This thread is privately moderated by orange&white, who may elect to delete unwanted replies.
Old Apr 22, 2015, 03:56 PM
franciscan is offline
Find More Posts by franciscan
Devon,UK
Joined Nov 2002
jr clipper
What a lovely Jr Clipper. What covering did you use - very translucent?
franciscan is offline Find More Posts by franciscan
Old Apr 22, 2015, 09:06 PM
yosemitealoha is offline
Find More Posts by yosemitealoha
sambino
Waterloo Ontario Canada
Joined Mar 2010
Clipper Jr.
Ultracote lite with Parklite trim.
yosemitealoha is offline Find More Posts by yosemitealoha
Old Apr 23, 2015, 02:25 AM
zl3vml is offline
Find More Posts by zl3vml
Sir Jasper
zl3vml's Avatar
Christchurch - New Zealand
Joined Jan 2003
Comet Clipper ribs
Someone will need to resize this please to correct wing size and convert to pdf
Mark
zl3vml is offline Find More Posts by zl3vml
Old Apr 24, 2015, 04:44 AM
aeromeddeler is offline
Find More Posts by aeromeddeler
Soulles Normandy France
Joined Feb 2011
Mark
well someones gota do it
Comet clipper ribs resized to fit Comets 72 in span plan. For those like me who often convert back to a graphic format the Plan I have is at 300 dpi and the ribs were at 400 dpi (which is good as it allows upscaling to be nice and clear) so I saved at 300 dpi and checked on the plan and they are the correct size.
aeromeddeler is offline Find More Posts by aeromeddeler
Old Apr 24, 2015, 08:10 AM
Devon,UK
Joined Nov 2002
Comet Clipper wing ribs
Many thanks to you both(Mark and Roger) for doing the work to produce the Clipper rib profiles. This is one of my favourites and will enable me to get the complete plane on the board.
John
Old Apr 24, 2015, 01:56 PM
zl3vml is offline
Sir Jasper
zl3vml's Avatar
Joined Jan 2003
Thanks Aeromeddeler.
Just a word of caution. I have not checked this particular plan, but from memory, mine had one wing side marginally wider chord-wise than the other, about 1/8th in so always best to check wing halves for symmetry before building.
Probably the way the plans were printed back them.
Mark
Old Apr 24, 2015, 04:43 PM
Edubarca is online now
Find More Posts by Edubarca
Edubarca
Edubarca's Avatar
Colombia, South America
Joined Oct 2009
Mark
The best way to prevent different wing size is ALWAYS to use the same wing half. To build the other, just rub some 3 in 1 oil to the wing drawing, turn around the plan and proceed to build. Both panels will come out exact!! The plan will not be damaged. 3 in 1 oil evaporates in just a few days and the plan will be fine. Try it, you'll like it!!
Edubarca is online now Find More Posts by Edubarca
Old Apr 24, 2015, 06:02 PM
bascom32423 is online now
Find More Posts by bascom32423
Florida Panhandle
Joined Apr 2002
WD-40 works well also.
bascom32423 is online now Find More Posts by bascom32423
Old Apr 24, 2015, 08:07 PM
Edubarca
Edubarca's Avatar
Joined Oct 2009
Agreed!! I have also used Cooking oil
Old Apr 25, 2015, 12:32 AM
SrFalcon is offline
Find More Posts by SrFalcon
SrFalcon's Avatar
South Africa, GP, Krugersdorp
Joined May 2011
Cooking Oil
I agreed also, cooking oil works great!
Cheers
Sr. Falcon
SrFalcon is offline Find More Posts by SrFalcon
Old Today, 07:59 PM
P_J_Glor is online now
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
Midwest Blue Ridge Comet?
This plan came up on an unrelated E-Bay search, and I have no recollection of this particular model. Although the listing says that it has a 42" span for .15 to .19 engines, the plan itself lists the wingspan at 62" and .25 to .40 engines. Perhaps the seller has reduced the printed size of the plan?
Flaps are optional, but there are no ailerons. Interesting . . .
I did a search on Outerzone and also on Hippocket Aeronautics with no results. It appears that the attached .jpg would not make a very good enlargement. Does anyone have any further info about this plane?
Pete G.
P_J_Glor is online now Find More Posts by P_J_Glor
Old Today, 08:47 PM
PGregory is online now
Find More Posts by PGregory
Now I have to land that thing?
PGregory's Avatar
United States, NY, Poughkeepsie
Joined Apr 2014
Going by the 3.5" wheel size I roughly got 56" +/- 1"
The Other Pete G.
PGregory is online now Find More Posts by PGregory
Gallery Vintage & Old-Timer Plans built gallery orange&white Vintage & Old-Timer Designs 467 Mar 21, 2015 10:10 AM
Discussion Best source for Vintage/Old Timer plans? river-studio Vintage & Old-Timer Designs 18 Nov 09, 2012 07:56 AM
For Sale Old timer Sal Taibi plans Biper/Piper Aircraft - Fuel - Airplanes (FS/W) 2 Aug 15, 2011 09:30 AM
