable hatch? I like it, have to do something like that for my Senior.
I'll print out that post with the pics and tape it to the wall o' ideas.
paullie is offline Find More Posts by paullie
Old Nov 22, 2011, 08:23 PM
rawUAV is offline
Find More Posts by rawUAV
rawUAV's Avatar
Joined Mar 2011
This is as far as I go till the wing dihedral is set with an epoxied root. The part "WF" must be fabricated in order to start the windscreen and I need the wing to finish WF.
rawUAV is offline Find More Posts by rawUAV
Old Nov 23, 2011, 10:47 AM
doc993 is offline
Find More Posts by doc993
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Awesome! hey check out the other Sig conversion in this forum,Tony is a pretty good builder,you'll like it. Package mailed yesterday,use some magnets on the wind shield hatch Man that's going to be cool.opcorn.
doc993 is offline Find More Posts by doc993
Old Nov 23, 2011, 08:22 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
Yea! Good thing he reminded me to do that. We had discussed it a while back. It fits nice and tight. I considering putting a piano wire hold-down pin through the firewall.
Old Nov 23, 2011, 09:59 PM
paullie is offline
paullie's Avatar
USA, NY, Clarence
Joined Jan 2010
I'm learning from you here so keep on posting the pics! This is great!
Old Dec 02, 2011, 10:55 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
See my new post:
http://www.rcgroups.com/forums/showt...9#post20036412
Old Dec 14, 2011, 07:51 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
I picked up the saw to begin cutting-up the wing. I'll pick up some nerves this weekend...
Old Jan 07, 2012, 12:57 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
Time to kick it up a notch. I realized, given the predicament I put myself in, that using a good-stiff, old-style hand saw would be the safest bet to cut the ailerons/flaps. I will need to do a bit more sanding than I wanted. I wanted to use my table saw, but that was just too risky. I will trim the cutoff with it though.
Old Jan 08, 2012, 07:14 AM
doc993 is offline
doc993's Avatar
Joined Dec 2009
Intense cut's man Look's good ,Keep up the good work.I'm starting to read on radio systems.At some point we will have to decide what suits our needs best.I also have been looking at diamond servos,They have servos that meet or surpass hi tech for a lot less.
Old Dec 23, 2012, 05:54 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
The Resurrection
From the ashes of deep despair comes the desire to fly among raptors. Plus a good excuse to buy a new radio.
Old Dec 23, 2012, 09:14 PM
Staggerflyer is offline
Find More Posts by Staggerflyer
Staggerflyer's Avatar
Tama, Iowa USA
Joined Dec 2007
You will love that radio! I won't give mine up for nothin', (except maybe a 10 or 12 channel Spectrum!!)
Staggerflyer is offline Find More Posts by Staggerflyer
Old Dec 23, 2012, 11:07 PM
doc993 is offline
doc993's Avatar
Joined Dec 2009
DUDE!
Old Aug 24, 2014, 03:47 PM
Davo777 is offline
Find More Posts by Davo777
Davo777's Avatar
United States, UT, Salt Lake City
Joined Mar 2010
Now I kind of wish I would have found this thread before I started on the hatch on my Kadet MKII conversion. My hatch is similar to the one that was shown but didn't turn out as good.
Details of my power system/conversion. In retrospect I was really close but would have been better if I would have went with a Rimfire .46 and probably a 5S 2600-3000 mah lipo instead seeing as I needed 3.5 ounces in the nose to get it to balance.
- Rimfire .32
- 4S 3300 mah lipos
- Castle ICE 75 ESC
- Futaba 6EX
- standard Airtronics servos on elevator and rudder
- 1 Hitec HS-255mg on each aileron
- converted to taildragger with 1 Futaba s3114 steering the tailwheel
- re-covered in Ultracote
Davo777 is offline Find More Posts by Davo777
Last edited by Davo777; Aug 25, 2014 at 02:58 PM. Reason: Corrected amount of added nose weight from 3 to 3.5
Old Aug 24, 2014, 03:48 PM
Davo777 is offline
Davo777's Avatar
Joined Mar 2010
I forgot to mention larger ailerons as well as the conversion to 1 servo per each aileron.
Old Aug 24, 2014, 05:39 PM
Tama, Iowa USA
Joined Dec 2007
Hi Davo777,
Personally, the only thing I see that needs upgrading is the motor on yours. The Rimfire .46 should give you much better performance. The .32 is to small, in my opinion. You would like it much better, I assure you. The upgrade should be quick and easy.
If done properly, the taildragger conversion makes the Kadet fly much better, I think. Mine was much more maneuverable, while also being smoother. Some day I will finish my third one.
Don
For Sale Sig Kadet Mk II - Minnesota SnoJetter Aircraft - Fuel - Airplanes (FS/W) 1 Oct 09, 2010 03:08 PM
Build Log Sig Kadet Mark II =) gsumano Fuel Plane Talk 3 Jul 09, 2010 12:00 AM
Discussion Fixing a Sig Kadet Mark II - anyone with one have pictures? Raverix The Builders Workshop 1 Jul 07, 2010 08:09 PM
For Sale SIG Kadet Mark II NIB flybaby55 Aircraft - Fuel - Airplanes (FS/W) 4 Apr 25, 2009 06:24 PM
Alert NIB SIG Kadet Mark II Kit Gene Chernosky Aircraft - Fuel - Airplanes (FS/W) 0 Feb 21, 2004 08:38 AM
